Page 2 of 3 1 2 3
Re: Milodon gear drive users come on in [Re: Bob_Coomer] #503029
10/21/09 10:36 PM
10/21/09 10:36 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Keep'em coming guys..
What mods if any are required to the after market MP blocks, I actually have a World. 4.5 bore version.
I tried to read the installation instruction on the web site. It would have probably understood it better If I had the parts in front of me, or any experience with these.
The Milodon gear drive in my World block cleared without any special grinding. My Pre-World MP block needed more aggressive grinding to some internal boss.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Milodon gear drive users come on in [Re: turbobitt] #503030
10/21/09 10:55 PM
10/21/09 10:55 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Mines noisy, it depends on your preference. If I had to do it again I'd go with a belt drive.
Re: Milodon gear drive users come on in [Re: 1badx] #503031
10/21/09 11:38 PM
10/21/09 11:38 PM
Ransom Canyon, Texas
Madness Offline
Madness  Offline
I've had one for years hanging on the wall that says RAMCHARGERS across the top. Is it common?
Re: Milodon gear drive users come on in [Re: Madness] #503032
10/22/09 01:34 AM
10/22/09 01:34 AM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
I recently put one on my World block, 4.5 bore. Easy installation but a few things we discovered. You will need longer bolts for the electric water pump as the Milodon spaces the water pump out to clear the cover. You will need a new dampner or a spacer behind the existing dampner along with longer bolts for mounting the dampner. Outside of these, I really like the Milodon and it is not very noisy at all.
Good luck
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: Milodon gear drive users come on in [Re: brktracr] #503033
10/22/09 03:01 AM
10/22/09 03:01 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
WHAT?
I have had two of them in three different big blocks, and switched to belt drive because of the noice. In the engine dyno through mufflers the operator asked several times if the engine is really ok, are you sure that it won't blow up? Other than that it's a good unit, very reliable and accurate, easy to set on after you figure it out etc. However, nothing wrong with a good chain either, and a bunch less $.
Plynouth VIP '67 TT IC EFI
Re: Milodon gear drive users come on in [Re: jyrki] #503034
10/22/09 05:19 AM
10/22/09 05:19 AM
pa
572charger Offline
572charger  Offline
pa
ive had one on my hemi since 2003 makes alittle noise i can hear it at cruise inside my car sounds like a vacuum leak i got mine brand new for 380.00 so i bought it u need it on a hemi or a belt drive last barton ss hemi i saw still had one on it mopar muscle or action did some dyno testing i think the gear drive made the most hp and kept the cam timming dead on !! my mopar 2002 block needed grinding to clearance the idler !!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Milodon gear drive users come on in [Re: 572charger] #503035
10/22/09 06:49 AM
10/22/09 06:49 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
Very accurate and very strong, I run it for more than 20 years w/o any trouble. Go for it !
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me Run 8.04" / 168 mph 1.11" 60 ft Fastest Mopar at the Euro Mopar Nats website : http://vantastic-racing.com/
Re: Milodon gear drive users come on in [Re: Dodgem] #503036
10/22/09 07:02 AM
10/22/09 07:02 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I really like mine got two one in the box form my next 542 and one that came with this JWD 452.
First yo put them on with no lower dowel pins and get gear clearance right drill to 5/16 and install 5'16 dowels and that is done.
Trick is there are no timing marks!
so you get your degree wheel on at TDC! one of these is the cats butt for this!!
http://chucker54.stores.yahoo.net/crtusowidewh.html
you turn the cam to .050 lift and turn the crank to the @.050 number you desire and then line the top gear up so 7 bolts line up perfectly and tighten gear then do your regular degree checks to make sure where you are!! the mark things and any advancing and retarding of cam from where you are is done buy lining numbers up to the original 1 mark!!
So if you have a 260 @ .050 cam and you want it at 106 you devide 260 by 2 = 130 then you subtract 106 this leave 24 so you want @.050 lift at 24 BTDC (before)
That is the cat's meow Barry. I will be getting one of those.
Re: Milodon gear drive users come on in [Re: mac56] #503037
10/22/09 08:04 AM
10/22/09 08:04 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Milodon here, quiet.
stay with single idlers, more power and less vibes from what I here.
Re: Milodon gear drive users come on in [Re: mac56] #503038
10/22/09 08:49 AM
10/22/09 08:49 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It was so nice when I changed cams as you pull it off do what you got to do put it back on and tighten the set screw no re doing the corrected 0 mark plus the handy 1/2 ratchet use to turn the engine!
did a buddys cam timing in AYR in august and he liked it too! LOL!!
Re: Milodon gear drive users come on in [Re: jyrki] #503039
10/22/09 10:36 AM
10/22/09 10:36 AM
The Great White North
RAMM Offline
RAMM  Offline
WHAT?
I totally agree with this statement! We fired our 471 up and I thought the dyno was frigged up because of the different and very noticeable noise. I put my stethoscope all over the engine just to make sure and the second I touched the cover it just about tore my ear drums out. I think it does have a lot to do with the idler gear being and integral part of the cover. That being said- timing stays super accurate, once you know how to use the vernier type cam gear you can jack the cam around to whatever you want quickly and easily. My only piece of advice would be to get a GOOD dampener as I think it kicks the crap outta a lesser one pretty fast. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Milodon gear drive users come on in [Re: RAMM] #503040
10/22/09 10:54 AM
10/22/09 10:54 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
WHAT?
I think its all relative. What one person would consider noisy, another may say its not. The Milodon installed in my Hemi is noisy compared to the other 2 milodon drives I used. I also think its from the idler bolted to the cover instead of the block.
AG
Re: Milodon gear drive users come on in [Re: turbobitt] #503041
10/22/09 11:33 AM
10/22/09 11:33 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Have one on a KB block, no mods needed though you have to get the correct damper. Stable timing but noisey. With the mufflers on it sounds like I'm running a procharger. Personally I don't like the noise but I can live with it.
Re: Milodon gear drive users come on in [Re: Tig] #503042
10/22/09 01:06 PM
10/22/09 01:06 PM
UK
602heavy Offline
602heavy  Offline
UK
Milodon gear drive here too , as said already , whistles like a supercharger , the front oil gallery has been modified to spray oil on the gear drive (megablock).
The gear drive helps regards the excessive endplay on crank (0.015")
Re: Milodon gear drive users come on in [Re: Cab_Burge] #503043
10/22/09 02:11 PM
10/22/09 02:11 PM
Milwaukee WI
R_Blaha Offline
R_Blaha  Offline
Milwaukee WI
My dad's 496 has a Milodon gear quick change drive and it pushes the water pump out so there is less room from the pulley to the radiator. I have the pete jackson on my hemi, fits under the stock timing cover, was a little less $$ than the Milodon and sounds just the same.
LOOKING FOR THE 68 GTS IN THE AVATAR SPOT
1969 Dodge Superbee post coupe 383
1969 Dodge Superbee hardtop 472 hemi
1989 Mustang GT
1993 mustang lx 5.0
2004 screaming yellow cobra
2013 CVO Roadglide
Re: Milodon gear drive users come on in [Re: R_Blaha] #503044
10/23/09 04:25 AM
10/23/09 04:25 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
You can get the sound of the Stereos with only a CD cost. I have borken two P&J's, I would never use a floatinig dual idler again. nayway, with the Milodon I actually stated to have torubles in the yearly inspection, not beacause of the exhaust noice, but engines mechanical noice. That's the only reason I switched to Jesel.
Re: Milodon gear drive users come on in [Re: Dodgeman67] #503045
07/08/11 09:48 AM
07/08/11 09:48 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I'm bumping this thread up from way back as I noticed I posted in it inquiring about them also and I must say mine seems noisy this time ....
Bob you ever get one?
Mopar Performance
Re: Milodon gear drive users come on in [Re: moparniac] #503046
07/08/11 10:22 AM
07/08/11 10:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been running a KB gear set for about 12 years
now on my 2 race engines(small blocks)... no noise
and timing is dead steady... just have to set the back
lash on the idler to the specs and drill and tap 1 hole...
They are pretty nice... loosen a few screws and you
can change the cam timing(degree marks on the cam gear)
I also have a KB for a BB as well as a aussie belt drive
which is new... I'm in the process of selling off
my BB stuff
Re: Milodon gear drive users come on in [Re: MR_P_BODY] #503047
07/08/11 10:39 AM
07/08/11 10:39 AM
PA
moparacer Offline
moparacer  Offline
PA
We run one in our small block too.
Cant even tell its in there.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 5.44-126
414 cid SB Dragster 7.65-174
Re: Milodon gear drive users come on in [Re: moparacer] #503048
07/08/11 10:52 PM
07/08/11 10:52 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
I got about eight years on mine, no problems and its not loud on the smallblock
Page 2 of 3 1 2 3
