Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513676
01/10/10 11:52 PM
01/10/10 11:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
FYI,
67's had lower compression pistons and closed chamber heads
68-71 had higher compression pistons with open chamber heads. So, at the end of the day the net results for final compression was about the same.
Adding gears, a higher stall speed converter, and a stout cam will make the single plane work better for sure, they just come on later than a dual plane, less low end, more top end so you have to accomodate that.
Re: Jaybirds 67 Belvedere [Re: ScottSmith_Harms] #513677
01/11/10 09:01 PM
01/11/10 09:01 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Sweet project. Talk Jaybird into some headers.
Re: Jaybirds 67 Belvedere [Re: 67Satty] #513678
01/16/10 09:45 PM
01/16/10 09:45 PM
Seattle Wa
PowerWagonDude Offline OP
Seattle Wa
Jay workin on the 440
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513679
01/16/10 09:46 PM
01/16/10 09:46 PM
Seattle Wa
Seattle Wa
Pretty clean old motor
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513680
01/16/10 09:47 PM
01/16/10 09:47 PM
Seattle Wa
Seattle Wa
New MP cam is installed 284/484
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513681
01/23/10 10:35 PM
01/23/10 10:35 PM
Seattle Wa
Seattle Wa
Car waiting for the motor
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513682
01/23/10 10:37 PM
01/23/10 10:37 PM
Seattle Wa
Seattle Wa
Crazy looking motor almost ready
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513683
01/31/10 10:33 PM
01/31/10 10:33 PM
Seattle Wa
Seattle Wa
Motor meets car
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513684
01/31/10 10:34 PM
01/31/10 10:34 PM
Seattle Wa
Seattle Wa
Using the Dodge truck to hoist the 440
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513685
01/31/10 10:35 PM
01/31/10 10:35 PM
Seattle Wa
Seattle Wa
Souped up 440 almost in
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513686
01/31/10 10:40 PM
01/31/10 10:40 PM
Seattle Wa
Seattle Wa
Finally it is in the Belvedere GTX clone. We got it running shortly after this picture. It sounds great with the new MP cam. Jaybird says it has alot more power with the new intake with one inch riser, 284/484 cam, hi-stall converter, flex fan, and removed the heat riser flapper from inside the exhaust manifold. It also got a new steering box
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513687
01/31/10 11:11 PM
01/31/10 11:11 PM
Missouri
P
petty43 Offline
petty43  Offline
P
Missouri
Purple doesn't match too good. Unless it hauls.....
Looks good congrats.
1968 Satellite RR Copy Cat My Fleet
Re: Jaybirds 67 Belvedere [Re: petty43] #513688
02/27/10 09:01 PM
02/27/10 09:01 PM
Seattle Wa
Seattle Wa
The purple monster is in and running well!
Re: Jaybirds 67 Belvedere [Re: PowerWagonDude] #513689
11/12/10 09:37 PM
11/12/10 09:37 PM
Seattle Wa
Seattle Wa
Its got a new gas tank now and runs pretty good!
http://www.youtube.com/watch?v=IWEvMGPoKz0&feature=related
