exhaust evac system
#516763
11/05/09 03:52 PM
11/05/09 03:52 PM
Posts: 7,506 Az
Crizila
Az
Looking at installing an exhaust evacuation system. I run a short extension on to my 3" collectors and I want to mount the evac tubes per the attached pic. Is this the correct way to mount the tubes ( flush to the pipe ), or should the protrude in to the pipe some distance? Thanks, John
Fastest 300
Re: exhaust evac system
[Re: 70dusterjohn]
#516765
11/05/09 04:39 PM
11/05/09 04:39 PM
Posts: 7,506 Az
Crizila
Az
Ok, Thanks John. I noticed the Moroso system has a cut in the evac tube as you mentioned. I bought the Summit system that is indentical to the Moroso system except there is no cut in the tube?
Fastest 300
[Re: Crizila]
#516766
11/05/09 04:45 PM
11/05/09 04:45 PM
Posts: 535 Ohio
racerAL
Ohio
that looks like the angle you want it in at...try to get the tip of the evac. tube in the middle(center) of the exhaust pipe..also it should be turned around so the opening of the evac. tube is facing towards the rear of the car or going with the exhaust..the exhaust should pull the crank case gasses out of the evac. tube and exit out the exhaust.
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: Crizila]
#516774
11/05/09 08:28 PM
11/05/09 08:28 PM
Posts: 7,506 Az
Crizila
Az
Any other opinions before I fire up the mig welder?
Fastest 300
[Re: Crizila]
#516777
11/05/09 08:38 PM
11/05/09 08:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The first pic will give you a greater vac... I did a lot of testing this in the exhaust lab for Chrysler
[Re: racerAL]
#516780
11/06/09 06:30 AM
11/06/09 06:30 AM
Posts: 998 Clinton Township, Michigan
Dartin
... ...thats the look your huntin for..imo.
X3 on the first pic. Mine are installed this way and work awesome.
[Re: kruger]
#516784
11/06/09 10:32 AM
11/06/09 10:32 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Heres some info Crizila:Exhaust Evac Install w/diagram pic http://docs.google.com/gview?a=v&q=c...F9plYXEE50sk4pw
The first picture is the right angle but you have it too far down. The second picture won't do anything. The top of the angled portion should be within 1/8th inch of the top of the tube. Also, like was mentioned, it would have been much better to put it in the header itself and not the extensions.
[Re: Big B]
#516786
11/06/09 12:24 PM
11/06/09 12:24 PM
Posts: 7,506 Az
Crizila
Az
Based on your discription of the angle tube depth ( 1/8" off the wall) Brian, sounds like there is a low pressure area along the pipe wall verses in the middle of the pipe? I have room issues trying to mount the tubes in the header collector - not to mention I aint drilling holes in my new headers. I do run the short extensions at the track. I also have a very minimal exhaust system ( 3" pipe to large chambered mufflers that dump in front of the axle ). I only run this system for street T&T or running the car in the garage - want to maintain my "good neighbor" relationship . I was thinking about running my existing PCV system ( slight negative pressure at idle only )along with the exhaust evac system. Any thoughts on that?
Fastest 300
