Page 3 of 3 1 2 3
Re: Differences between '67-'69 Barracudas [Re: big-block-dave] #50654
03/19/09 02:00 PM
03/19/09 02:00 PM
USA
big-block-dave Offline
USA
How about fenders? Other than the side marker difference, the '69 has 2 angled tabs welded on the head light bucket to screw the plastic head light trim/bezel to. So if you use a '67-8 fender for a '69 you need these tabs.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: Differences between '67-'69 Barracudas [Re: big-block-dave] #50655
03/19/09 05:06 PM
03/19/09 05:06 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
46. The window lock strip was different in '67 vs. 68+ (for both the front and back windows), in '67 it used a lock strip (like the '66 and the 80's trucks) and in '68+ it was glued in and had stainless steel trim. - The vert used the same style for all 3 years though (lock strip in the bottom & stainless trip around the top)
Actually, the '68-9 are not glued in, they us a rubber gasket but the stainless trim attaches to clips around the perimiter of the opening.
Also, '67s have chrome inside rear view mirrors where '68-9 have matte finish. Other parts are like this.
'69s also come standard with a unique steering wheel. It is three spokes like the '68-9 wood grain wheel but has a colored rim and matching horn button. A '69 Barracuda only part.
'69s also made the fold down rear seat in fastbacks optional and ones that didn't get it didn't have carpet on the floor back there.
'68-9 you could get red plastic wheel well liners on fastbacks and coupes.
'69 Bumper gaurds are located further apart.
'68s have multiple rocker trim or none at all.
Stripes different all three years.
Numbering on speedo different between '68 and '69
'68 A/C vent assembly different (it's padded).
'69 has unique wheel covers available.
Can't think of anything else.
Re: Differences between '67-'69 Barracudas [Re: NicksGarage] #50656
03/19/09 05:09 PM
03/19/09 05:09 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Thought of more...
Disc brakes were standard on '67 383 cars. Optional on '68. Not sure about '69.
Power steering available with 383 in '69.
440 available in '69
'Cuda package in '69
Re: Differences between '67-'69 Barracudas [Re: NicksGarage] #50657
03/20/09 12:02 PM
03/20/09 12:02 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
'69 optional rocker panel molding is different then '67 - '68 rocker molding. I have seen the '69 Barracuda rocker molding on some of the early Dusters.
'69 dash wood grain different then '67-'68 dash wood grain.
Re: Differences between '67-'69 Barracudas [Re: 69Cuda340S] #50658
03/20/09 03:57 PM
03/20/09 03:57 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
This is friggin awesome...
I think it has come to the point that I should organize the different differences into categories - like interior, exterior, engine, trans, etc...
Anything else?
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50659
03/21/09 09:03 AM
03/21/09 09:03 AM
USA
USA
I believe there is a difference with trunk lids. '67 has a frame with a outer skin(like a hood) where '69 has 2 solid skins with the frame as part of the inner skin. I'm not sure which way a '68 is. I have a '68 lid but can't get to it at this time.
Re: Differences between '67-'69 Barracudas [Re: big-block-dave] #50660
03/21/09 09:14 AM
03/21/09 09:14 AM
USA
USA
I DON"T believe the bumper gaurds were further apart on '69 as a earlier post said. If you look here the guards are on the outside but notice in the older pic someone added those TALL guards in the middle and moved the factory guards out!! That is very odd looking with guards on the out side! Maybe this is where the poster saw this without seeing the old pic? I have car #29 survivor with 21K miles and it is correct position as factory.
http://www.mooresmopars.com/modtop1.html
Re: Differences between '67-'69 Barracudas [Re: big-block-dave] #50661
03/21/09 09:24 AM
03/21/09 09:24 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I AGREE! I think the '68/67 lid are different(I know it is for the notch back / vert) not sure about the fastback.
I dont know why they made the change, but I do know my trunk was WAVY as HELL down to the factory metal... I am not sure if it was factory or what, but the hood was not abused, and it was BAD - it still is not right.... after months of work, but it is painted now - at least it is shinny...
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50662
12/03/09 01:37 PM
12/03/09 01:37 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
With all the posts disappearing, I did not want this one to die, so here is a
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50663
12/03/09 06:53 PM
12/03/09 06:53 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
In 69 A bodys the pan that is just forward of the trunk pan changes.67/68 and up to mid 69 has a well in it...mid 69 and up is smooth.
"Long Live Mopars"
Re: Differences between '67-'69 Barracudas [Re: Furyman] #50664
12/05/09 08:08 PM
12/05/09 08:08 PM
USA
USA
I've heard that '67 notchback rear window is smaller than a '68 & '69??????? Therefore the opening is also smaller. How much????
Re: Differences between '67-'69 Barracudas [Re: big-block-dave] #50665
12/05/09 08:16 PM
12/05/09 08:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I don't know about that one. Even with notchbacks I think people convert the rear window molding to the 68/69 stainless style. If it was a different size opening the molding wouldn't work.
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #2219181
12/22/16 05:54 PM
12/22/16 05:54 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Someone was asking me a question and I thought it was in this thread (and it was), just a bump to keep it out of the dead...
Some good stuff...
Re: Differences between '67-'69 Barracudas [Re: 69Cuda340S] #2219947
12/23/16 11:46 PM
12/23/16 11:46 PM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
Originally Posted By 69Cuda340S
Just a little something I have learned about a 69 hood,a dart sport hood is a bolt on and can be spotted right away by the crumple zone.
Any '73 up Dart hood will bolt right on and look correct. I believe the braces under the hood are different.
A little more clarification on the hoods. I have a 73 Dart hood with no crumple zones and another with, and two rusted up 69s. The ribs are the same as far as I can tell and the 73s have the little bolt cutouts for the 69 scoops so my feeling they used the same ribs from 69 other than the adjusting pieces for the hinge and crumple zone latter in the year.? They will bolt on but have no adjustment unless you use the same year hood-hinges, 73-73 and 69-69 . I have a 68 and 69 fb trunk lid and see no difference except trim holes. 69s had two maybe three steering wheels, cheapo three spoke with holes and thin hard rubber band, second same spokes but wood looking band with ss strips around band, third was a rim blow type, not compleatly sure on that but what I heard. Also heard but not sure, the bumper guards on 69 (witch I have) where splayed out on the back but straight forward on the front. The guards I have now (4 out of 10) are made this way so??
69s S and Cudas have spring torque boxes in the rear, convertibles have rear and front. 440 engine has a unique driver side motor mount.
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #2220568
12/25/16 03:59 AM
12/25/16 03:59 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The Formula S round medallions are the same part number for '67-'68, one on each front fender, total 2. These have wide silver outer rings and are readily obtainable.
In '69 the round medallion was re-designed with a narrow black outer ring and moved to the tail panel, just one. Layson's used to sell a re-pop until 2008. Except for the Layson's version, I've never seen one of these for sale anywhere.
There were also "340-S" emblems in 1969 only for the front fenders when the upper body stripe with engine call out was deleted. But I've seen lots of cars with both these emblems and the upper body stripes, which isn't factory correct as I understand it. Were there "383-S" emblems?
Re: Differences between '67-'69 Barracudas [Re: kentj340] #2223121
12/30/16 12:32 AM
12/30/16 12:32 AM
crisfield, maryland 21817
8
82ramIndy493 Offline
Since you are all on this subject does anyone know where I can get fenders for a 69 barracuda. The passenger mainly. New, aftermarket or non rusted used. Thanks.
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #2223364
12/30/16 01:30 PM
12/30/16 01:30 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
yes the 67 notchback rear window is smaller. but the opening is the same as 68 and 69
I did years ago, I had all 3 year next to each other and did a comparison at my house. Going on memory so I might get years messed up but I will be close.
67 68 cowls are differs for 69
all three year the fire was is different
all 3 years the radiator support header is different
all 3 years the sides of the radiator support are different
I there was something on the 67 in the roof that was different
I think the inside of the trunk the trail light brackets a little different
67 inner fender are different
front license plate brackets is different I think 67 had no slots at the top
69 shoulder belts
January of 69 mandatory headrest
The fastback fold down seat hinge bracket on the seat chrome on 67 and 68 natural on 69 also and the part that screws to the body different one was cast steel and the I believe the other was cast aluminum
seat belts different
hood release different all 3 yeas 67 68 are close but different
68 astray
key light
heater cables in 67 different
67 bucket seat reinforcements different 68 69
There is more sheet metal on the body that is different have think some more.
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #2226935
01/04/17 04:49 AM
01/04/17 04:49 AM
Southern Indiana
75RoadRunner Offline
Southern Indiana
What about the horn button on the steering wheels. I have seen some with a Plymouth emblem in the center, and some with a Barracuda(fish) emblem. I have seen both on all 3 years. What determines when it would have the Plymouth emblem verses the fish emblem? Great old thread that I am glad someone drug up.
Re: Differences between '67-'69 Barracudas [Re: 75RoadRunner] #2226999
01/04/17 10:41 AM
01/04/17 10:41 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
69 = fish emblem
Page 3 of 3 1 2 3
