Mopar aluminum head P4876624 for Magnum 5.9l
#498962
10/16/09 07:24 PM
10/16/09 07:24 PM
Posts: 118 Sarasota, Fl
siggie30
Sarasota, Fl
I need info for porting the exhaust port on this head on the short side (how deep?)also, since bottom end is stock what is an accurate Compression Ratio for these 53mL chambered heads? (Application is 5.9l SB stock bottom end)
I don't even have 1/2 lift, but the other 1/2 is nitroused.
Re: Mopar aluminum head P4876624 for Magnum 5.9l
[Re: siggie30]
#498963
10/16/09 07:26 PM
10/16/09 07:26 PM
siggie30
Sarasota, Fl
Here is a close up of the port(s).
[Re: siggie30]
#498964
10/16/09 07:49 PM
10/16/09 07:49 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
Wierd, looks like some funky upside down A.M.C. port.Considering it will go on a stock bottom end,I would thin the extra width around the guide,and polish the rest. The short side looks to have a pretty large/tall radius already.Should flow good enough for a stock lower end.
[Re: 67_Satellite]
#498965
10/16/09 11:39 PM
10/16/09 11:39 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I think how much porting you want to do will depend on what cam you are going too run, is it just the stock cam? If it is just a stock cam then grinding much out won't do any good, just smooth out the rough areas around machining transitions and if you have the rough cast heads there is a lot of rough stuff in there to clean out. Any more than that and it will not do any good. The pushrod pinch in the intake port is pretty bad so might want to open that up a little, I don't think that would hurt on a stock motor, also the bump in the intake roof from the rocker boss can be removed but you have to run a thread sealler on the studs or bolts or oil can be sucked through around the threads. I have set like that I was going to use but may end up selling them to pay for the rest of my motor and I will just run ported stock heads and hope they don't crack too bad. ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: HotRodDave]
#498966
10/17/09 05:55 AM
10/17/09 05:55 AM
siggie30
Sarasota, Fl
Good points, the cam is 0.506 lift @ 227/234. So do not elongate the vertical access on the exhaust to match the gasket?
[Re: siggie30]
#498967
10/24/09 08:08 PM
10/24/09 08:08 PM
siggie30
Sarasota, Fl
Okay fellas, I have been lightly porting around the valve stems and cleaning up the exhaust. I still need some info on these heads. I assume that not many people are running them since they have such a small combustion chamber, but surely someone has used them or know someone that is.
[Re: siggie30]
#498968
10/24/09 10:48 PM
10/24/09 10:48 PM
HotRodDave
Kalispell Mt.
Remove that knob. Open the ex to about 1/16 smaller than the gasket all the way around. The PR pinch is really small so open it up as much as you can with out makeing holes into other parts of the head. With your cam exotic max porting is not nessacary.
Not many people are useing thease heads because they were so over priced when new it was incredibly rediculous. You could buy complete eddys with springs valves retainers... for less than thease cost new and the eddys flow more OOTB.
Do you have any more specific questions you need help with?
[Re: siggie30]
#498971
10/26/09 09:02 AM
10/26/09 09:02 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
assuming the stock bottom end was a true 9:1, dropping chamber size from 64cc to 53cc, keeping all else the same gets you 10:1...
on the exhaust short side, just make sure there's a nice smooth transition from the valve job up and into the short side. I wouldn't mess with it too much. hack down the valve guide bosses, I'd do a little work on that bulge for the pedestal in smoothing it out, but I wouldn't remove it entirely. I'd also open up the pushrod pinch as much as you feel comfortable.
Re: Mopar aluminum head P4876624 for Magnum 5.9l *DELETED*
[Re: patrick]
#498972
10/27/09 03:25 PM
10/27/09 03:25 PM
siggie30
Sarasota, Fl
Post deleted by siggie30
[Re: siggie30]
#498974
11/03/09 07:06 PM
11/03/09 07:06 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I would raise the exhaust opening but not lower it.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: dulcich]
#498976
11/03/09 09:46 PM
11/03/09 09:46 PM
siggie30
Sarasota, Fl
The previous picture with the note "alignment tab". It seems that if this tab were not there that the gasket and the intake openings would better be aligned. Is there a reference to aligning the intake to the head intake port that I do not already see. Since I haven't really started on the intake side (at the entrance) I would just like to do this once (or rather 8 times) and be allright. Would it be simpler to mark the heads and intake together and move the gasket to match them up (taking into account the shimmed difference of course)? EDIT: Okay so after the "mock up" it is apparent where everything goes. I am concerned about removing the rocker bolt casting as these are aluminum heads and the amount of material that would be left for the bolt concerns me for longevity and strength (100 shot N2O will be used).
[Re: dulcich]
#498978
11/04/09 07:37 AM
11/04/09 07:37 AM
siggie30
Sarasota, Fl
If I grind out the hump- it leaves just a hair over 5/8" thickness. The studs are 3/8".
[Re: patrick]
#498980
11/04/09 12:39 PM
11/04/09 12:39 PM
siggie30
Sarasota, Fl
I agree. I think you are right. I should of not posted it that way, but hey- first time ![](/ubbthreads/images/graemlins/wrench.gif) builder. I found out after putting the stuff on the block how the gaskets really should be oriented ![](/ubbthreads/images/graemlins/whistling.gif) . Thanks for not flaming btw.
[Re: siggie30]
#498981
11/05/09 06:05 PM
11/05/09 06:05 PM
siggie30
Sarasota, Fl
Here are a few shots of the rough port work. I really just need someone to say "hey, your messing that up" or "finish polishing what you have there". the line toward the valve is the referenced area in the next post.
