Re: The autopsy - windowed block
[Re: Cab_Burge]
#505739
10/25/09 08:17 AM
10/25/09 08:17 AM
Posts: 2,299 NE Ohio
DoubleD
NE Ohio
Me thanks the rod bearing locked up first, which siezed on the crank breaking the rod which hit the cam, breaking it making it fall down into the rotating crankshaft and ended up lodging, for a nano second, between the block main web and the rotaing crankshaft cracking the block, maybe not sorry for your loss
Cab good guess- cam was still in perfect shape not a mark on it - all other bearing came out perfect - I have seen this before - the main cap was loose it bled oil enough to starve the rod foe awhile then finally ceased the bearing.
[Re: 727builder]
#505742
10/25/09 10:09 AM
10/25/09 10:09 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Wow... Let us pray and have a moment of silence for her. Sorry for your loss.
Dearly beloved, we are gatherd here today to morn the passing of Russ's motor. It was a crusty, rusty old piece that was well past it's prime. ![](/ubbthreads/images/graemlins/engel016.gif)
Then agian, so is Russ
[Re: WILD BILL]
#505743
10/25/09 10:21 AM
10/25/09 10:21 AM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
LMAO thats funny ! good one Bill !! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: rickstershemi]
#505745
10/25/09 11:03 AM
10/25/09 11:03 AM
WILD BILL
BROOK PARK, OH
PS.....was it wearing DEPENDS ....?????
Rickster
Fixed ![](/ubbthreads/images/graemlins/devil.gif)
[Re: rickstershemi]
#505747
10/25/09 12:05 PM
10/25/09 12:05 PM
DoubleD
NE Ohio
Talk about going out with a BANG....sorry to see the carnage Russ....best-o-luck with the new bullet ![](/ubbthreads/images/graemlins/thumbs.gif)
PS.....was it wearing a diaper....?????
Rickster
Driver had one car did not! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: 1_WILD_RT]
#505748
10/25/09 04:32 PM
10/25/09 04:32 PM
Challenger 1
Cincinnati, Ohio
You didn't get that much heat in the rod journal from a broken main web... The main bearings would tell that tale.. Those rod journals were smokin..
I pointed that out in the the thread last week that he posted, it spun a rod bearing first...
[Re: Dodgeman67]
#505749
10/25/09 10:05 PM
10/25/09 10:05 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
I got to say when the man tears something up, he sure does it right.
I hope you got your money out of that one , cause as they said, this one is done.
Sorry to see it.
This one does not owe me anything. The bottom end was put together back in 2000 and was set up with the MW heads and intake and in my 70 Challenger that I drove on the street for a while. Then it went into my 64 car in 04 and into the 63 in the last year..... It has done well for me and I had fun with it.
Russ ![](/ubbthreads/images/graemlins/wave.gif)
[Re: WILD BILL]
#505752
10/25/09 10:31 PM
10/25/09 10:31 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
How's the heads Russ? You didnt post any pics, so I assume its OK? Thats a bummer.. ![](/ubbthreads/images/graemlins/shock.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
#505753
10/25/09 11:03 PM
10/25/09 11:03 PM
Wow Russ, Looks like it had it's own little war going on in there...Looks like all you may salvage off of that one is the balancer bolt Let me know if you need any help poppaj
i think Russ wants to turn it up next year so i think he probably will pass on the help from you, IMO, remember he does want to go fast, ouch thats gonna leave a mark.
[Re: bill_greenwood]
#505755
10/26/09 12:16 AM
10/26/09 12:16 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
If that cracked main bolt hole is why it broke isn't that why they use aluminum caps? Of course my thoughts are that is just a result of the rods seizing not the cause. I don't see that causing a significant loss of lube to the rods with out takeing out the main long before ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: HotRodDave]
#505756
10/26/09 12:55 AM
10/26/09 12:55 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
if you think it was a main that got loose first, allowing oil pressure to bleed off at the main bearing, starving the rods for oil, and thus, the spun rod bearing...would a block girdle/main cap system have prevented that?
**Photobucket sucks**
