Page 2 of 5 1 2 3 4 5
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513964
11/03/09 02:55 AM
11/03/09 02:55 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
.004 is too tight imho....I would go back to where you were at setup 19 and move the pinion depth in by .007 which also decreases backlash (from your .017 reading) and that should move the drive pattern slightly towards the toe, and the coast pattern slightly towards the heel.
Maybe I'm wrong....
Re: Ring & Pinion pattern help needed PLEASE! [Re: Quicksilver440] #513965
11/03/09 03:56 AM
11/03/09 03:56 AM
Erda, UT
67Charger Offline OP
Erda, UT
Currently at:
.028" shim behind driver side carrier bearing
.090" shim behind passenger side carrier bearing
.045" shim behind the big pinion bearing cup
.057" shim between the pinion and small bearing
Backlash is at .008"
Attempt 21 - Moved the carrier away from the pinion by .007. Backlash now .008" What says the hive mind? Go with it or fiddle around some more???
Drive
Coast
Both
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513966
11/03/09 06:50 AM
11/03/09 06:50 AM
Arizona
Chris'sBarracuda Offline
Arizona
Man am I glad I have a 9"..
Looks like too much work..
Keep at it, you're getting close..
Chris..
Re: Ring & Pinion pattern help needed PLEASE! [Re: Chris'sBarracuda] #513967
11/03/09 08:21 AM
11/03/09 08:21 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
.004 will be fine i set mine at .oo3 with no issues.I,ve had some guys tell me its to tight ,but i have found it makes the gears last longer for me.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Ring & Pinion pattern help needed PLEASE! [Re: Chris'sBarracuda] #513968
11/03/09 08:27 AM
11/03/09 08:27 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Chris..
X2
But when I have to work on my 70 Cuda its a different story, have a Dana
Re: Ring & Pinion pattern help needed PLEASE! [Re: B1KILLER] #513969
11/03/09 10:33 AM
11/03/09 10:33 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Try .030 behind the inner pinion bearing, and reset back lash and pattern
IMO you want the largest foot print across the ring gear as possible and still have the correct back lash..
Re: Ring & Pinion pattern help needed PLEASE! [Re: Bob_Coomer] #513970
11/03/09 10:35 AM
11/03/09 10:35 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Not a very good pic but you can see my foot print.
Re: Ring & Pinion pattern help needed PLEASE! [Re: Bob_Coomer] #513971
11/03/09 11:37 PM
11/03/09 11:37 PM
Erda, UT
Erda, UT
Should I keep chasing it? What direction next? I'd guess a little thinner pinion shim, maybe .005" more out... What backlash should I be shooting for?
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513972
11/03/09 11:53 PM
11/03/09 11:53 PM
Dan, are these new gears? If so set them up as tight on the backlash as the manufacturer suggests, they will wear in some and the backlash will increase some on the first hard hit I like to shoot for the least amount of backlash as I can get away with(manufacturer suggested minimum) and get the pinion depth as deep as possible that still looks good Richmond recommends setting the pinion depth .010 deeper on a drag race gear set up than the depth printed on the back of there pinion gears.
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513973
11/03/09 11:53 PM
11/03/09 11:53 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Looks like you're goin crazy and this is just my opinion.
I'd go back to # 21 set the BL at .10 and run it .
What brand gear is that ??
Re: Ring & Pinion pattern help needed PLEASE! [Re: RussW] #513974
11/04/09 01:08 AM
11/04/09 01:08 AM
Erda, UT
Erda, UT
I'm still at #21... Backlash is at .008. These are brand new Strange gears and new bearings. If anything I was going to pull a bit of pinion shim out, but if deep is the recommended setup...???
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513975
11/04/09 01:31 AM
11/04/09 01:31 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I am a big fan of a proper pattern, i hate noise from the rear and the vibration it brings with it.
I see the drive and coast are now on the same part of the gear so you are real close. Can you have someone with a lot of pressure hold a prybar between the case and the spool while your turning it so it cleans up the lead and gives us a better look.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ring & Pinion pattern help needed PLEASE! [Re: bigtimeauto] #513976
11/04/09 01:36 AM
11/04/09 01:36 AM
Erda, UT
Erda, UT
Lemme see what I can do...
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513977
11/04/09 01:49 AM
11/04/09 01:49 AM
Erda, UT
Erda, UT
Drive
Coast
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513978
11/04/09 01:57 AM
11/04/09 01:57 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I think the pinion is still in to deep. BUT before you change it bring the back lash down a couple of thou to .006-.007 and take a look.
When doing rears you usually need to move the pinion shim .003 to see a difference.
I wish i could stay up and help you but i'm east coast!. good luck here i just found a link on line of pics to help you out:
http://www.precisiongear.com/pgtechpatterns.htm
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513979
11/04/09 03:01 AM
11/04/09 03:01 AM
Erda, UT
Erda, UT
Pulled .005 pinion shim out, putting me at .040 pinion shim, .052 preload shim. Backlash was at .007, now at .009.
Drive
Coast
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513980
11/04/09 12:23 PM
11/04/09 12:23 PM
What does Strange want for the minimum backlash? I would set it at that and run it with no change to the pinion depth with this pattern. BTW, I did buy a Pro Parts pinion depth tool yyears ago and use that for setting the pinion depth, not just the pattern
Re: Ring & Pinion pattern help needed PLEASE! [Re: Cab_Burge] #513981
11/04/09 01:18 PM
11/04/09 01:18 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
like above bring the backlash down and i think you will be good.
Re: Ring & Pinion pattern help needed PLEASE! [Re: bigtimeauto] #513982
11/04/09 02:07 PM
11/04/09 02:07 PM
Erda, UT
Erda, UT
I just called Strange, and they said .005 - .009, with even .004 being OK since everything is new. I'll swap .004 carrier shim which should move me about .003.
We'll try again after work.
Thanks for all the help guys!
Re: Ring & Pinion pattern help needed PLEASE! [Re: 67Charger] #513983
11/05/09 01:14 AM
11/05/09 01:14 AM
Erda, UT
Erda, UT
Attempt 23 - Moved the carrier into the pinion by .004. Backlash is now .006.
I'm just about "done" with this thing... in one sense of the word anyway.
Drive
Coast
