exhaust evac system
#516763
11/05/09 03:52 PM
11/05/09 03:52 PM
Posts: 7,506 Az
Crizila
Az
Looking at installing an exhaust evacuation system. I run a short extension on to my 3" collectors and I want to mount the evac tubes per the attached pic. Is this the correct way to mount the tubes ( flush to the pipe ), or should the protrude in to the pipe some distance? Thanks, John
Fastest 300
Re: exhaust evac system
[Re: 70dusterjohn]
#516765
11/05/09 04:39 PM
11/05/09 04:39 PM
Posts: 7,506 Az
Crizila
Az
Ok, Thanks John. I noticed the Moroso system has a cut in the evac tube as you mentioned. I bought the Summit system that is indentical to the Moroso system except there is no cut in the tube?
Fastest 300
[Re: Crizila]
#516766
11/05/09 04:45 PM
11/05/09 04:45 PM
Posts: 535 Ohio
racerAL
Ohio
that looks like the angle you want it in at...try to get the tip of the evac. tube in the middle(center) of the exhaust pipe..also it should be turned around so the opening of the evac. tube is facing towards the rear of the car or going with the exhaust..the exhaust should pull the crank case gasses out of the evac. tube and exit out the exhaust.
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: Crizila]
#516774
11/05/09 08:28 PM
11/05/09 08:28 PM
Posts: 7,506 Az
Crizila
Az
Any other opinions before I fire up the mig welder?
Fastest 300
[Re: Crizila]
#516777
11/05/09 08:38 PM
11/05/09 08:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The first pic will give you a greater vac... I did a lot of testing this in the exhaust lab for Chrysler
[Re: racerAL]
#516780
11/06/09 06:30 AM
11/06/09 06:30 AM
Posts: 1,001 Clinton Township, Michigan
Dartin
... ...thats the look your huntin for..imo.
X3 on the first pic. Mine are installed this way and work awesome.
