Re: Milodon gear drive users come on in
[Re: Madness]
#503032
10/22/09 02:34 AM
10/22/09 02:34 AM
Posts: 753 San Diego, CA
brktracr
super street
super street
San Diego, CA
I recently put one on my World block, 4.5 bore. Easy installation but a few things we discovered. You will need longer bolts for the electric water pump as the Milodon spaces the water pump out to clear the cover. You will need a new dampner or a spacer behind the existing dampner along with longer bolts for mounting the dampner. Outside of these, I really like the Milodon and it is not very noisy at all.
Good luck
1.298 60 ft
6.001 1/8 mile
114 mph
9.52 1/4 mile
140.87 mph
@ 3110 lbs
[Re: brktracr]
#503033
10/22/09 04:01 AM
10/22/09 04:01 AM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
WHAT? I have had two of them in three different big blocks, and switched to belt drive because of the noice. In the engine dyno through mufflers the operator asked several times if the engine is really ok, are you sure that it won't blow up? Other than that it's a good unit, very reliable and accurate, easy to set on after you figure it out etc. However, nothing wrong with a good chain either, and a bunch less $.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#503034
10/22/09 06:19 AM
10/22/09 06:19 AM
Posts: 1,629 pa
572charger
pa
ive had one on my hemi since 2003 makes alittle noise i can hear it at cruise inside my car sounds like a vacuum leak i got mine brand new for 380.00 so i bought it u need it on a hemi or a belt drive last barton ss hemi i saw still had one on it mopar muscle or action did some dyno testing i think the gear drive made the most hp and kept the cam timming dead on !! my mopar 2002 block needed grinding to clearance the idler !!!
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Dodgem]
#503036
10/22/09 08:02 AM
10/22/09 08:02 AM
Posts: 976 ontario canada
mac56
ontario canada
I really like mine got two one in the box form my next 542 and one that came with this JWD 452. First yo put them on with no lower dowel pins and get gear clearance right drill to 5/16 and install 5'16 dowels and that is done. Trick is there are no timing marks! so you get your degree wheel on at TDC! one of these is the cats butt for this!! http://chucker54.stores.yahoo.net/crtusowidewh.html you turn the cam to .050 lift and turn the crank to the @.050 number you desire and then line the top gear up so 7 bolts line up perfectly and tighten gear then do your regular degree checks to make sure where you are!! the mark things and any advancing and retarding of cam from where you are is done buy lining numbers up to the original 1 mark!!
So if you have a 260 @ .050 cam and you want it at 106 you devide 260 by 2 = 130 then you subtract 106 this leave 24 so you want @.050 lift at 24 BTDC (before)
That is the cat's meow Barry. I will be getting one of those.
[Re: turbobitt]
#503041
10/22/09 12:33 PM
10/22/09 12:33 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Have one on a KB block, no mods needed though you have to get the correct damper. Stable timing but noisey. With the mufflers on it sounds like I'm running a procharger. Personally I don't like the noise but I can live with it.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: R_Blaha]
#503044
10/23/09 05:25 AM
10/23/09 05:25 AM
jyrki
Finalnd, Perkele
You can get the sound of the Stereos with only a CD cost. I have borken two P&J's, I would never use a floatinig dual idler again. nayway, with the Milodon I actually stated to have torubles in the yearly inspection, not beacause of the exhaust noice, but engines mechanical noice. That's the only reason I switched to Jesel.
[Re: Dodgeman67]
#503045
07/08/11 10:48 AM
07/08/11 10:48 AM
Posts: 6,295 U.S.
moparniac
U.S.
I'm bumping this thread up from way back as I noticed I posted in it inquiring about them also and I must say mine seems noisy this time ....
Bob you ever get one?
Mopar Performance
[Re: moparniac]
#503046
07/08/11 11:22 AM
07/08/11 11:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've been running a KB gear set for about 12 years now on my 2 race engines(small blocks)... no noise and timing is dead steady... just have to set the back lash on the idler to the specs and drill and tap 1 hole... They are pretty nice... loosen a few screws and you can change the cam timing(degree marks on the cam gear) I also have a KB for a BB as well as a aussie belt drive which is new... I'm in the process of selling off my BB stuff
[Re: MR_P_BODY]
#503047
07/08/11 11:39 AM
07/08/11 11:39 AM
Posts: 2,530 PA
moparacer
PA
We run one in our small block too.
Cant even tell its in there.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
