Re: Ring & Pinion pattern help needed PLEASE!
[Re: Quicksilver440]
#513965
11/03/09 03:56 AM
11/03/09 03:56 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Currently at: .028" shim behind driver side carrier bearing .090" shim behind passenger side carrier bearing .045" shim behind the big pinion bearing cup .057" shim between the pinion and small bearing Backlash is at .008" Attempt 21 - Moved the carrier away from the pinion by .007. Backlash now .008" What says the hive mind? Go with it or fiddle around some more??? Drive ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3823.jpg) Coast ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3824.jpg) Both ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3826.jpg)
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: Chris'sBarracuda]
#513968
11/03/09 08:27 AM
11/03/09 08:27 AM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Man am I glad I have a 9".. ![](/ubbthreads/images/graemlins/eeek.gif)
Looks like too much work.. ![](/ubbthreads/images/graemlins/laugh2.gif)
Keep at it, you're getting close.. ![](/ubbthreads/images/graemlins/thumbs.gif)
Chris..
X2
But when I have to work on my 70 Cuda its a different story, have a Dana ![](/ubbthreads/images/graemlins/bawling.gif)
[Re: Bob_Coomer]
#513971
11/03/09 11:37 PM
11/03/09 11:37 PM
67Charger
Erda, UT
Should I keep chasing it? What direction next? I'd guess a little thinner pinion shim, maybe .005" more out... What backlash should I be shooting for?
[Re: RussW]
#513974
11/04/09 01:08 AM
11/04/09 01:08 AM
67Charger
Erda, UT
Looks like you're goin crazy and this is just my opinion.
I'd go back to # 21 set the BL at .10 and run it .
What brand gear is that ??
I'm still at #21... Backlash is at .008. These are brand new Strange gears and new bearings. If anything I was going to pull a bit of pinion shim out, but if deep is the recommended setup...???
[Re: 67Charger]
#513975
11/04/09 01:31 AM
11/04/09 01:31 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I am a big fan of a proper pattern, i hate noise from the rear and the vibration it brings with it.
I see the drive and coast are now on the same part of the gear so you are real close. Can you have someone with a lot of pressure hold a prybar between the case and the spool while your turning it so it cleans up the lead and gives us a better look.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#513976
11/04/09 01:36 AM
11/04/09 01:36 AM
67Charger
Erda, UT
Lemme see what I can do...
[Re: 67Charger]
#513978
11/04/09 01:57 AM
11/04/09 01:57 AM
bigtimeauto
Trophy Winner
Trophy Winner
I think the pinion is still in to deep. BUT before you change it bring the back lash down a couple of thou to .006-.007 and take a look. When doing rears you usually need to move the pinion shim .003 to see a difference. I wish i could stay up and help you but i'm east coast!. good luck here i just found a link on line of pics to help you out: http://www.precisiongear.com/pgtechpatterns.htm
[Re: 67Charger]
#513979
11/04/09 03:01 AM
11/04/09 03:01 AM
67Charger
Erda, UT
Pulled .005 pinion shim out, putting me at .040 pinion shim, .052 preload shim. Backlash was at .007, now at .009. Drive ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3830.jpg) Coast ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3831.jpg)
[Re: Cab_Burge]
#513981
11/04/09 01:18 PM
11/04/09 01:18 PM
bigtimeauto
Trophy Winner
Trophy Winner
like above bring the backlash down and i think you will be good.
[Re: bigtimeauto]
#513982
11/04/09 02:07 PM
11/04/09 02:07 PM
67Charger
Erda, UT
I just called Strange, and they said .005 - .009, with even .004 being OK since everything is new. I'll swap .004 carrier shim which should move me about .003.
We'll try again after work.
Thanks for all the help guys!
[Re: 67Charger]
#513983
11/05/09 01:14 AM
11/05/09 01:14 AM
67Charger
Erda, UT
Attempt 23 - Moved the carrier into the pinion by .004. Backlash is now .006. I'm just about "done" with this thing... in one sense of the word anyway. Drive ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3833.jpg) Coast ![](http://img.photobucket.com/albums/v227/67Charger/IMG_3834.jpg)
