Re: Can I throw a 6 pack intake on any 440?
[Re: ScottSmith_Harms]
#514819
11/03/09 04:16 PM
11/03/09 04:16 PM
DaytonaTurbo
Manitoba, Canada
That post addressed everything except what I'm about
I think the number of guys on here who're concerned at all about stock heads is dwindling rapidly. With the affordability of aftermarket heads these days, it's hard to justify putting work into stock heads. If you can't afford aftermarket, IMO the OP would be best off just working with the heads he has for now. Meaning clean them up, maybe a set of new valve seals and springs and run em until he's got the dough for aftermarket.
[Re: R70RUNNER]
#514822
11/03/09 06:01 PM
11/03/09 06:01 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
waiting for the over the 915's flow as well....comment
906's and 915's share the same port shape , so ...
[Re: rbstroker]
#514824
11/03/09 08:21 PM
11/03/09 08:21 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Wasn't there an issue at one time about the six pack manifolds being factory machined at the wrong angle for complete sealing against the heads?
Lot's of variables on the sealing issue...That's why they put that little slip of paper in the box with the new intakes telling you to check the mating surfaces before the final install....
