Page 2 of 3 1 2 3
Re: Differences between '67-'69 Barracudas [Re: B1duster] #50634
12/23/07 01:34 PM
12/23/07 01:34 PM
My 67 coupe doesn't have hood or fender-top turn signal lights. I don't think they were offered that year, but maybe someone could correct me on that.
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50635
04/09/08 04:04 PM
04/09/08 04:04 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
The antenna is different between '67 and '69 they have a smaller hole in '67 and a larger hole in '68 along with a different bezel.
RAR II
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50636
10/14/08 08:42 PM
10/14/08 08:42 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I would not like this to die...
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50637
10/14/08 08:45 PM
10/14/08 08:45 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Here is one more:
67 had a chrome button for the door handle, sometime in '68 they went to black plastic, not sure what they did in '69
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50638
10/18/08 10:30 AM
10/18/08 10:30 AM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
I believe there is a difference in the steering column . Grant shows a different steering wheel adapter for the 67's then the 68 and 69 . What is different from the 67 and the 68-69 ?
I have a 68 Cuda and I'm switching to a console shift from a column shift . The steering column I have is a 67
Re: Differences between '67-'69 Barracudas [Re: DonnieLawson] #50639
10/18/08 11:03 AM
10/18/08 11:03 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Yes, but no; they are designed slightly different but I can not see any way they are different that would effect fitment.
'67 uses a ball bearing lower retainer, whereas the later ones use a nylon sleeve type setup. the '68+ style is available in repop, but the '67 ball bearing type is not avail... I went through 4 stearing columns to find good races / balls to rebuild mine...
I was thinking about designing a busing which could be used on the '67 ones to use a real, standard ball bearing, but I never got around to it...
Re: Differences between '67-'69 Barracudas [Re: DonnieLawson] #50640
10/18/08 11:05 AM
10/18/08 11:05 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I see you are in Midletown OH, I am about 40 min from you - I have both styles if you want to see the differences...
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50641
10/18/08 03:11 PM
10/18/08 03:11 PM
Middletown , Ohio
Middletown , Ohio
What is the difference about mounting a steering wheel, different spline or something ? Is the harness the same ?
Re: Differences between '67-'69 Barracudas [Re: DonnieLawson] #50642
10/19/08 08:39 AM
10/19/08 08:39 AM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Doors for each year are different, slight difference but for originality, different.
1967, uses chrome Phillips screw for wing window
1968 and 1969, allen screw with plastic plug
1967 and 1968 interior door lock closer to back of door.
1969 interior lock release moved forward about 6 inches.
Re: Differences between '67-'69 Barracudas [Re: sawdust] #50643
10/19/08 10:52 AM
10/19/08 10:52 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
one year has a vent at the bottom of the door doesnt it ?
Re: Differences between '67-'69 Barracudas [Re: AdamR] #50644
10/19/08 04:10 PM
10/19/08 04:10 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Actually two years, 67 and 68.
Re: Differences between '67-'69 Barracudas [Re: sawdust] #50645
10/19/08 04:37 PM
10/19/08 04:37 PM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Correct, but the side view mirror moved between the two years, making all three years different...
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50646
10/19/08 05:16 PM
10/19/08 05:16 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Yeah forgot the mirror, thanks. Just to clarify, 67 and 68 are for the vents only, 67 like said above, has Phillips screw for wing window 68 Allen screw w/ plastic plug.
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50647
03/17/09 11:22 AM
03/17/09 11:22 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
Don't want this to die...
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50648
03/17/09 11:25 AM
03/17/09 11:25 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I have compiled a list (from my memory) - anyone else have any more? - there was a good thread about a year ago outlining some of the differences, but I guess it is gone now - not in my favs or search for???
A few things I have found
1. Grills are different between all years, 67-68 will swap though
2. Header panels are different all three years, again 67-8 will swap, 67 has PLYMOUTH spelled out, but '68 had it as one word, '69 had a bump in the center, '67-8 were flat along the top.
3. 67 has a one year only idler arm
4. 67 was the last year for the 273, the 68 got the 318/340/383 (the 383 was avail in '67)
5. The wiper motors are different
6. The fish emblem is bigger on a '67 and placed at the front of the fender, 68 is toward the back
7. '67 has no side markers
8. '68 grill/fenders has another hole in the left and right ends of the grill
9. '67 used the inland shifter; sometime in '68 they moved to HURST
10. in a four speed, the output shaft yoke is the small dia (the 904 style) the later ones used the large 727 yoke
11. The '67 used a smaller (3 speed) output bearing on the 4-speed then the '68+ (it was the same for '66 BTW).
12. The 67 used a smaller 9.5" clutch and the later ones used the larger 10.5" - the belhousing on a '67 is cast iron as well, and later ones are Aluminum.
13. The dash is different, the pad only covers the top, '68 the pad has a "knee pad", and 69 only covers the top, but the top pad is different.
14. The dash bezels are different - the '67 had the cig lighter in the ash tray
15. The glove box door is different as well; both in the hinges and the handle; '68's have a button (I think??)
16. The glove box cardboard box is different - it attached differently then '68+
17. The tach for a '67 is different then a '68 the sweep range is different
18. '67 the trip odo was standard, optional in '68+
18a. The speedo cable was different - it screwed into the back of the speedo in '67 and snapped in in '68+
19. For a 'vert, the inside around the window trim is painted black in '68+ in '67 the a-pilar moldings were plastic chrome and the upper part was chrome.
20. The wing ding (vent window on the door) channel and handle is different between the years, '67 has a straight handle, 68+ curves in torawd the door.
21. The doors are different, '67 has a screw holding on the wing ding (vent window) which can be seen inside the car, '68 had a plug there, '69 had nothing,
22. 67 + 68 have the door vents in the front of the door and the bottom (behind the front seat), '69 does not
23. The side view mirror was moved in '68
24. The door lock was moved in '69 up torward the driver
25. The door panels are different
26. The seat frames are different, '67 used the '66 style with steal trim for the back and bottom, '68 used something different.
27. The console was changed in '69 to a wood grain insert, the '66-68 had a black strip - both 4 speed and auto
29. The arm rests are different on a '67, they have something like a "shelf" that the pad mounts to, 68+ used the later style, which were used until '76
30. The door hardware is different, the window crank on a '67 is all metal, '68+ used a metal bar w/plastic handle
31. The rear door panels are different, but the converts are the same.
32. The gas cap is different in '69 it said "FUEL"
33. The gas tank is differen in '67 - it used one strap going from left to right, 68+ used two straps going front to back.
34. '67 had single exhaust (I think the 383 had dual, but not sure) 68 had dual exhaust.
35. '67 did not use chrome exhaust tips - the hi po cars used the 273 resonator system
36. The reverse lights are different, '67 used the long style (I think) '68 had none (they were in the tail light) and '69 used a shorter style and a longer style, but I think they are different then the ones used in '67.
37. The trunk lids are different, they have different emblem holes.
38. '67 trunk trim was 3-pieces, '68 was two, '69 was one
39. The tail lights are different for all 3 years
40. The vin number on a '67 is on the a pillar in front of the door, in '68 it is on the dash
41. The dash frames are different (the glovebox lid + plastic dash + the '68 is purforated along the top under the pad - '67 is solid).
42. The radios were different, '67 had knobs, '68 used thump wheel.
43. The '67 had the horn relay under the hood (near the horns) and in '68 it was moved under the dash
44. All 3 years used different rocker panel moldings, the '67 were thin (about 2-3"), '68 had a thin spear, with a pot metal piece with fins near the rear wheel.
45. The optional wood grain on the upper dash bezel was different on '69s compared to the '67-'68 style wood grain
46. The window lock strip was different in '67 vs. 68+ (for both the front and back windows), in '67 it used a lock strip (like the '66 and the 80's trucks) and in '68+ it was glued in and had stainless steel trim. - The vert used the same style for all 3 years though (lock strip in the bottom & stainless trip around the top)
47. The convt top & vinyl top were different grains in '67 & '68 (and maybe '69).
48. The hood trim was different for all 3 years, '
'67 used the thin fins for all models, '68 used callouts on the HP models, and a simpler design for the low po models,
49. The hood was different '67-8 to '69.
50. The headlight adjusters are different 67 to 68+, the 68 ones use a larger adjusting bolt, and a slightly different plastic piece. I think the headlight bucket is different as well, and drilled out slightly bigger for the larger bolt
That is all I can think of off the top of my head...
6t6
Re: Differences between '67-'69 Barracudas [Re: 6T6Cuda] #50649
03/17/09 11:57 AM
03/17/09 11:57 AM
383's had dual exhaust in 67, smaller diameter than in 68-9, though. See my post above.
Another way to put it is that 273's never got dual exhaust, and 340's never had single exhaust. 340's weren't available until 68, and 273's disappeared from Barracuda's after 67.
And of course non-hi-po engines had single exhaust all three years.
My 67 has the short style reverse lights.
I only had to drill a couple of new holes in the trunk lid of my 67 to put 69 trunk trim and taillights on my 67. The trunk lid sheetmetal stampings are the same as near as I can tell.
that is all I can think of off the top of my head...
6t6
Re: Differences between '67-'69 Barracudas #50650
03/17/09 12:35 PM
03/17/09 12:35 PM
MARYLAND
69Cuda340S Online content
69Cuda340S  Online Content
MARYLAND
Re: Differences between '67-'69 Barracudas [Re: DonnieLawson] #50651
03/17/09 01:16 PM
03/17/09 01:16 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
When I did the 4 speed swap on my 67, I had a 69 parts car. When I tried to swap the non-shifter sleeve onto my column, it wouldn't mount. The tube of the column was shaped differently at the top. I ended up swapping the entire column in as I recall.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Differences between '67-'69 Barracudas [Re: phantomx] #50652
03/18/09 02:47 PM
03/18/09 02:47 PM
USA
big-block-dave Offline
USA
Guys, i have started a '69 M-code A-body 40th Anniversary reunion at Carlisle in July. See carlisleevents.com for a ad/sign up to bring your car!! Other ads maybe on this site, other mopar websites and 3 of the 4 mopars mags. Any M-code A-bodies can email me at mcodecuda@yahoo.com for more info and a invite/informational letter mailed to you!! I'm also in the process of reproducing the right side exhaust spacer that goes inbetween the manifold and head pipe! I'm now the NEW CARETAKER of Whenstadt's '69 440 'cuda registry. Anyone that wants to add there M-cuda or update info email me. HELP SPREAD THE WORD!!!!! Dave
Re: Differences between '67-'69 Barracudas [Re: big-block-dave] #50653
03/18/09 02:53 PM
03/18/09 02:53 PM
USA
USA
Don't forget the reverse light housings! '67 and '69 had chrome housings/glass lens on the rear valence. '68 reverse lights were in the tail light. Therefore no holes on the '68 rear valence. There IS 3 (i repeat THREE) different lengths of chrome reverse housings. '67 short, early '69 medium(before 1/69 build), after 1/69 long.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Page 2 of 3 1 2 3
