Post deleted by Defbob
[Re: blownzoom440]
#504564
10/25/09 10:27 AM
10/25/09 10:27 AM
Re: rod,stroke opinions for roots KP440?
#504565
10/25/09 11:42 AM
10/25/09 11:42 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
even with the better block i am not interested in more rpm.[6800]
What if you stepped up to the B1 heads, instead of those smaller B1BS heads? You might have to get another manifold, tho.
i dont want to have to switch valvetrain,pushrods...to port match my intake to the bigger b1's may not be easy.my HP goal is small also so i only need a little better heads.a lot to think about. i know dave weber pritty well.he did my block o-ring and ballance work.this was before i knew koffels.
[Re: blownzoom440]
#504566
10/25/09 12:48 PM
10/25/09 12:48 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I run 440-1's, 345 cnc'd 2.25 intake valve out of the box from indy, 23lbs of boost. If i would have built this from the begining my way it would have had a 4" crank in it. Right now I am leaving the starting line with 4* of timing and ramping the timing in over the next 2.5 seconds. I shift at 6800 and go thru around 7200. I run a 29.5/10.5 tire.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#504569
10/26/09 03:43 PM
10/26/09 03:43 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Is 23 lbs of procharger boost the same as 23 lbs of roots boost??I am still limited to 5 lbs of boost ,,,,,,,,for now
[Re: theclutcher]
#504570
10/26/09 05:36 PM
10/26/09 05:36 PM
blownzoom440
ELYRIA,OH
Weber was making near 40 on his sbc years back. Dont know what they run now. What psi koffels run?
dave is using a 460+ cu in motor has alan johnson heads and i am sure runs more than 55lbs that the monster runs.he uses a screw blower also[weber] hemi itis quit choking that engine and get some bigger carbs. match my 2x 1250's
