Re: Ok whats the deal on all these nascar,P/S truck mot
[Re: cheapstreetdustr]
#509380
10/28/09 12:01 PM
10/28/09 12:01 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
The mid plate will accept SB bell. The R5 engine does not have the stock mopar bell pattern. The crank spacer will work for fly wheel or flex plate. I made my spacer with the chevy bolt pattern, then used the spacer as a fixture to drill the flywheel... These engine are right around 12:1 from the shops, probably not a good idea to boost them the way they are....
[Re: ProSport]
#509382
10/28/09 07:12 PM
10/28/09 07:12 PM
DemonDust
Menomonee Falls
So they require straight race gas and a front steer conver$ion, ok I'm out.
E-85.... E-85.... E-85....E-85
[Re: DemonDust]
#509383
10/28/09 07:30 PM
10/28/09 07:30 PM
Posts: 413 Big Island ,VA
JC Childress
Big Island ,VA
They dont have to be a front steer .I know this for a fact. We bought three of these engines from Chip Ganassi. We put one in a Duster. We had a chassis shop relocate the factory steering box rearward a bit and he re-fabbed the drag-link and whatnot to make it work, but it does not have a rack and pinion. It has the factory steering box and it all cleared fine,although, it may possibly be cheaper to put a rack and pinion in. These are neat engines and we make adapters where I work as well. We have even sold one to a Moparts member !
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#509384
10/28/09 07:36 PM
10/28/09 07:36 PM
DemonDust
Menomonee Falls
Do you have any pics of the car?
You must have had to chop the K frame though, when I set my R5 in there was no way it was gonna sit down far enough without removing the some of the K frame or moving the engine way back...
[Re: DemonDust]
#509385
10/29/09 02:13 PM
10/29/09 02:13 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
this was gonna be my next question..will it fit with a modified k member..? i figured there would be more room being a dry sump? cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: scottb]
#509387
10/29/09 02:41 PM
10/29/09 02:41 PM
JC Childress
Big Island ,VA
It can be done "RIGHT " by trimming the factory k-member a good bit and moving the steering box rearward ( and a few other things...I cant say exactly because I dont know exactly...I'm not a chassis man ).
Of course the aftermarket k-member would be super nice as well. Kinda like baking cakes....lots of different recipes and lots of good cakes !
J.C. Childress
(434) 665-9541
