Page 2 of 3 1 2 3
Re: Hand or CNC Head Porting ??? #504038
10/22/09 08:33 PM
10/22/09 08:33 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
We're building a 426 to put in the car to get the headers built and bugs worked out, then the heads will go on a 528 or 572, so we will see how the CNCed heads do on each one.
Re: Hand or CNC Head Porting ??? [Re: moparniac] #504039
10/22/09 08:38 PM
10/22/09 08:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cnc porting with hand blending...
this is what I do... there is quite a bit of
machine lines in the port and I take the machine lines out
Re: Hand or CNC Head Porting ??? [Re: MR_P_BODY] #504040
10/22/09 08:44 PM
10/22/09 08:44 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Whats it worth hand blending CNC ports? This doesnt include the valve job which is hand blended in my case anyways?
Re: Hand or CNC Head Porting ??? [Re: Bob_Coomer] #504041
10/22/09 09:12 PM
10/22/09 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my W-9 it was 2 cfm.... I had my B1MCs cnc'd and
touched them up also... I dont know what/if there was
any change... I didnt have them re-flowed
Re: Hand or CNC Head Porting ??? [Re: MR_P_BODY] #504042
10/22/09 10:15 PM
10/22/09 10:15 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
CNC porting is only as good as the information fed into the computer, and even then it still falls short of the hand ported port that was digitized for the CNC program. I would say that on a head that has symetrical ports you could get away with a fairly good CNC ported head. But on a big or small chrysler where you have ports with opposite bias, there's only so far a CNC machine can go IF there's core shift. This is where a good head porter comes in. I like to start max effort port jobs with untouched heads. It gives me an idea of how thick the material is. If I start on a CNC'd head I have no idea how much material is left in the port and whether or not there's any core shift or not.
For something that I just want a quick port job on and consistency, I say go CNC. But if you want the most out of a set of heads, you need a good head porter. As for the debate of hearing when the material gets thin, I have experienced this on several occasions.
If you want the best CNC ported heads out there, go talk to Chapman. They are an example of CNC porting at it's best.
Re: Hand or CNC Head Porting ??? #504043
10/22/09 10:28 PM
10/22/09 10:28 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm sending my hemi heads to Jeff at Modern.
smartest thing i've heard today.
i'll be right behind you.
Would like Jeff or Mike to chime in here and verify some facts on CNC proceedures and how much additional work is needed in a max effort hemi or wedge cylinder head.I would think that depending on the head the program was written off and the person writing the program could have a tremendous effect on the final outcome.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hand or CNC Head Porting ??? [Re: hemi-itis] #504044
10/22/09 10:44 PM
10/22/09 10:44 PM
Utah
topbrent Offline
topbrent  Offline
Utah
CNC machine work is as good as the program...yup...
However, given Jeff @ MCH's outstanding track record and PRO client list...I would venture that his happy customers feel his CNC work is nothing less than outstanding.
Re: Hand or CNC Head Porting ??? [Re: dodgeboy11] #504045
10/22/09 10:57 PM
10/22/09 10:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Chapman did one set of my W-9s.... plus I sent them a
broken W-9 they ported to see if it could be repaired,
it was beyond help... they duplicated my one to
a tee.... I still touched up the machining lines,
they are the ones I picked up 2 cfm for just a short
bit of time
Re: Hand or CNC Head Porting ??? [Re: MR_P_BODY] #504046
10/22/09 11:09 PM
10/22/09 11:09 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
bit of time
mike, did you have another set cnc'd by someone else, if so do you know the difference?
Re: Hand or CNC Head Porting ??? [Re: moparniac] #504047
10/22/09 11:18 PM
10/22/09 11:18 PM
Finally a HUSKER again
Moparnut426 Online content
Moparnut426  Online Content
DING DING DING DING we have a winner!!!!!
KAsey
Re: Hand or CNC Head Porting ??? [Re: Moparnut426] #504048
10/22/09 11:55 PM
10/22/09 11:55 PM
isn't it proven by jeff at modern that his cnc program on 906 heads outperformed a hand porter on a FAST build getting a 440-6 RR into the 10 second zone while the hand porter was only able to get the A12 RR to low 11's.
i believe thats proof enough that CNC'ing one of these heads works better then hand porting.
if i were to do it again CNC'ing is my choice,hands down.
Re: Hand or CNC Head Porting ??? #504049
10/23/09 12:05 AM
10/23/09 12:05 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
CNC'ing is not magic just a xerox machine for a digitized hand ported port. Depending on the original it is probably 95-98% as good, add some hand rubbing after to get another 2%. That being said unless your running an all out effort where you need every last hp, CNC'd heads from a top line porter are more than adequate and usually a little cheaper.
would be curious to see Jeff or others post flow #'s of the original hand port versus the digitized copy of the same port. Head type not important. would be willing to bet it is only 2-3 cfm.
Re: Hand or CNC Head Porting ??? [Re: tjmarcus1] #504050
10/23/09 12:15 AM
10/23/09 12:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No I had the one set of W-9s cnc'd and a set of
B1mc cnc'd, Ryan did a hand port set of W-9 that
were a couple cfm better than the cnc'd ones but with
the little work I did on my cnc'd W-9s they were
almost identical in max flow
(plus the one head that Chapman also duplicate was
cnc'd)
Re: Hand or CNC Head Porting ??? [Re: TS3303] #504051
10/23/09 12:17 AM
10/23/09 12:17 AM
and i bet cnc'ing is safer as not to go through the water jacket.
Re: Hand or CNC Head Porting ??? #504052
10/23/09 12:27 AM
10/23/09 12:27 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
My 440-1 heads CNC ported by MCH flow 380+cfm. The car went 144 mph in the 8th mile and 1.07 60ft Mid July heat. Coulda been a bit faster If I had areal converter.
My Stock Hemi heads also done by MCH flow 460cfm, I am willing to bet the engine runs good also.
Proof to me is the track times..Flow bench numbers doesnt mean squat to me unless the track numbers back them up
Which they have
Re: Hand or CNC Head Porting ??? #504053
10/23/09 12:37 AM
10/23/09 12:37 AM
you can see by the answers here that almost everyone's take on this subject is all about peak flow numbers.
so using YOUR logic for a street hemi car with a 2800 stall convertor, 256 @.05 camshaft and 9.5-1 compression, a max port CNC hemi head flowing 460 cfm would be the cats azz? not hardly. the porting needs to match the combo. stop being so one track minded.
Re: Hand or CNC Head Porting ??? #504054
10/23/09 01:23 AM
10/23/09 01:23 AM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
Dan! This is the last time I'm going to tell you to stay away from the coffee pot this late! Only saw one post about max flow, yes it's all about the area under the curve for a broad power curve.
Bob whats this 1.07 144 mph car? dragster or PA car?
Re: Hand or CNC Head Porting ??? #504055
10/23/09 09:20 AM
10/23/09 09:20 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A 10sec pass so far has only happened ONCE , Ed had a killer 60ft and has not been able to duplicate it since .
You should stick to what you know ... BBQ'ing skirt steaks ...
Re: Hand or CNC Head Porting ??? [Re: JohnRR] #504056
10/23/09 09:43 AM
10/23/09 09:43 AM
Re: Hand or CNC Head Porting ??? [Re: JohnRR] #504057
10/23/09 09:47 AM
10/23/09 09:47 AM
hemi-itis Offline
hemi-itis  Offline
John,you should stick to chasing ambulance casualties.You speak with SUCH authority like you are running in the 14's.Correct me if I'm wrong but the top F.A.S.T guys are all going to MCH.And NO!You can't have a peice of steak
Page 2 of 3 1 2 3
