Page 3 of 3 1 2 3
Re: 11 seconds with a 416 [Re: 73cuda340] #514567
11/20/09 07:58 PM
11/20/09 07:58 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Would any of the cams in the [Email]240@50[/Email] range still be streetable? I want it to have a nice choppy idle but at the same time I dont want to lose a lot of low end torque.
A local guy has a Hughes 237/242 @ .050, .548/.555 hydraulic in his 408. It hits a good lick and runs 7 teens in a 3200# Dart Sport. IIRC the motor is about 9.8-1 on the compression.
Re: 11 seconds with a 416 #514568
11/20/09 08:03 PM
11/20/09 08:03 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
The Lunati 60405 has .533/.552 lift with .242 int .252 ext at 50 degrees..and is very streetable and in my duster ran consistent 11.0's...
Just order the same cam last week for my 340, what size motor did you have the cam in
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: 11 seconds with a 416 [Re: 65signet] #514569
11/21/09 05:25 AM
11/21/09 05:25 AM
Right now its in my stock stroke 360 running a best of 11.79..
Re: 11 seconds with a 416 [Re: 65signet] #514570
11/22/09 06:43 PM
11/22/09 06:43 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
You can find something better than comp, there selection for mopar is not good and most of there cams have to much duration for a good street strip car.
Whats wrong with the comp cams? Ive always been a fan of them and always had good results.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 11 seconds with a 416 [Re: 73cuda340] #514571
11/22/09 07:40 PM
11/22/09 07:40 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Comp Cams has about 10,000 lobes they can grind on a SBM cam.
Just because they only list 30 in their catalog doesn't mean you
can't get what you need.
Re: 11 seconds with a 416 [Re: S/ST 3040] #514572
11/23/09 05:31 PM
11/23/09 05:31 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I got one of there off the shelf cams and had to take 40 thou off the front journal so it would fit in the block correctly.
Re: 11 seconds with a 416 [Re: 65signet] #514573
11/23/09 06:36 PM
11/23/09 06:36 PM
S/ST 3040 Offline
S/ST 3040  Offline
I would have sent it back! Accidents happen. Stuff gets out the door.
Re: 11 seconds with a 416 [Re: S/ST 3040] #514574
11/23/09 06:43 PM
11/23/09 06:43 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I have the comp 275hl in my 408. It sounds and drives pretty good. It definitely sounds cammed but isn't the rumpetiest, I can idle below 1000 rpm. Power comes on good in the midrange and pulls steady to 5-6k but no explosive cam 'turn on' in the upper rpms like a more radical cam.
I think I could have gone with the 285hl and gotten some more horses, but for a hot daily driver I am satisfied.
http://www.youtube.com/watch?v=iyU83fpak4A
Kevin
Re: 11 seconds with a 416 [Re: S/ST 3040] #514575
11/23/09 07:16 PM
11/23/09 07:16 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
I did send it back and they did not take enough off, it took 2 weeks with shipping that i paid for so i had it done locally, they could not figure out way it did not fit, maybe it was for a chevy same grind.
Page 3 of 3 1 2 3
