Re: 68 SPORT SATELLITE PROJECT UNDERWAY FOR DAD
[Re: JDMopar]
#518768
09/25/10 11:26 PM
09/25/10 11:26 PM
Posts: 2,495 Richmond , Virginia
BEEQUIK
Richmond , Virginia
Looking good! Spray a gallon on.....sand 7/8 of a gallon back off! So what's the "X" taped on the left quarter for?
That was a spot that got some block sanding prior to the heavy fill,just for good measure without going through the epoxy.No kidding about sanding most of it off,too bad I can't recycle it and put it back in the paintgun!!
[Re: BEEQUIK]
#518769
09/26/10 11:35 PM
09/26/10 11:35 PM
BEEQUIK
Richmond , Virginia
OK- we have a winner on the color!! Check this out , it is 2009 "Plymouth" Electric Blue Pearl.Close to the original but with some new technology mixed in for effect!! It was a tough choice but I'm glad we can move on now and maybe see some color flying pretty soon. Here it is...Drumroll...
[Re: basketcase]
#518771
09/27/10 09:55 PM
09/27/10 09:55 PM
BEEQUIK
Richmond , Virginia
that color is perfect! keep the pics comming! and since you're in a B Body mode....I've got a set of skins that are dying to go one.....
where are you located?We may be actually renting a shop shortly with a lift and a paintbooth so I can hook you up!!We would be able to handle ALL facets of body and paintwork from Racecars to restos and custom paintwork. May even have a mechanic and I have an Excellent MOPAR race engine builder that can build mild to wild engines and transmissions.I will keep you posted.May even be able to become an AMD distributor.
[Re: BEEQUIK]
#518775
10/03/10 10:25 PM
10/03/10 10:25 PM
BEEQUIK
Richmond , Virginia
another- wanted to get some primer in the trunk jamb.I will scuff and shoot sealer on the bottom of the trunklid and then paint it.It did not really need much of anything else...
[Re: BEEQUIK]
#518776
10/03/10 10:31 PM
10/03/10 10:31 PM
BEEQUIK
Richmond , Virginia
My friend Seamus is one of the painters at work and we were both in the booth spraying today trying to get this thing knocked out.I am very grateful for his help,he masks a car faster than anyone I have ever met.Thanks man!
