Re: porting 906 heads
[Re: VernMotor]
#498931
10/19/09 08:45 PM
10/19/09 08:45 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Nice!  I actually wish my buddy, Dwayne Porter could comment here. We learned a lot about this head design from the FAST builds I did here at the shop. He did all the heads on my engine builds.  Another thing to mention that is a big concern with these, especially when pushing them to the limits. External cracks. These castings, especially those which have been decked heavily, will "oil can" and create external water cracks. heck, I have a pile of stock heads that I have changed out over the years with external water cracks. The main problem area seems to be under the two center exhaust ports. This area is particularly thin. It just pains me to see someone spend a lot of time and money on these, when they know they are a ticking time bomb. Yes, and I know people have made some serious power with these. When that's all you had to work with you made the best of it. No different with the old Hemi stuff. We would buy tore up blocks, busted up heads, and cracked cranks and try to patch it up and make it work. Now we can buy new stuff.  MB
[Re: JohnRR]
#498934
10/20/09 12:59 PM
10/20/09 12:59 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Did anyone see the motor that Indy entered and won with in the enginemasters competition, it had aluminium inserts in the ports.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#498935
10/20/09 03:14 PM
10/20/09 03:14 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
adding inserts is common. Same with the Ford Cleveland heads.
[Re: JohnRR]
#498936
10/20/09 04:15 PM
10/20/09 04:15 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Vern , where did that cut up head crack ?
Been to many years now..Not sure I remember but I am thinking it was in the intake port.
[Re: moeflo]
#498937
10/20/09 09:35 PM
10/20/09 09:35 PM
Posts: 12,595 Great Neck,LI,new york
hemi-itis
It is my job. I can see your point on doing the same head for the same job. It helps tremendously in saving testing and development time. But, doing mainly heads for various class racing, I'm always working with different lift ranges, engine sizes, RPM ranges, etc. so I rarely do a set w/o the need for at least, some specific development around an existing combination. I may have 100 hours in a set using a fully CNC'ed set as a starting point.
So your saying even with a set of fully ported CNC'd heads they still need to "detail" the port or bowl??
[Re: 383man]
#498938
10/20/09 11:11 PM
10/20/09 11:11 PM
Posts: 2,381 MD
Kevins493
MD
Nice work. This is the only pic I have of my 906's on my 63. I bet I have about 30 hrs total in them as not only did I do the bowls and ports I enlarged the seats and installed the 2.14 & 1.81 valves myself. I really dont think I can ever port another set of heads as it made my back hurt so bad bending over to work on them I could hardly stand it. I think the next eng I build I will just get some CNC aluminum heads and save my back the pain. What is the car and combo they are going on?? Ron
You and me both Ron. When I did those 346 heads for the Fury I was sore for weeks. Of course now I don't have time to mess with it either..
[Re: hemi-itis]
#498939
10/21/09 08:15 PM
10/21/09 08:15 PM
hemi-itis
I would have thought that a CNC performed job would be DONE and need nothing else
[Re: hemi-itis]
#498940
10/22/09 05:38 PM
10/22/09 05:38 PM
i have a virgin set of 906 heads that i was going to get ported by hand but after seeing the results a CNC program has over a set of hand ported heads,its a no brainer to go the CNC route. but my question is, after they are CNC ported, how much hand work extra is there to do, polishing, blending,etc.
[Re: RAMM]
#498943
10/23/09 08:27 AM
10/23/09 08:27 AM
Posts: 75,428 A gulag near you.
JohnRR
A gulag near you.
Guys, this is the perfect thread right now! I am currently porting a set of '452's. I have a 1020 and haven't gotten radical yet but baselined them @ 215 cfm and now have them @ 262--but want more. Yes I know that flow #'s are a small part of it. I'm just playin here and want to get some numbers to brag about. What can I do to get max numbers? And no I don't want to leave out the spark plug! Oh and I have read the archives but without pictures it doesn't help as much as it could. Thanks J.Rob
The numbers you want to BRAG about are at the end of the 1/4 mile.
Here's some food for thought, how long does the valve sit at MAX LIFT ??? The important flow numbers are those BELOW max lift since the valve is at all those lifts TWICE .
