New Best - and through the mufflers too
#518676
11/07/09 10:59 PM
11/07/09 10:59 PM
Posts: 16,934 NC
440Jim
NC
I set a new best today, and it was using mufflers (which I don't normally run). They were 4" bullet mufflers, but they are mufflers! At Maryland International Raceway (MIR) in Budds Creek Maryland, they are having their big "World Cup" (import vs domestic) street car race. Today was time trials and qualifying for the various classes. Sunday is eliminations. http://www.mirdrag.comAll classes require mufflers, and the only thing I could fit my car in after adding mufflers was the "Street ET" class which only requires headlights, tail/brake lights, and mufflers. Anyway my car went a new best (for E85) with a 1.229 sixty foot and 9.215 at 142 mph. It also backed up that run with another 1.229 and 9.217. 56 degrees, 41% RH, 30.21"Hg
Re: New Best - and through the mufflers too
[Re: 440Jim]
#518677
11/07/09 11:12 PM
11/07/09 11:12 PM
Posts: 16,934 NC
440Jim
NC
I guess I should also post the combo summary: 4.250" Stroke Callies Crankshaft, 4.375" bore, 511 CID BEST Machine aluminum main caps, 400 block align bored to 440 main size SCAT H-beam rods, ARP 2000 bolts, 6.535" long, 2.200/0.990 Milodon windage tray with custom crank scraper welded on Indy 440-1 heads, 68cc, 0.700" 350. cfm, 0.800" 368. cfm Titainium retainers, 2.25" intake valve Flat top pistons, 13.5 CR Indy 400-3 intake, Comp Cams solid lifter 305º/320º@.020", 279º/287º@.050", 197º/200º@.200", 110 LSA (not a roller) published 0.650"/0.630" but I am running 1.6 rockers for .690"/.670" Ron's Flying Toilet mechanical injection, http://www.ronsfuel.comCustom built headers, 2-1/8” tubes 32" long, 4” collector 727 trans, 5400 stall converter, 4.30 gears in a Dana 60 rear Phoenix slicks 31.25 x 12.2 W, actual 32.0 x 13.6 3210 lbs with driver
[Re: 440Jim]
#518680
11/07/09 11:32 PM
11/07/09 11:32 PM
congrats on the new best. so what did that air desity work out to be?
#518681
11/07/09 11:38 PM
11/07/09 11:38 PM
Posts: 16,934 NC
440Jim
NC
That's about -300 ft DA (below sealevel standard density) The high pressure, low temp, and low track elevation (80 ft) really helps. I almost didn't go, but I was glad I did to take advantage of the good air.
The barometric pressure was dropping all day, and was down to 30.10"Hg by the end of the day.
[Re: 440Jim]
#518684
11/08/09 03:57 AM
11/08/09 03:57 AM
fullmetaljacket
[Re: Plumcrazyracing]
#518687
11/08/09 06:08 AM
11/08/09 06:08 AM
Posts: 16,934 NC
440Jim
NC
The wheelie bars came with the car, so I don't know the brand. I will have to measure the length, but they are not real long.
EDIT: The bars measure 51" long, plus a few inches from the bar mount to the center of the axle.
They did have springs, but this year I took them out and put solid spacers in them. It works fine for me, but I use front end travel limiting to match track conditions (air/power level) to balance the weight transfer and not hit the wheelie bars too hard. But it does use them to control the wheel stand.
You can see the wheelie bars in this attachment from 2002.
[Re: 440Jim]
#518690
11/08/09 11:22 AM
11/08/09 11:22 AM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You sure do have your ride sorted out. You made 807 hp on that day, going by the 5.825 formula. That is a whole lot of oats gettin burned!! Congrats on the new best. By the way, curious just what your front/rear weights are?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#518693
11/09/09 01:13 AM
11/09/09 01:13 AM
Posts: 16,934 NC
440Jim
NC
I will have to look it up, it was a few years ago, but as I recall the front end is heavy. And I think that is why this car must wheel stand or the tires will spin; it needs the weight transfer.
[Re: 440Jim]
#518695
11/09/09 08:53 AM
11/09/09 08:53 AM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Congrats Jim!!! ![](/ubbthreads/images/graemlins/beer.gif) CHIP
