Ok whats the deal on all these nascar,P/S truck motors?
#509360
10/27/09 09:55 PM
10/27/09 09:55 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
is there a place to get them? they are popping up in everything.... ive seen parts here and there.. but whats the deal on engines...?
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: Ok whats the deal on all these nascar,P/S truck mot
[Re: B1KILLER]
#509362
10/27/09 10:03 PM
10/27/09 10:03 PM
cheapstreetdustr
What is fair coin? $$ and how complete are they? most of you guys are just swapping cams? and getting some type of adapter for a converter? cheapst.
[Re: cheapstreetdustr]
#509363
10/27/09 10:09 PM
10/27/09 10:09 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
I bought mine a year ago, it came from Buffalo, and it came as yoou see inda pics. 10K for 860 hp, not bad. ![](/ubbthreads/images/graemlins/apimp.gif) Their going for less money now.
[Re: scottb]
#509365
10/27/09 10:35 PM
10/27/09 10:35 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I'd like to see a very detailed list of what all it would actually take to make this swap on a torsion bar car. I've considered selling my whole 500" motor and tranny turn key to go this route. Do these engines come turnkey?
I believe I'd need a new motor plate, tranny adapter and a 904 tranny and converter. Probably a set of custom headers. Oil pan? What else?
[Re: scottb]
#509366
10/27/09 10:37 PM
10/27/09 10:37 PM
B1KILLER
BX, CT, FL.
3K front end crank hub trans plate bobs profab make all the parts you need .i never changed cams in my motor still have been 9.42
Bob, is the man, he fabricating my stuff ![](/ubbthreads/images/graemlins/Twocents.gif) Oh it also came with an intake that has been ported., not seen in pics ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: ProSport]
#509367
10/27/09 10:42 PM
10/27/09 10:42 PM
B1KILLER
BX, CT, FL.
Well Its pretty much turn key, when I bought mine it was just freshen up, and dyno.With a 750 produced 860 hp @ 9600 RPM ![](/ubbthreads/images/graemlins/stirthepot.gif)
[Re: scottb]
#509369
10/28/09 06:04 AM
10/28/09 06:04 AM
Posts: 6,840 The Swamp
Sixpak
The Swamp
The motor will not work with rear steer thats why I said 3k front end 1k oil tanks lines trans plate 600 crank hub 150 to 250 custom headers 1k that will get you going down the track
So another 5-6K to make this a workable package - any possibility to fabbing up a wet sump rear steer pan for them?
[Re: B1KILLER]
#509371
10/28/09 08:13 AM
10/28/09 08:13 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I bought mine a year ago, it came from Buffalo, and it came as yoou see inda pics. 10K for 860 hp, not bad. Their going for less money now.
Looks like one of Ritters engines ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Sixpak]
#509372
10/28/09 08:24 AM
10/28/09 08:24 AM
DemonDust
Menomonee Falls
These engines will not work with a wet sump. Rear steer and stock K frame are not compatible with this engine. tubular K frame and front steer required.
One of my nascar connections is selling complete engines minus the intake for 7k.... Wish I could have gotten a deal like this back in the day ![](/ubbthreads/images/graemlins/eeek.gif)
I also made my plate and drew it up on solid works. Now that I know it works and can show it works I will have a few extra made WITH crank spacer and can utilize stock mini starter unlike another vendor out there selling a POS adapter plate (just so you guys know I'm NOT referring to BondoBob) My plate is also compatible with auto or stick bellhousings...
[Re: DemonDust]
#509373
10/28/09 09:47 AM
10/28/09 09:47 AM
Posts: 4,421 in a chair
mopartony
in a chair
Ok Guys, now that you have my gray matter churning and thinking this is a viable option. I thank you but my wallet might be ![](/ubbthreads/images/graemlins/flame.gif) at you guys. I am to assume a detailed list of needed parts would be... Motor plate trans plate/adaptor oil pan headers crank hub what else am I missing? this is assuming you have a carb to oil pan motor. Also no need to change the pan in you have a tube car correct?
#509379
10/28/09 12:01 PM
10/28/09 12:01 PM
cheapstreetdustr
will the compression they utilise ..handle boost? i am thinking...stratospheric numbers with boost. hell ..i dont have a car that could handle it. but i just had to ask.... cheapst
