Ideas on cleaning out debris in cowl..... #507466
10/25/09 09:53 PM
10/25/09 09:53 PM
Iowa - a member of the rustbel...
Birdturd Offline OP
Birdturd  Offline OP
So I was stripping out the dash and heater box and was courious are there any good ways of getting to the inside of the cowl? I stuck the shop vac hose in the one side after I got the heater out. Is that the only way I really dont think the cowl on this car NEEDS to be replaced but if I did that sure would make it simple.
Thanks for any help
josh
Re: Ideas on cleaning out debris in cowl..... [Re: Birdturd] #507467
10/25/09 10:15 PM
10/25/09 10:15 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Use a blow nozzle on an air hose, and blow it into the drain holes in the door jambs. You can blow it back and forth from the cowl screens to the drain holes with the air nozzle while leaving the shop vac running up in the vent holes. I do that till it's all out, and use a bottle brush or something similar to knock the rest of the dirt loose.
