Re: Is this carb on backwards?
[Re: Pyper70]
#511386
10/30/09 10:28 AM
10/30/09 10:28 AM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
Mind this is going in a 1968 Charger, 440/ 727....I think those are A-Body linkage but it looks like I am staring at the passenger side #2 cylinder with the throttle linkage over it....
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: stumpy]
#511389
10/30/09 10:43 AM
10/30/09 10:43 AM
Pyper70
Athens, Greece
For some reason the runners look longer to the right side of the picture...
[Re: stumpy]
#511397
10/30/09 06:27 PM
10/30/09 06:27 PM
Pyper70
Athens, Greece
I just like having the answer at my disposal when he approaches me to fix it for him. I'll make sure to charge him extra special for it.
[Re: Mopar1970440]
#511399
10/30/09 08:09 PM
10/30/09 08:09 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
Linkage is odd and problaby wont work good at all..and his transmission is going to burn up.
Only if it's an auto! ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: I go fast]
#511400
10/31/09 08:37 AM
10/31/09 08:37 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
well if you know what you are looking at in that picture the linkage shown is the THROTTLE VALVE LINKAGE for an AUTOMATIC TRANS ...
[Re: JohnRR]
#511401
10/31/09 08:41 AM
10/31/09 08:41 AM
Pyper70
Athens, Greece
Well its a 727....but on my setup 440/727 again, I have the carb adapter hooked up to the throttle cable correctly. I didnt take the picture. I am just puzzled by wanna be mechanics....This is the same mechanic who installed his alternator on right in front of his fuel pump...an inch away from his subframe to "clean up the engine bay"....
Now the guy who is assembling this car is saying he took it from a 73 Charger with a 318...I still don't think he has a kickdown linkage. Its going to be funny when he finds his transmission all over the street here.
[Re: JohnRR]
#511402
10/31/09 08:43 AM
10/31/09 08:43 AM
I go fast
Wilmington,NC
And John,if you look again it is connected as throttle linkage and would work as such but not well. ![](/ubbthreads/images/graemlins/scope.gif)
[Re: I go fast]
#511403
10/31/09 11:28 AM
10/31/09 11:28 AM
JohnRR
Linkage is odd and probably wont work good at all..and his transmission is going to burn up.
Please look again , the factory throttle cable is installed on the linkage in board of the trans linkage. But you are correct if that mess was being used a throttle linkage it would not work well at all .
