Ebay HEI distributors?
#516380
11/05/09 12:30 AM
11/05/09 12:30 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Ok, laugh it up now if i made a big mistake for buying one, but i figured i would give one a try, its made by Procomp i'm sure, its for a SB, they have 2 styles, i went with the large cap unit with everything in one for 72.00 bucks, it takes all GM parts, so if something goes bad, i can replace it with GM stuff, it comes with an adj. canister, my question is, is anyone useing one of these, any feedback, i'm hopeing it clears the firewall in the Dart.
Re: Ebay HEI distributors?
[Re: minivan]
#516382
11/05/09 02:08 AM
11/05/09 02:08 AM
Posts: 3,547 stratford,ontario,canada
JD340
If it looks anything like this, you should be pretty happy with it. We finally put one in Dad's 69 Dart 318 this summer. Starts better, easy install,stable timing, and 12 volts to coil! ![](/ubbthreads/images/graemlins/boogie.gif) When I get a couple bucks together, the Aspen is gonna get one too. ![](/ubbthreads/images/graemlins/thumbs.gif)
Nothing to see here. Carry on.
[Re: joedust451]
#516384
11/05/09 02:12 AM
11/05/09 02:12 AM
Posts: 27,484 So Cal
autoxcuda
So Cal
Is the seller in Santa Barbera or Goleta, CA ???
I know a guy that just got some of those in and sells them at Pomona and Long Beach swap meets.
[Re: autoxcuda]
#516385
11/05/09 09:40 AM
11/05/09 09:40 AM
joedust451
super gas
super gas
Branson, Mo.
They are in Iowa. Now i feel alittle better about getting one, its not the one in the pics, its another larger style, just like a GM HEI, just has the mopar shaft, i hope it clears the firewall, if not, he said i can return it for the other unit.
That one pictured, does it need an external coil? The one i'm getting has the coil built in.
[Re: joedust451]
#516386
11/05/09 10:02 AM
11/05/09 10:02 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
External. You can see the coil terminal on the cap in the first pic. OEM GM had the coil in the cap.
[Re: joedust451]
#516387
11/05/09 12:50 PM
11/05/09 12:50 PM
Posts: 7,506 Az
Crizila
Az
Been running one for about 3 years now ( mine is a D.U.I unit ). Works great. No problems.
Fastest 300
[Re: derekeh]
#516390
11/05/09 06:49 PM
11/05/09 06:49 PM
joedust451
super gas
super gas
Branson, Mo.
I was about to post a thread asking about these too lol. I didnt know you could get one with a built in coil... would it be good for a mild 340 build?
I'll be getting it tomorrow, i will post pics, from what i gather, it looks just like a GM HEI, big cap, coil on top, i just hope it clears the firewall.
[Re: joedust451]
#516391
11/05/09 06:54 PM
11/05/09 06:54 PM
I think the ones with the big caps/coil may create a problem with the firewall but I got the one with the internal electronics for my 64. Runs good but I did notice the rotor points to a different location than stock and I had to move the wires on the cap.
[Re: Crizila]
#516394
11/06/09 01:20 AM
11/06/09 01:20 AM
joedust451
super gas
super gas
Branson, Mo.
Pics would be good. I would be interesterd in what coil and module ( I'm sure it will be a 4 pin ) are in it - manufacturer / brand name. Would be very interested in the Primary and secondary ohm readings on the coil. Is it a one wire hook up?
He said one goes to 12v & the other to ground on this unit.
[Re: minivan]
#516396
11/06/09 02:40 AM
11/06/09 02:40 AM
joedust451
super gas
super gas
Branson, Mo.
WOW, those DUI distrabators are pretty spendy.. Seems like I looked at them but was put off by the price.....
DUI= "Driving under the influence", that can get pretty pricey ![](/ubbthreads/images/graemlins/laugh2.gif)
BTW, whats a "distrabator" ![](/ubbthreads/images/graemlins/shock.gif)
[Re: joedust451]
#516397
11/06/09 02:41 AM
11/06/09 02:41 AM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
What we call distributors after a couple of beers.......
