Page 2 of 3 1 2 3
Re: porting 906 heads [Re: proshiftcharger] #498911
10/17/09 10:17 AM
10/17/09 10:17 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
My heads have been extensively ported and modified. They are now Max Wedge port size and closed chambered. I'm having a valve job done on them right now and will post specs when I get them back.
FWIW, these heads were done before I was born, lol!!!
Just curious...
Are you guys still using templates to do the port work that DC & MP used to sell?? Or is there a better way now?? How many hours does it take to do a pair of 906's to the max as far as you can
take them??
Templates have you do very little work , they are for stock valve sizes and they don't have you do anything to the short turn which is what makes or breaks the port.
Re: porting 906 heads [Re: jsmopar1072] #498912
10/17/09 07:57 PM
10/17/09 07:57 PM
Pennsylvania
proshiftcharger Offline
Pennsylvania
its a 72 charger 727 3800 stall 3:91 ratio 8 3/4.
440
4.350 bore
3.75 stroke
diamond flat tops sitting flush
heads are 906's ported
2.14 int 1.81 exh valves cut .040 1.6 ratio roller rockers
cam in ex
gross lift .646 .630
[Email]duration@.050[/Email] 264 .275
112.0 separation
solid roller
What et's with this combo?
Re: porting 906 heads [Re: proshiftcharger] #498913
10/17/09 09:08 PM
10/17/09 09:08 PM
mt.ephraim , new jersey
jsmopar1072 Offline OP
not sure yet although i was TOLD it would go 10.70s but im sure its more like 11s.ill let you know when i get these heads done and the motor back in the car.
WINNING IS ALL LUCK,ASK ANY LOSER! OBJECTS IN MIRROR APPEAR TO BE LOSING! JEFF'S BUDGET DODGE GARAGE!!!!
Re: porting 906 heads [Re: dodgeboy11] #498914
10/17/09 10:16 PM
10/17/09 10:16 PM
nc
moeflo Offline
moeflo  Offline
nc
Just curious...
Fully ported aluminum heads with valve job typically takes about 16-18 hours.
16-18 hours?! For fully ported heads? Man, I wish I had your energy.
Re: porting 906 heads [Re: moeflo] #498915
10/17/09 10:45 PM
10/17/09 10:45 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I typically don't, but when it's your job, you make it happen... lol, 8 hr days standing in one place with a grinder get a little old but at the same time, I like making things go faster! Keep in mind, those 16 to 18 hrs of port work, that's one heads I've done before and know what needs doin'. Heads I've never worked on before, those require some time...
Re: porting 906 heads [Re: dodgeboy11] #498916
10/18/09 08:25 AM
10/18/09 08:25 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Have them flowed and see how you did. I think the exh port is way too large for starters. Looks mean little tho. The idea is not to make them LARGER but to make them flow air faster and smoother with the right volume. Just big can mean more problems than power.
Re: porting 906 heads [Re: dodgeboy11] #498917
10/18/09 10:42 AM
10/18/09 10:42 AM
nc
moeflo Offline
moeflo  Offline
nc
It is my job. I can see your point on doing the same head for the same job. It helps tremendously in saving testing and development time.
But, doing mainly heads for various class racing, I'm always working with different lift ranges, engine sizes, RPM ranges, etc. so I rarely do a set w/o the need for at least, some specific development around an existing combination. I may have 100 hours in a set using a fully CNC'ed set as a starting point.
Re: porting 906 heads [Re: CrAzYMoPaRGuY] #498918
10/18/09 12:27 PM
10/18/09 12:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice work. This is the only pic I have of my 906's on my 63. I bet I have about 30 hrs total in them as not only did I do the bowls and ports I enlarged the seats and installed the 2.14 & 1.81 valves myself.
I shoulda read the thread first, you are bang on IMO...
Thanks for the kind words.
I know when I did my own heads I would work on them for a few hrs a night. Then go back to them the next time I had a few hrs to spare as I have a bad back and it kills me to stand like that for long. So this way I would only stand like that about 2 hrs at the most. Ron
Re: porting 906 heads [Re: 383man] #498919
10/18/09 06:22 PM
10/18/09 06:22 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I think the exh ports are big also, i would get them pressure checked before i screw them on the motor & risk trashing the block.
Re: porting 906 heads [Re: 383man] #498920
10/18/09 06:22 PM
10/18/09 06:22 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Get a stool that you can sit on and make sure you have some sort of rubber mat under your feet. Something so you're not standing on the hard floor all the time. Makes it a little more bearable. I also find that an MP3 player helps me concentrate on the work at hand and drown out background noise.
Re: porting 906 heads [Re: dodgeboy11] #498921
10/18/09 07:31 PM
10/18/09 07:31 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Some bowl hogs, a mikita electric die grinder, and some good bits from mondello save alot of time when porting cast iron.
Re: porting 906 heads [Re: Twin Turbo Mower] #498922
10/19/09 04:44 PM
10/19/09 04:44 PM
any other input?
Re: porting 906 heads [Re: jsmopar1072] #498923
10/19/09 05:45 PM
10/19/09 05:45 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Ok I got lots of pics..you ask for them LOL.. I start out with pics of a ported head that got cracked and we cut it up so we could see how thick and thin it was. tell me if you want to see more like this..
Re: porting 906 heads [Re: VernMotor] #498924
10/19/09 05:49 PM
10/19/09 05:49 PM
please do post em up
Re: porting 906 heads [Re: VernMotor] #498925
10/19/09 05:52 PM
10/19/09 05:52 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
The problem with these castings is that they aren't consistent. The bottom line is if you try to get a lot out of them, then it's not a matter of IF they will crack, but more like WHEN they will crack. Like the others have stated, if you don't need to run them to comply to a specific class, then I really don't see how it makes sense to take these to a very high level. We are really in the "Golden Age" of aftermarket parts. Why mess with this old junk unless you have to.
MB
Re: porting 906 heads [Re: HPMike] #498926
10/19/09 05:56 PM
10/19/09 05:56 PM
i cant afford indy heads and all the fancy offset rockers plus i already have 906s so im going to use them.if i could i would.i know its silly to use them but they ran good back in the day
Re: porting 906 heads [Re: HPMike] #498927
10/19/09 06:03 PM
10/19/09 06:03 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
MB
And I agree..so keep that in mind the whole trick here is make them flow better not to make them bigger..they will crack ..sooner or later
Re: porting 906 heads [Re: VernMotor] #498928
10/19/09 06:15 PM
10/19/09 06:15 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
ok here is cut up pics first..you realy have to look at them to figger out what you are looking at.
Re: porting 906 heads [Re: VernMotor] #498929
10/19/09 06:19 PM
10/19/09 06:19 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
some other pics of ported heads
ok I got more. wife says time to eat >>I will post some more here in alittle bit.
Re: porting 906 heads [Re: VernMotor] #498930
10/19/09 06:51 PM
10/19/09 06:51 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
here is a flew more.
Page 2 of 3 1 2 3
