So I had the trunk floor in and the tail light panel was sitting in corner looking totalled. I don't mind spending a couple bucks when needed, but I don't like to waste them! I figured with all the work it's taken to get the aftermarket stuff installed , I'd better give this panel a shot. Much to my delight, it's not that tough. Take your time and make it happen! The repop stuff is great when you don't have an option but if yours looks marginal, fix it. The more I get into this project the more it becomes apparent that you can fix almost anything.
