1968 roadrunner hood blackout? #51047
01/01/08 03:06 PM
01/01/08 03:06 PM
Anonymous OP
Anonymous OP
can anyone provide info on taping area in center of hood between power bulges in black? is it a rectangle? is it satin black? any photos available? thanks
Re: 1968 roadrunner hood blackout? #51048
01/01/08 06:21 PM
01/01/08 06:21 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
heres a pic of mine
Re: 1968 roadrunner hood blackout? [Re: ademon] #51049
01/01/08 06:35 PM
01/01/08 06:35 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
The line across the back is straight but the front one has a bit of a point to it so it`s not a rectangle.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: 1968 roadrunner hood blackout? #51050
01/02/08 09:13 PM
01/02/08 09:13 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Hope this helps
Re: 1968 roadrunner hood blackout? [Re: TrueTripleX] #51051
01/02/08 09:27 PM
01/02/08 09:27 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Hope this helps
The diagram shows it too straight across the front, here's the best pic of my org painted blackout that I have on hand.
Re: 1968 roadrunner hood blackout? [Re: rrunner] #51052
01/02/08 09:34 PM
01/02/08 09:34 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
bigger
Re: 1968 roadrunner hood blackout? [Re: rrunner] #51053
01/02/08 11:02 PM
01/02/08 11:02 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The front basically follows the contour of the leading edge of the hood, and of the front "scoop" contours. The rear is a straight line, which follows the rear "scoop" contours.
If you lay it out with 1.5" or so masking tape to get a reference, you'll be able to see it.
It's actually a pentastar shape.
Re: 1968 roadrunner hood blackout? [Re: topside] #51054
01/02/08 11:24 PM
01/02/08 11:24 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
What is the distance from the back of the hood to the front point of the blackout? I was going to ask from the front but wasnt sure of a good point to measure from due to the curvature of the front of the hood.
Re: 1968 roadrunner hood blackout? [Re: ksj] #51055
01/03/08 01:43 PM
01/03/08 01:43 PM
Anonymous OP
Anonymous OP
I have some pretty detailed pictures of an untouched hood blackout. I'll dig them up for you.
Re: 1968 roadrunner hood blackout? #51056
01/03/08 07:26 PM
01/03/08 07:26 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
These numbers are measured off an original 68 Road Runner with the Performance Hood Treatment option. The rear of the blackout starts at 2" from the back of the hood as measured from the middle. The forward "peak" of the blackout will measure 32.25" from the same rear of the hood reference. I have measured a few different hoods while reseaching my 68 Runner and the numbers only vary about 1/8". The scoops get painted black and underneath the scoops they had the paint line split across the outer holes.
Hope this helps.
68 Hemi Road Runner
Re: 1968 roadrunner hood blackout? [Re: 68jim] #51057
01/03/08 07:35 PM
01/03/08 07:35 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
Sorry for stealing the thread, Would this be coded on the fender tag, I have a St Louis 68 GTX.
I know some assemlbly plants didnt code this option only if it was deleted.
Re: 1968 roadrunner hood blackout? [Re: hemi4speed] #51058
01/03/08 07:37 PM
01/03/08 07:37 PM
Anonymous OP
Anonymous OP
hopefully these pictures combined with Jim's measurements will help you out!
The black is a bit faded from 40 years of sun haha.
Re: 1968 roadrunner hood blackout? #51059
01/03/08 09:27 PM
01/03/08 09:27 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
THANKSS!
Hopefully this topic will end up in the "Archives" Hint,Hint!
