Re: New MOPAR 5 speed from McLeod!!!!!!!
[Re: CJK440]
#517322
11/07/09 11:24 AM
11/07/09 11:24 AM
Posts: 10,607 Rittman Ohio
fourgearsavoy
Rittman Ohio
That has to be the race version from the look of the straight cut gears and faceplate engagement dogs. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: StrokerAspen]
#517323
11/07/09 11:30 AM
11/07/09 11:30 AM
Posts: 6,033 Salem
Grizzly
Moparts Proctologist
Salem
I LIKE THE LOOK OF THIS AS WELL!
Looks like it means business. So simple. Hope it works as good as it looks.
One of the photos shows straight-cut gears.
And, aluminum case?
Hope the Overdrive ratio is around 0.67
[Re: Grizzly]
#517324
11/07/09 11:47 AM
11/07/09 11:47 AM
Posts: 419 NY
F1Scamp
NY
Man. Too bad I already cut the scamp up for the tko-600. That thing looks bad.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: fourgearsavoy]
#517325
11/08/09 01:40 AM
11/08/09 01:40 AM
Posts: 9,112 Rogue River, OR
Jeremiah
Rogue River, OR
What's wrong with dogs on the street? It looks to be the perfect multi-use unit for those of us that like to do some straight line action as well as some corner carving. I'll bet it would live with a street duty slipper clutch....
I'm interested to see how it shifts...I never really liked the feel of the tko's but that's me.
[Re: Jeremiah]
#517326
11/08/09 11:25 PM
11/08/09 11:25 PM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
I have known about this for a few weeks already prior to SEMA. The part that really upsets me is that the entire unit is made in Taiwan. That explains the 2300.00 price tag. I have to be honest with you though, I am more than scared looking at the gearset. Hasn't anyone noticed that the gears are VERY narrow. There is little room for load carrying capacity. I understand the bearing support on the cluster gear, However, that will not stop the teeth from wiping off. They say it will take 1000 lb ft of torque. I have heard Keisler state that the TKO will take 1400 lb ft or torque. However, we have seen these units break WELL below the 1000 mark. The thing that everyone is forgetting is... What kind of resistance was put behind the unit. If there is no resistance it should handle 10,000 lb ft of torque. NOW, put it in a 3600 lb car and lets see what happens...
I am not knocking it. I am just stating that physics is physics and we learned A LOT making the OD gearset as to what you need to make things survive. OH, and by the way, to my knowledge, there is no other gearset.
The other point, is... does this really looki like it is gonna fit in an A Body, or a front mount B Body? Just looking, I say no way... Any other input from people?
When I was speaking to Red, he really glossed over the "fitment" issue. He just said that the tail will fit all the Chrysler cars. I think that we all know that there are drastically different dimensions between the the main body styles. We shall see...
I don't know that I would rush out and buy one just yet...
I do welcome discussion on this topic.
Jamie
[Re: JamiePasson]
#517328
11/09/09 07:54 AM
11/09/09 07:54 AM
Posts: 2,477 Answering the call of the wild
ThermoQuad
I am very skeptical the depicted box in the linky will fit in the tunnel of an E body or a 68-70 B body. Being a bit older, maybe wiser now I will await the reports from the people who jump in and get rather than get myself Good luck... In the meantime I will continue the yearly torture testing of the Passon Aluminum 4sp OD in my pos on the road course and the drag strip.
[Re: wicked]
#517329
11/09/09 09:56 AM
11/09/09 09:56 AM
JamiePasson
Sugarloaf, PA. USA
Wicked, Its funny you say that. That is exactly what it is. I am just very skeptical as to fitment. Like I said, when I spoke to Red at McLeod, he didn't even know what I was talking about as to the different crossmember locations and shifter locations. Lets look at the details, What about shifter handles, More $$$ can you use a console? trans mounts and crossmembers, More $$$ speedo cables, etc, more $$$ driveshaft length, more $$$
So, once again, the $2300 really isn't $2300 at all...
Just pointing out details that surface once you start to try to put it in the car.
[Re: JamiePasson]
#517330
11/09/09 10:30 AM
11/09/09 10:30 AM
Posts: 227 Tennessee
rj8806
Tennessee
.... I have heard Keisler state that the TKO will take 1400 lb ft or torque.....
Actually Jamie, it is not Keisler that says the TKO will take 1400 ft/lbs, it was Tremec. ....and what our Tremec rep said was "they had a TKO-600 on a dyno and hit it with 1400 ft/lbs and the jig holding the tranny broke".
Take that for what it's worth as none of us here at Keisler were there when then went down, but we have never told anyone that a TKO-600 will definitely stand up to that much torque.
Richard Tech Support
[Re: JamiePasson]
#517331
11/09/09 12:05 PM
11/09/09 12:05 PM
Posts: 905 cleveland Ohio
mloboda
cleveland Ohio
.... The part that really upsets me is that the entire unit is made in Taiwan. That explains the 2300.00 price tag...Jamie
That's right, everybody just keep on buying chinese made junk 'cause it's cheap. Mcleod will never get another dime of my money. To me, that's GREED. Plain and simple. The next job lost is increasingly more likely to be your own.
[Re: JamiePasson]
#517335
11/09/09 03:29 PM
11/09/09 03:29 PM
rj8806
Tennessee
No worries. I didn't take your response as a dig to us, I just wanted to make sure no one reading this took it the wrong way. If they go back and look at my past posts, I have had nothing but good things to say about you and your transmissions and I have always seen your opinions to be very informative and upbeat. Richard Tech Support
[Re: LAR_414]
#517336
11/09/09 03:34 PM
11/09/09 03:34 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Other than custom stuff like Viper 6 Speeds, Richmond 5 speeds, etc. Right now we basically have 3 choices for a steetable OD manual trans: Passon, Kiesler, and Gear Vendor.
All of them have thier good and bad points, the reasons people choose one over the other often comes down to nothing more than personal choice. I wouldn't mind seeing another choice come into the market, it will likely have it's good and bad points as well but the price, even though bare bones, makes it look pretty good. Time will tell.
[Re: hemicop]
#517338
11/09/09 04:59 PM
11/09/09 04:59 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
I must have walked right by this thing. No mention of it being a Mopar app that I saw. Sure looks like it sticks out in spots where the floor is. The shifter deal looks a bit funky, but boots should prevent and dirt issues. Not happy with the import deal, but to the guy that said we buy because it's cheap, maybe it's more like buy that or nothing.... I sure won't be in the market for one in the near future, but I'm glad there is another choice. T oo many booths said that they do stuff, untill they saw my Mopar badge and shirt. I even had one guy say "Why don't you just go with an LS1 like everyone else?" I expect he drives a silver econobox and lives in a planned gated community...
[Re: hemicop]
#517339
11/09/09 05:00 PM
11/09/09 05:00 PM
JamiePasson
Sugarloaf, PA. USA
I see your point. I am not trying to be a jerk. I am not pointing out the shortcomings. I am pointing out that it doesn't seem like it is gonna be able to fit where they say it is going to. Has anyone looked at how far above the trans the shifter mechanism is? There is NO WAY that is gonna fit without cutting the floor. I doubt that a console will fit over it either. Well, I don't want to get a bad rap here. So, I will just wait and see what develops with it... Jamie
