Re: 25 MPG with a 408 ??? Yup!!
[Re: dmerc]
#500646
10/23/09 03:21 PM
10/23/09 03:21 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
![](/ubbthreads/images/graemlins/iagree.gif) The more efficient the chamber and port design, the less time you need for combustion (meaning, less ign advance), the less negative torque that will be created, and the less heat that will be lost to the cooling system. All adds up to more fuel efficiency. ![](/ubbthreads/images/graemlins/thumbs.gif)
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Rapid340]
#500648
10/23/09 03:43 PM
10/23/09 03:43 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
my mild 318 (combo listed above) seems to like 32 or so degrees of total advance for best power and economy. I'm using a 17 degree vac advance can on the dizzy, for a total of 49 degrees of cruise advance.
[Re: dmerc]
#500652
10/23/09 07:25 PM
10/23/09 07:25 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Depends on if what the engine needs. Normally in my experiance the magnum heads work best 32-34 mechanical advance. When I had my 318 mpg motor it really ran better with a very short mechanical advance and a short vaccume advance. If I remember the sweet spot for mechanical was 18 initial and 32 total. The shortest vaccume advance can I found was 8.5 and it did the best, I think it would have really liked a couple less total degrees. Once I got it all tuned right it ran the same on 87 octane as 93 and neither one wanted more advance. I am now at 3000 ft elevation so that lowered my preasure a hair.
[Re: dmerc]
#500653
10/24/09 12:36 AM
10/24/09 12:36 AM
Posts: 2,474 Answering the call of the wild
ThermoQuad
Great work ![](/ubbthreads/images/graemlins/bow.gif) I wonder if a six pak would do even better. I am glad to see someone put some thought into having a fast [but old] car & gas mileage just like new tupperware can... [Tupperware refers to a corvette-plastic container with an airtight lid...] Have you put synthetic fluid in the diff??? Anything synthetic for lubricants will help raise the mileage as well. I have a very strong 416 six pak in an E body with overdrive that got 16 mpg going to & from Carlisle 180 miles each way. Speed was 55-70 mph mostly on cruise control. I'd show the naysayers my log book for the car but that's classified info. ![](/ubbthreads/images/graemlins/sawzall-smiley.gif)
[Re: Skeptic]
#500657
10/24/12 09:00 AM
10/24/12 09:00 AM
patrick
Grand Haven, MI
dmerc's last post was over a year ago...you might be waiting a while
[Re: dmerc]
#500661
10/24/12 02:07 PM
10/24/12 02:07 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Way to go, Dmerc. ![](/ubbthreads/images/graemlins/thumbs.gif) These great cars do NOT have to be "single purpose" machines. Efficiency crosses many lines and a clean running engine can be fast and fuel efficient. Late model cars are compromises of the big 3 factors: Emissions, economy and performance. YOUR efforts are in line with the OEMs, and it should be congratulated. Nice work. My car will never see 25 mpg even driving downhill with 90 series tires and the trans in neutral. I do plan on improving the combination to maximize mpgs, but there are some points to which I will not concede. I will not modify the exterior, change the tires or switch to a smaller engine. The T-Quad carb could be the single most effective modification to improve mpgs. Your efforts are paying off, and posting them here will certainly help others reach their goals. Thank you.
