how to idenify a 440 steel crank? #512776
10/31/09 09:10 PM
10/31/09 09:10 PM
Indiana
jef408 Offline OP
jef408  Offline OP
Indiana
someone gave me a big block crank shaft and said it was a 440 steel crank,im wondering how to tell if its a 440 crank and how to tell if its a steel piece or if its a cast unit,need to know how to tell the diff!thanks.
Re: how to idenify a 440 steel crank? [Re: jef408] #512777
10/31/09 09:16 PM
10/31/09 09:16 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Forged will have a wide parting line, Cast will have a narrow parting line. Then you have to measure main bearing sizes to make sure it is an RB crank.
Sheldon
Re: how to idenify a 440 steel crank? [Re: RUNCHARGER] #512778
10/31/09 09:20 PM
10/31/09 09:20 PM
Indiana
jef408 Offline OP
jef408  Offline OP
Indiana
what do you mean by wide parting line?and how wide should it be?
Re: how to idenify a 440 steel crank? [Re: jef408] #512779
10/31/09 09:22 PM
10/31/09 09:22 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Cast crank parting line... 1/8" or thereabouts...
Steel crank parting line... 3/8" + or thereabouts...
CrAzYMoPaRGuY
Re: how to idenify a 440 steel crank? [Re: CrAzYMoPaRGuY] #512780
10/31/09 09:44 PM
10/31/09 09:44 PM
Canada
Canada
Ooohh look at the pic I found
CrAzYMoPaRGuY
Re: how to idenify a 440 steel crank? [Re: CrAzYMoPaRGuY] #512781
11/01/09 01:16 AM
11/01/09 01:16 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
From the Tech Archive:
Crank Q's
Re: how to idenify a 440 steel crank? [Re: jef408] #512782
11/01/09 06:19 AM
11/01/09 06:19 AM
w it on its side make a magic marker mark on the top of a main journal and a mark on top of an adjacent rod journal then measure the (offset) distance between the 2. Double that figure & that is your stroke. 440 (RB) is 3.750".
Re: how to idenify a 440 steel crank? [Re: RapidRobert] #512783
11/01/09 10:28 PM
11/01/09 10:28 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Wouldn't all early steel 440 cranks have a pilot hole drilled into the rear of the crank?
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: how to idenify a 440 steel crank? [Re: jef408] #512784
11/01/09 11:54 PM
11/01/09 11:54 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
just tap it with a metal object. The forged will sound like a tuning fork..like a ring for 3-4 seconds. The cast will sound like a tin bucket. The cast is also darker, forged are grey. Rounded corners on the throws are a giveaway unless someone knife edged a cast crank.
Re: how to idenify a 440 steel crank? [Re: pishta] #512785
11/02/09 01:44 AM
11/02/09 01:44 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
The forged crank is an ugly piece too, while the casting is fairly prettily machined. And the cast crank will have 440 cast onto one of the counterweights. AND as mentioned, the cast cranks don't have a pilot hole for a manual transmission. Might be one or two out there that do, but I've never found one. Even found a 400 in a mid 70's pickup that had a steel crankshaft because it was in front of a 4 speed. Everything else was standard so I know it wasn't a rebuild.
