Re: What kind of HP gains with electric water Pump and fan? [Re: Quicktree] #503250
10/25/09 06:25 PM
10/25/09 06:25 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
anybody ever tested to see how much ET an alternator will cost you?
It seems to depend on the alt (amps?) I knew that I could depend on .09 by takin off the belt, even made it into a mini quick 16 race once by doing that, but after that alt died the one that replaced it must not have been robbing as much HP as it was only good for .03 off the ET. I'm guessing the one that died was a higher amp alt?
Re: What kind of HP gains with electric water Pump and fan? [Re: StrokerPost] #503251
10/25/09 06:41 PM
10/25/09 06:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
we took the belt off of Woody's car last night and it made hardly any difference
Re: What kind of HP gains with electric water Pump and fan? [Re: Quicktree] #503252
10/25/09 07:46 PM
10/25/09 07:46 PM
Wi.
65_gt_rag_402 Offline OP
Wi.
Yes... That is a GOOD Question also !!
I plan on running a powermaster 140 amp or a 120 denso for my ragtop. how much HP would this big 140 amp alt. take away VS a 60 amp? IS it putting more of a strain on the engine than a 60 amp? Bigger 140 amp robbing more HP that a 60 amp????
just wondering !
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: What kind of HP gains with electric water Pump and fan? [Re: 65_gt_rag_402] #503253
10/25/09 07:55 PM
10/25/09 07:55 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The alternator is only going to put out what is required to keep the battery charged. Which will depend on how much draw that you have. With a lot of draw the bigger amp alternator will put out more amperage and pull harder but will take a shorter time to restore charge or to keep up with the load. .
I have also notice that my idle speed will drop when I kick the fan and water pump ondue to alternator load.
