Considering the millions of dollars spent each year by less educated owners on so-called
'cold air intakes'
with washable filters that are only slightly less restrictive
(typically 3 inches of water out of 404 inches total air pressure, and this compared to a paper filter with more pleats/area only just for a short period after proper washing, not after even 3,000 miles of road use)
it has always seemed a great shame
that the benefits of water injection
were not better understood
and that newbies be directed toward kits like the Spearco,
Snow Performance,
English Aquamist, etc
The fact that Buick found out the hard way that some owners of water injected and supercharged factory engines could not be trusted to fill their water reservoirs may be one reason water injection kits never caught on.
It is little known
that water injection is as good as
Exhaust Gas Recirculation (EGR)
at reducing NOx pollution
but when used has a fuel economy benefit
( up to 6%)
because a higher compression ratio can be used.
If you want to be sobered by another 'government waste' number,
calculate the dollar amount
of what saving 6% of all the gasoline
used in the USA
since the passage of the Clean Air Act in 1971 would be.
It is in the hundreds of Billions of $.
It is even sadder that lower level engineers at the EPA Labs in RTP North Carolina know and understand this, but their politically appointed bosses wouldn't have a clue about how to calculate it.
