rod,stroke opinions for roots KP440?
#504524
10/23/09 01:04 PM
10/23/09 01:04 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
looking for ideas for a 4.35 bore,10.725 deck height.1400hp maxand switching to some B1-BS heads flowing 325int later from my iron flowing 280 now. thanks for your input.try to keep a budget minded $$. and no aluminum rods please.
Post deleted by Defbob
[Re: blownzoom440]
#504525
10/23/09 02:42 PM
10/23/09 02:42 PM
Re: rod,stroke opinions for roots KP440?
[Re: blownzoom440]
#504529
10/23/09 02:51 PM
10/23/09 02:51 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Just curious, why arent you just asking Scotty? Blocks look nice BTW, been reseraching them a bit, looks stout.
RIP Monte Smith
[Re: blownzoom440]
#504530
10/23/09 02:54 PM
10/23/09 02:54 PM
Posts: 705 Michigan
Hemiroid
i believe i can use steel rods for yrs and not have to change the aluminum after # passes.
Aluminum rods have come a long ways. The days of 200 laps and out and no street use are gone. A modern aluminum rod, like a GRP will last a long time and can be run on the street. They're also much more forgiving in a engine failure. Just my
[Re: CompWedgeEngines]
#504531
10/23/09 02:55 PM
10/23/09 02:55 PM
blownzoom440
ELYRIA,OH
i will get around to talking to scott but i need some brain power so i atleast sound like i might know even the smallest amount so i can relate to what he will say.
[Re: Moparteacher]
#504533
10/23/09 03:10 PM
10/23/09 03:10 PM
#504534
10/23/09 03:12 PM
10/23/09 03:12 PM
Posts: 705 Michigan
Hemiroid
Cunningham Rods.
Absolutely. Finish off the bottom end with a Fonzie crank, Potsy bearings, Mr. C. oiling system, and Joanie blower pistons with Chachi wrist pins.
#504536
10/23/09 03:14 PM
10/23/09 03:14 PM
blownzoom440
ELYRIA,OH
Cunningham Rods.
LOL!
[Re: blownzoom440]
#504537
10/23/09 06:20 PM
10/23/09 06:20 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I wouldnt go with a 4.5 stroke for that motor..Its just not needed. I would do a 4.25 stroke, and 4.5 bore...makes 540 inchs.
Whats the reason you are only going with a 4.35 bore? If your not wanting to max the block out the first go around, do what i did. I went with a 4.44 bore. This was with a Indy Maxx block, in case something happened I have extra cylinder walls thickness for a few overbores.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#504538
10/23/09 06:29 PM
10/23/09 06:29 PM
Posts: 5,875 communist bloc of new jersey
jamesc
given the bb bore spacing limitations i could never understand why people insist on going right to a 4.5" bore. 4.44 is what i went with. i know i've seen bores over 4.5" but the gasket purchase between the cylinders gets pretty thin imho
[Re: Bob_Coomer]
#504539
10/23/09 06:50 PM
10/23/09 06:50 PM
blownzoom440
ELYRIA,OH
call the bore whatever you want.i think the stroke hase more effect on my combo.
[Re: Bob_Coomer]
#504540
10/23/09 09:32 PM
10/23/09 09:32 PM
[Re: blownzoom440]
#504544
10/23/09 10:58 PM
10/23/09 10:58 PM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
on the aluminum rods. I have had a set of alm rods in my Hemi for years now. I am going to remove them soon. but they worked fine for me!! since (1988)!!
HEMI,S ARE FOREVER!!!
[Re: dodgeboy11]
#504548
10/24/09 12:13 AM
10/24/09 12:13 AM
blownzoom440
ELYRIA,OH
If it's supercharged, the big bore isn't necessary. Valve shrouding isn't as important when there's more than atmospheric pressure pushing in the air. With that being said, why are you smothering it with B1BS heads that only flow 325 if you're putting new heads on it?
no silly those are the better heads.i have iron 346 that flow 280 now!
[Re: blownzoom440]
#504551
10/24/09 10:10 AM
10/24/09 10:10 AM
Posts: 2,172 Ohio
theclutcher
Ohio
fill a kp block on a budget? Why waste the $$$ on cheap internals and risk the block? Carrillo rods and Callies or billet crank. heads wil be fine just add a few more teeth if needed. youll be blowin the tires off anyway you do it. I'd do 4.25 stroke.
[Re: bigtimeauto]
#504554
10/24/09 11:52 AM
10/24/09 11:52 AM
blownzoom440
ELYRIA,OH
thanks for your input! untel i could save some $$ for thye package i think i can use a 4.15 crank with my[in use] eagle H rods 6.760 with my wiseco pistons 2.050CH with my 95cc chamber headss and adjust the CR with the copper head gasket. i need to do the math on the CR but i can get a .100 head gasket.
[Re: bigtimeauto]
#504555
10/24/09 12:12 PM
10/24/09 12:12 PM
#504556
10/24/09 12:25 PM
10/24/09 12:25 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
less piston speed. It will make plenty of power without the stroke.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#504557
10/24/09 01:10 PM
10/24/09 01:10 PM
Posts: 903 Saskatchewan, Canada
cudabin
Not a blown application in my case, but I chose to build a 540ci w/ 4.5 bore and 4.25 stroke in my new Low deck indy Max block. Could have built a 557" or 572" for the same money... Reasons were that my 440-1 CNC 345 int volume heads (flow 382 at .800")really could not support any more than 900 hp no matter what approach,so I felt that the shorter stroke would rev higher before the heads became the limiting factor and this would allow deeper rear gears for more torque multiplication. Also i am traction sensitive with mini tubs and 10.5W X 31 slicks and ladder bars, so the shorter stroke should soften the bottom end torque and add it back on the top end... If I would have had a chassis that could handle it, i would have built the 572 and then later upgraded the heads. Choose the bore/stroke/size on what ever your final objective is but be realistic as to if you can hook it up. My two cents Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: blownzoom440]
#504558
10/24/09 05:46 PM
10/24/09 05:46 PM
bigtimeauto
Trophy Winner
Trophy Winner
Wrong, the bigger the bore the more the heads will like it.
Flow your heads on a 3.75 bore ring then on a 4.5 bore ring. After that you will never use a small bore again. I'm a big fan of the shortest deck, biggest bore, shortest pushrod i can get. After that design a piston ring package and then pick a rod length to connect the 2. Do not forget you have boost so you do not need nor want a long stroke. Since i drive my dart on the street I am even using regular size rings.
[Re: bigtimeauto]
#504559
10/24/09 06:04 PM
10/24/09 06:04 PM
blownzoom440
ELYRIA,OH
thanks for the replies. so many of the boosted engine are in the 500 range like top fuel it makes you think.there are a lot of boosted engines in the outlaw 10.5 and so on but i dont know of there ci. i am sure the head flow has some influance and the reason for my question.
[Re: blownzoom440]
#504561
10/25/09 08:27 AM
10/25/09 08:27 AM
Posts: 2,172 Ohio
theclutcher
Ohio
air flow is what makes the power. the displacement dictates the rpm that is needed to utilize the airflow.
[Re: blownzoom440]
#504563
10/25/09 10:19 AM
10/25/09 10:19 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Need to talk to somebody with blower info. Start adding boost and too many other factors come into play. Ever talk to Dave Weber in North Ridgeville? He might be able to give you some insight. Him or Lou Novotny. Local guys with lots of blower exp. in UDRA/NHRA Lou ran blown BB mopar for long time and still playing with some exotic stuff. Dave has competitive TAD. Brains and experience well worth picking, in fact, irreplacable.
[Re: blownzoom440]
#504564
10/25/09 10:27 AM
10/25/09 10:27 AM
#504565
10/25/09 11:42 AM
10/25/09 11:42 AM
blownzoom440
ELYRIA,OH
even with the better block i am not interested in more rpm.[6800]
What if you stepped up to the B1 heads, instead of those smaller B1BS heads? You might have to get another manifold, tho.
i dont want to have to switch valvetrain,pushrods...to port match my intake to the bigger b1's may not be easy.my HP goal is small also so i only need a little better heads.a lot to think about. i know dave weber pritty well.he did my block o-ring and ballance work.this was before i knew koffels.
[Re: blownzoom440]
#504566
10/25/09 12:48 PM
10/25/09 12:48 PM
bigtimeauto
Trophy Winner
Trophy Winner
I run 440-1's, 345 cnc'd 2.25 intake valve out of the box from indy, 23lbs of boost. If i would have built this from the begining my way it would have had a 4" crank in it. Right now I am leaving the starting line with 4* of timing and ramping the timing in over the next 2.5 seconds. I shift at 6800 and go thru around 7200. I run a 29.5/10.5 tire.
[Re: bigtimeauto]
#504569
10/26/09 03:43 PM
10/26/09 03:43 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Is 23 lbs of procharger boost the same as 23 lbs of roots boost??I am still limited to 5 lbs of boost ,,,,,,,,for now
[Re: theclutcher]
#504570
10/26/09 05:36 PM
10/26/09 05:36 PM
blownzoom440
ELYRIA,OH
Weber was making near 40 on his sbc years back. Dont know what they run now. What psi koffels run?
dave is using a 460+ cu in motor has alan johnson heads and i am sure runs more than 55lbs that the monster runs.he uses a screw blower also[weber] hemi itis quit choking that engine and get some bigger carbs. match my 2x 1250's
