Re: Detonation
[Re: JoesMopar]
#520165
11/10/09 09:44 AM
11/10/09 09:44 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Yeah what it would do is just crank longer because of the advance. It was really bad once the motor got warmed up and the only way I knew to fix it was back the timing off.
I'll try your suggestions and see if it fixes it. I appreciate all the help as usual.
I thought you meant kicking back on the starter and assumed to be doing that at 36 someone must have shortend the slots. no real reason it should have been harder to ignite?? maybe you were timid on the throttle! LOL!!
Re: Detonation
[Re: JoesMopar]
#520169
11/10/09 02:24 PM
11/10/09 02:24 PM
Dodgem
Ontario, Canada
Tune completely with vacuum off. you will be able to use 93 but get summer 93. yours may not vary as ours in the cold north! work the mechanical advance idle and what not for a few weeks to get the best total 36 to 38 produces best HP and to get a good idle 900 to 1000 in gear with 22 or so idle advance. tune till till you have no ping under any driving conditions Once you are happy and have not made changes in a couple weeks?? Then and only then you can if you must plug the vacuum advance back in to ported vacuum. I would expect light throttle ping to come back at this point! so with a 3/32 allen wrench in through the hole in the dis vacuum port you start tuning out that ping by turning CC. I would go 3 turns right off the bat. drive and keep going CC till you have no ping under any driving conditions (I personally think the vacuum advance has no place on a performance car especially with todays fuels) By the time you tune out ping it does little anyways. If you were to adjust timing with it hooked up now you would lose all your WOT performance??? ![](/ubbthreads/images/graemlins/eeek.gif)
Re: Detonation
[Re: JoesMopar]
#520173
11/15/09 10:48 AM
11/15/09 10:48 AM
Posts: 271 Dallas, Wisconsin
BurntOrange
Dallas, Wisconsin
I'm running a Comp 292/299 .509/.509 cam, Edelbrock 84cc closed chamber heads, Holley 870 street avenger carb, MP ignition (distributer w/chrome box). The block has alsobeen zero decked and I'm running KB flat tops. Can't remember the head gasket thickness, maybe .020"?
Zero deck and .020 clearance? What's your compression ratio?
