Page 1 of 7 1 2 3 4 5 6 7
New MOPAR 5 speed from McLeod!!!!!!! #517300
11/06/09 10:24 AM
11/06/09 10:24 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
Looks like they are making a 5 speed that will fit directly into our cars with no cutting, and can handle some power.
I wonder what the details are, and how much $
http://www.bangshift.com/blog/Bangshift-Approved-The-McLeod-M-800-5-Speed-Transmission.html
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: LAR_414] #517301
11/06/09 10:34 AM
11/06/09 10:34 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Looks really good,I just hope the entry fee is'nt 6k lol. Now if I sell my 2 race built 904s & 3 converters... Then I could bug you Larry about a good clutch setup.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: LAR_414] #517302
11/06/09 10:35 AM
11/06/09 10:35 AM
Netherlands
72Challenger Offline
Netherlands
Looks good for the currently more and more big ci / mighty hp streetcars being build. Of course the big Q will be what it will survive on the strip I guess. It's just not me who will figure it out as I just ordered a GForce GF4A trans for the racer. As said, at least it looks tuff!
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: 72Challenger] #517303
11/06/09 10:38 AM
11/06/09 10:38 AM
LAR_414 Offline OP
LAR_414  Offline OP
I hear ya! I'd like to try one of these out with my RST street twin clutch setup. I just have a feeling that the cost is going to be big. I wonder what kind of ratios we are talking about too. Sure would be nice to drive to the track in an overdrive, but yet, still be able to shift through 4 gears at the track.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: LAR_414] #517304
11/06/09 12:50 PM
11/06/09 12:50 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Hopefully the price isn't too outrageous... If it's reasonable I've just found the perfect trans for my duster
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: DemonDust] #517305
11/06/09 12:54 PM
11/06/09 12:54 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Per the comments section $2300.00
IMO, pretty reasonable.
Ed
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: DemonDust] #517306
11/06/09 12:56 PM
11/06/09 12:56 PM
Somewhere Over the Hill
Mr. Dodge Offline
Mr. Dodge  Offline
I thought i saw someone said 2300.00 in the comments section below the artical
"The advantage of being armed the Americans possess over the people of all other nations,which are carried as far as the public resources will bear, the governments are afraid to trust the people with arms."(James Madison) 69 Hemi Coronet R/T 70 456 Dart Swinger
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: Mr. Dodge] #517307
11/06/09 01:15 PM
11/06/09 01:15 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
IF ITS REALLY !!!!!!2300!!!!!!! IM INN!!!
That even looks kind cool, better than the kesler imho
Kasey
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: Moparnut426] #517308
11/06/09 03:01 PM
11/06/09 03:01 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I LIKE THE LOOK OF THIS AS WELL!
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: StrokerAspen] #517309
11/06/09 03:31 PM
11/06/09 03:31 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I saw it at SEMA, Red from mcleod said they were thrashing to get it done in time for the show. The cluster gear is multi-peice, that allowed them to put a bearing in the middle of it that mounts in a bulkhead thru the middle of the case. That's where the strength comes from. THe overdrive is mounted in the tailshaft housing. It is all syncronized, so I don't know how well it will shift in drag racing applications. I suppose it can be slick shifted just like any 833 trans. I think he mentioned that 2300 price to me also. He also said they came in second place for best new product at SEMA.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: Hemi_Joel] #517310
11/06/09 04:08 PM
11/06/09 04:08 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
I'll break it.......
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: LAR_414] #517311
11/06/09 04:17 PM
11/06/09 04:17 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: BBLM23] #517312
11/06/09 04:23 PM
11/06/09 04:23 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If that thing is a bolt in in an A body SIGN ME UP ... the configuration in the link looks like E body
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: JohnRR] #517313
11/06/09 06:40 PM
11/06/09 06:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
That shifter set-up looks like it could be the Achilles heel for street use and strips with dust covered pits.Other than that I like the look of it and it looks like you wouldn't need much fabrication to install it in any car.
Gus
64 Plymouth Savoy
Dana 60
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: fourgearsavoy] #517314
11/06/09 07:34 PM
11/06/09 07:34 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'm pretty stoked on this. I was soooo close to pulling the trigger on a much more expensive aftermarket 4-speed until I saw this. I'd think the shifter could be handled with a dust boot of some sort. I'd be amazed if they left it open to the elements.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: Jeremiah] #517315
11/06/09 08:19 PM
11/06/09 08:19 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Wonder what the gear ratios are???
the Tremec 1 is too deep and the 1-2 is a little wide, I could go for a close to even spread 4 speed with a .8 od.
Something like:
2.56
1.92
1.28
WIZE
In Car:
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: LAR_414] #517316
11/06/09 09:14 PM
11/06/09 09:14 PM
Portland, Or.
Bee4spd Offline
Bee4spd  Offline
Portland, Or.
That is pretty cool. I don't see the $2300 happening, but it would be sweet if it were true. It looks from the background in the main picture that the shifter is mobile and that there is a short shaft version. I think I would buy it if the price is as speculated.
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: LAR_414] #517317
11/06/09 09:18 PM
11/06/09 09:18 PM
IMGTX Offline
IMGTX  Offline
Sweet
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: IMGTX] #517318
11/07/09 08:09 AM
11/07/09 08:09 AM
pa
572charger Offline
572charger  Offline
pa
i'd break it too!! now were was that g-force on racing junk !!! ahhahahahaha
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: New MOPAR 5 speed from McLeod!!!!!!! [Re: 572charger] #517319
11/07/09 08:36 AM
11/07/09 08:36 AM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
there is a vidio here with some info on it plus some more pics http://www.stangtv.com/forum/mcleod-hits-high-gear-their-new-6035.html
