Page 2 of 4 1 2 3 4
Re: Mopar Commando heads [Re: S/ST 3040] #513029
11/05/09 08:35 AM
11/05/09 08:35 AM
BPE Offline
BPE  Offline
Vic,
Thanks for the pictures. Technical info is always good.
Re: Mopar Commando heads [Re: BPE] #513030
11/05/09 06:20 PM
11/05/09 06:20 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
OK so here's the same port with the pushrod pinch opened up
from .780" to .965".....typical of a decent port match.
.100"_____62.1
.200"____125.3
.300"____181.5
.400"____220.6
.500"____235.3
.550"____239.0*
Backs up over .550"
* slight turbulance
Re: Mopar Commando heads [Re: S/ST 3040] #513031
11/05/09 06:26 PM
11/05/09 06:26 PM
S/ST 3040 Offline
S/ST 3040  Offline
Again, same port as last posted with the Magnum stud boss
cut out of the roof.
.100"_____63.1
.200"____126.3
.300"____186.5
.400"____229.3
.500"____246.5*
.550"____249.0*
.600"____250.1*
.650"____249.0*
.700"____242.0
* slight turbulance
Re: Mopar Commando heads [Re: S/ST 3040] #513032
11/06/09 09:03 AM
11/06/09 09:03 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I love seeing info like this, hard numbers for incremental changes.
Thanks Vic.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Mopar Commando heads [Re: Rapid340] #513033
11/06/09 10:10 AM
11/06/09 10:10 AM
S/ST 3040 Offline
S/ST 3040  Offline
Oh cool......there's 2 of you.
I thought I'd put some stuff up that pertained to the original
poster's question. It's a waste of my time to clean the head
and flow it after every incremental change.
I'll just finish these up and move on to the next job.
Re: Mopar Commando heads [Re: S/ST 3040] #513034
11/06/09 10:50 AM
11/06/09 10:50 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I thought the information was great. Please continue and show the end results.
Getting old just means you were smarter than some and luckier than others.
Re: Mopar Commando heads [Re: flatiron] #513035
11/06/09 10:54 AM
11/06/09 10:54 AM
NY usa
540challenger Offline
NY usa
do you have the numbers of the CC's of the combustion chamber before and after port work by any chance???
Re: Mopar Commando heads [Re: S/ST 3040] #513036
11/06/09 12:45 PM
11/06/09 12:45 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
thanks i apreciate learning alitle more this way
Re: Mopar Commando heads [Re: 1Fast340] #513037
11/06/09 02:23 PM
11/06/09 02:23 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
Keep at it Vic!
Ryan
Re: Mopar Commando heads [Re: S/ST 3040] #513038
11/07/09 12:13 AM
11/07/09 12:13 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
.100"_____62.1
.200"____125.3
.300"____181.5
.400"____220.6
.500"____235.3
.550"____239.0*
Backs up over .550"
* slight turbulance
so are these numbers a net gain..after mods.?.
or a net loss...?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Mopar Commando heads [Re: S/ST 3040] #513039
11/07/09 12:20 AM
11/07/09 12:20 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Vic I really appreciate all the great info you give!
Please dont stop shareing because people are idiots.
Re: Mopar Commando heads [Re: HEMIDARTS] #513040
11/07/09 01:58 AM
11/07/09 01:58 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I missed out on some idiots
I like thease heads and have a set of the aluminum magnums I am planning on running so I apreciate some real world info like this
Re: Mopar Commando heads [Re: HotRodDave] #513041
11/07/09 09:49 AM
11/07/09 09:49 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I am not going to ruin this thread.
All i am saying is i dont want to see good info
disapear because of people being negative.
Re: Mopar Commando heads [Re: HEMIDARTS] #513042
11/07/09 10:50 AM
11/07/09 10:50 AM
who's being negative?
i have sets of these..large ports
havent touched them yet..
if someone has data..by all means..
i dont have all the flow charts side by side.
i was asking if his opinion was that moving or removing the pushrod pinch was worth it..or not.?
I assume the "Idiot" question was directed at me..since iam the only one asking questions..or commenting on technical aspects..
I am no Idoit..
cheapst
[image][/image]
Re: Mopar Commando heads [Re: cheapstreetdustr] #513043
11/07/09 02:16 PM
11/07/09 02:16 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
no it was not directed at you. i would have said your name if it was directed at you.
Re: Mopar Commando heads [Re: HotRodDave] #513044
11/07/09 03:01 PM
11/07/09 03:01 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Must of got edited? I did not read anything bad , then boom! Vic is mad for some reason with nothing to explain why.
Re: Mopar Commando heads [Re: Dos Snails] #513045
11/07/09 06:26 PM
11/07/09 06:26 PM
S/ST 3040 Offline
S/ST 3040  Offline
For all the people who currently own a set of these Small Port Commandos or the aluminum
Magnums...........there seems to be a problem with making these thing flow any air.
Look at this picture. Apparently the thought was to run these exclusively with a hydraulic roller
cam as the pushrod holes are .205" further from the manifold surface than my nasty old OEM heads,
which incidentally, outflow these paper weights by 28 CFM.
By them being machined as such, places them deeper in the port. Which makes the transition
into the curved wall much more abrupt, upsetting the airflow in a bad way.
Without relocating the pushrod, I don't see them being a candidate for a serious race application.
Flow is 251.3 @ 500" right now.
Re: Mopar Commando heads [Re: S/ST 3040] #513046
11/07/09 06:58 PM
11/07/09 06:58 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Whats the deal on the exhaust port, I heard they were a fair amount too tight?
Re: Mopar Commando heads [Re: emarine01] #513047
11/07/09 07:09 PM
11/07/09 07:09 PM
S/ST 3040 Offline
S/ST 3040  Offline
I think the engineer who came up with these might have stayed on from the AMC buy-out.
Him and his buddies probably got a good laugh out of this when Mopar approved it.
Re: Mopar Commando heads [Re: S/ST 3040] #513048
11/07/09 07:15 PM
11/07/09 07:15 PM
S/ST 3040 Offline
S/ST 3040  Offline
Honestly, it's not a bad port. At least it has a short turn.
The Large Port Commandos have the dual W-2 bolt pattern.
SP version is a mis-match to an OEM header. There's not
much you can do but, weld them up or use W-2 headers.
Page 2 of 4 1 2 3 4
