Re: Rotten tarp may have fallen into block..help!
[Re: Pyper70]
#504844
10/24/09 08:35 AM
10/24/09 08:35 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Mouse urine really does a number on aluminum parts.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: Bill MeLater]
#504845
10/24/09 07:33 PM
10/24/09 07:33 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
When you pull the valley and oil pan, do us a favor and post some pics.
Well, here it is, directly after peeling back the intake pan:
No rust to speak of, or any other debris for that matter, which is a good thing.
Here is a shot of two middle lifters. That' not rust along the lower part, just appears to be burnt or something:
Here is the front of the cam, directly under the distributor hole:
Here's the bad news:
A picture of the front two lifters, right after removing them:
And after wiping down the tappet area:
You can feel the pits when you run your fingernail across the area, so I'm assuming they are shot. Is it safe to assume the cam is also? Or perhaps they aren't that bad and I can run them? Looking for some expert opinions on this one. I'd really like to rebuild this properly and not have to take it out again.
Cheers
[Re: Pacnorthcuda]
#504848
10/24/09 09:34 PM
10/24/09 09:34 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Well now that I've got it this far apart, I'm trying to justify going deeper (bearings, rings, etc) to make sure that it is 100 percent. Who knows what I'll end up doing. Now to start bugging you all with cam questions. (In case anyone would like to chime in here, this is a 440 in an 80 RC that I would like low range power out of using the stock convertor and 3.55 gearing, 35" tires, power brakes and a 650cfm carb) Thanks all
[Re: nomore65BelvJim]
#504850
10/24/09 11:43 PM
10/24/09 11:43 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
just remember when making your cam choice you have to get your tailpipe sniffed in Maricopa county.
Jim,
Does the go for all vehicles? Is there an age cut-off for emissions testing?
