I have been working on this car for about 4 years making incremental progress. The idea is to have it look pretty much like an AAR with modern attributes in the areas of suspension and drive train. By "modern" I dont mean transplanting a 5.7 and a 5 spd necessarily, I mean more modern better engineered equipment. Like most projects this has changed slightly since its inception but currently is at the point where I intend to run a 340 (I have a 68 motor), A833 4spd w/OD (Passion), 4 link rear w/coil overs, heavy T bars, tubular upper CA, adj struts, poly bushings, FF stage 3 box, flaming river column, etc. I also intend to run a EFI 6 pac, custom dash, electric windows (all), Corvette C5 seats, etc. Right now I am replacing all of the bad sheet metal and have widened the rear tubs slightly (want to run a 315 rear and 275 front). I having issues aligning the new rear qtr skins currently but like everything with this car it takes some ingenuity to make it work.
