Opinions on my set up
#495877
10/13/09 12:41 AM
10/13/09 12:41 AM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Ok did a little drag racing about 2 weeks back! i was pretty happy!
I pulled 13.68 at 105, 1.9 60 foot time.
Here is my build up
1970 dodge Coronet 3900 with me in it
440 engine 10:1 compression (Estimate) stock 440 aluminum heads Comp Xe268h-10 Cam with stock valve train 770 street Avenger Holley Street Dominator intake 1 3/4" shorty headman headers 727 transmission with 2500 PCT torque converter MRVB and 3:91 gears on my Yokohama 295 50 15 street tires.
like I said I was happy with my times, but could you please look at my build and tell me what I should consider changing to put me into the 12's?
Maybe this is it and i should accept it, but any pointers would be great.
Mike
1969 Dodge Dart Swinger
Re: Opinions on my set up
[Re: MikeyT]
#495878
10/13/09 01:01 AM
10/13/09 01:01 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
You need bigger stuff. Cam/Carb/Headers, and the convertor is minimum. Are you sure its razor tuned as is? It sounds like its running to its potential. ![](/ubbthreads/images/graemlins/popcrn.gif)
[Re: RemCharger]
#495879
10/13/09 01:08 AM
10/13/09 01:08 AM
MikeyT
Watertown, WI
Probably not. I'm learning as I go. I've got timing set at 34 degrees (pings at 36) and went up one jet size on the carb, but that is about it. I haven't done any other wild voodoo things to it yet.
I was afriad that the top end change might be in order. ( suggestions would be nice for each) Would uncorking my headers and fattening up the carb do anything?
Ny the way I went with a streetwize build and it was very helpful to set this car up.
Mike
[Re: MikeyT]
#495880
10/13/09 01:11 AM
10/13/09 01:11 AM
Triple Threat
Renton Washington
Get the Car to 60 foot harder, you already make enough horsepower to run in the 12's.
My car runs 12.40-.50 at the same 105 MPH. But my car 60 foots in the high 1.6 range.
[Re: Triple Threat]
#495881
10/13/09 02:18 AM
10/13/09 02:18 AM
Posts: 1,460 oklahoma
forphorty
oklahoma
My car only runs 107 mph but has gone 12.35 with a 1.69 60ft. You need a sticky tire first. Eliminate any wheelspin and then see where you are at. If the launch is still soft, you may need more converter, but your cam is pretty mild, ought to have pretty good low end. I don't know about those shorty headers, a full length set would probably perform better. opening the headers would probably pick up a couple mph if you only have a 2.5 in exhaust. I bet more cam and converter would make your car really fly. Sounds like it runs pretty good for such a mild combo. Get some tires first, then play with what you have for awhile.
[Re: Triple Threat]
#495882
10/13/09 04:36 AM
10/13/09 04:36 AM
Quicktree
your car is not 3900 pounds, so no he's not making enough hp to run 12s. he's making good hp for what he has and I agree he needs to work on the 60' which isn't bad for what he has either. more converter,better tire,maybe a gear change would probably help. also a better carb/intake may help. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Quicktree]
#495883
10/13/09 07:47 AM
10/13/09 07:47 AM
That's wrong, Tony.........105 IS enough speed to go 12's at ANY weight...........ALL he needs is traction and a converter swap and I guarantee it'll run at least 12.50's..........and with a converter swap and sticky tires, I bet it'll pick up 2MPH....... ![](/ubbthreads/images/graemlins/wave.gif)
I've had LOTS of 3,900 to 4,000LB cars run mid 12's in the 105MPH range even with 3.55 gears.......... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MikeyT]
#495885
10/13/09 08:52 AM
10/13/09 08:52 AM
Posts: 52,972 Romeo MI
MR_P_BODY
To me for a street car I work from the back forward, in other words... I would put gear in it first, then a converter, then build the engine. With a gear you spend less time below the torque curve, converter keeps you in the torque longer yet... then the engine for more power.... but without hooking it up its ALL wasted ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MikeyT]
#495886
10/13/09 10:11 AM
10/13/09 10:11 AM
That’s very similar to my combination.
Mine’s a 4000lb (with me in it) 69 road Runner, 10:1 .030 over 440, 3.91 gears, 2500 stall, and a manual VB. I run 12.7’s – 12-8’s @ 107 mph here in Boise 12.3’s – 12.4s at 110 mph at sea level.
The differences in our combo’s: I run 11.5x28 Hooser QTP DOT’s (Like these guys said get that thing to 60 ft and the ET will come in line.)My 60"'s here in Boise are mid 1.8's I run a stock 4bbl intake, and factory (cast iron) heads, (with a Holley 750 DP on top). I’ve played with a Street Dom intake, it’s probably helping your top end mph a little (I only gained about ½- ¾ a mph with one), but it may be hurting your low end torque, and therefore your 60 ft. I run the purple 484/282 cam. I’m not sure how it compares to your comp cam, but I know a few people who have switched from Comp cams that are supposedly similar to the 484/284, to the 484/284, in mild 440’s and 383’s, and all have gone quicker with the mopar cam.
[Re: MikeyT]
#495888
10/13/09 01:00 PM
10/13/09 01:00 PM
I'd start with tires and a pinion snubber (if you're not already runnig one), and see where that get's you. Good luck ![](/ubbthreads/images/graemlins/thumbs.gif)
#495889
10/13/09 01:25 PM
10/13/09 01:25 PM
Posts: 484 The State of Hockey
2qik4u
The State of Hockey
I would agree 105 mph indicates the car has enough HP to run 12's.
#495890
10/13/09 03:45 PM
10/13/09 03:45 PM
Quicktree
maybe if he makes the right changes, we will see.
[Re: MikeyT]
#495891
10/13/09 03:59 PM
10/13/09 03:59 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
Mike
Mike, give us the 411 on the 440 aluminum heads. Are they MP452's? What kind of stock head?
With 10 to 1, I would go bigger cam, bigger carb, more converter. Get the most out of the aluminum heads.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#495893
10/13/09 06:20 PM
10/13/09 06:20 PM
MikeyT
Watertown, WI
Wow, thanks guys! Quote:
Mike
sorry they are 440 source aluminum heads! I've done nothing other then put the4m on the car.
They flow pretty good except on the exhaust side
.3 205.5 /140.9 .4 242.1/ 161 .5265.2/173 .6 274/ 182
Would a turn on the chassis dyno help as well?
Mike
[Re: MikeyT]
#495894
10/13/09 07:13 PM
10/13/09 07:13 PM
Mike
There are a LOT of things that will help........more stroke, having those heads fixed, a real camshaft, and on and on.......
It depends on what you're trying to accomplish......If you want to get into the 12's as cheaply as possible, put some sticky tires on it and if that doesn't get it there, loosen the converter to about 3,800 and you'll easily run mid 12's........
If you want to get into the 12's on hard tires, you'll need to work on the suspension and it may take a little more power, which equals tuning.........
What EXACTLY are you trying to accomplish?
#495895
10/13/09 07:24 PM
10/13/09 07:24 PM
MikeyT
Watertown, WI
Big Squeeze
What I would like is to get a decent street thumper that can hang with some of the other guys in my car group. Most of these guys have street tuned imports that are well in the 12' and I would like to be at least respectable, while retaining driveablility.
Mike
[Re: MikeyT]
#495896
10/13/09 08:44 PM
10/13/09 08:44 PM
Big Squeeze
Mike
How quick is "respectable" in your book and what kind of tire do you plan on racing on???
Like mentioned, slicks and converter swap and you'll run mid 12's........
[Re: MikeyT]
#495898
10/13/09 11:39 PM
10/13/09 11:39 PM
My 8 3/4 has held up just fine, and I've been running it hard at the track for over 8 years. (individual results may vary ![](/ubbthreads/images/graemlins/wink.gif) )
#495899
10/14/09 02:32 AM
10/14/09 02:32 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
![](/ubbthreads/images/graemlins/iagree.gif)
At 105mph it's got mid 12's in it.
As much as people don't like to pay for them, a looser converter is going to help a bunch.
Get the 60' down and the ET will follow. Sticky tires, pinion angle, spring clamps, front suspension work, etc.
[Re: Quicktree]
#495901
10/14/09 08:30 AM
10/14/09 08:30 AM
I don't think it's going to be as easy (or cheap)as some of you think to go from 13.60s to mid 12s. problem areas are going to be tire, converter. traction and a little more power. and to answer your question about the 83/4, heavy car with decent power and traction could lead to disaster for it. take all the precautions with it. it all depends on how much money you want to spend to reach your goal. If it were me I would get the heads ported, different carb and intake, headers, slicks maybe a 10.5, 8" race converter. that would be a good start, and maybe a cam swap
DON'T BELIEVE THE NAYSAYERS!!!........It IS that easy.......and you don't need an 8" converter.........just a 4,000 9.5 or 10" (about $550 for a new one with shipping or you could look around here for a good used one for about half that) and a set of used 28X9 slicks and you're there.........and that's a LOT cheaper than buying and installing camshafts, installing different headers, having the heads ported, different carb, different intake and a $1,000 8" converter............With all those changes, it'd run low 11's and cost you at least 4K....... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Quicktree]
#495902
10/14/09 10:04 AM
10/14/09 10:04 AM
2qik4u
The State of Hockey
I get the impression this was the 1st time out with this car, which leads me to believe some tuning and seat time could net considerable gains. Again, 105 mph is easily low 13/ high 12 horsepower. ![](/ubbthreads/images/graemlins/Twocents.gif)
#495903
10/14/09 11:06 AM
10/14/09 11:06 AM
Quicktree
I learned a long time ago to go overkill when looking for ET. it saves you disappointment ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: MikeyT]
#495904
10/14/09 11:23 AM
10/14/09 11:23 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
My demon a few weeks ago went 13.8 102mph roght off the trailer with air PSI adjustments. Its a four speed and my 60 footers are crap, 2.22. I run MT et streets, and ss springs, and a snubber. I was told I need get my 60 ft times down, and Ill be in the 12.50 range also. I run a 9.5 to 1 360, ported J heads, Hydraulic roller cam, and a Quickfuel 750. Runs hard, just dont hook for crap. Youll get it hookin, and get her runnin quicker... I have a 408 in the works, so Mine was just a before and after kinda thing. You are keeping your combo it sounds like so you can dial it in some more. Nice car by the way, Im doing a 70 bee next. ![](/ubbthreads/images/graemlins/thumbs.gif) Kasey
#495905
10/14/09 03:43 PM
10/14/09 03:43 PM
Quicktree
if you can get him running 12.50s with a $550 converter and a pair of slicks and guarantee it. I would have to advise him to take you up on it. I think it will take around 108mph and a few other chenges to gain over 1.1 seconds. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Quicktree]
#495906
10/14/09 04:13 PM
10/14/09 04:13 PM
Posts: 4,085 Indiana
W5Duster436
Indiana
Always wanted to ask what type of 1/4 ET i would get from running 89MPH in the 1/8th if I got traction? Never could get traction at all and usually ran 8.40's but trapped at 89mph very consistenly on all 4 runs in the cuda.
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: Quicktree]
#495907
10/14/09 04:57 PM
10/14/09 04:57 PM
Put up 4K and I'll prove it.......I'll call PTC and have them send the converter to my house, I'll drive up there with my 28X9 slicks and tranny jack and swap converters in his driveway and then take it to test and tune.......(if the drag strip is still open this time of year in Wisconsin???) Heck, for 5K, I'll go to Wisconsin, bring the car back here, do the deed, and bring it back to him.......
ANY takers??? anyone want to make a quick 4 or 5K??????? ![](/ubbthreads/images/graemlins/popcrn.gif)
I'll also say that with the converter swap and adding slicks, it'll pick up 2MPH, which would put it at 107 and the car may run as good as 12.30's.........
89MPH in the 1/8 is 7.60's in the 1/8, which is 12.0's - 12teens @ 109 in the 1/4...........
#495909
10/14/09 05:19 PM
10/14/09 05:19 PM
MikeyT
Watertown, WI
Put up 4K and I'll prove it.......I'll call PTC and have them send the converter to my house, I'll drive up there with my 28X9 slicks and tranny jack and swap converters in his driveway and then take it to test and tune.......(if the drag strip is still open this time of year in Wisconsin???) Heck, for 5K, I'll go to Wisconsin, bring the car back here, do the deed, make my 5K, and bring it back to him.......
Personally I'm all for this idea! Yet seriously a couple things are given. It looks like slicks and converter change are a minimum.
I got the slicks covered. Now what size converter should I go with?
Mike
[Re: Quicktree]
#495910
10/14/09 05:20 PM
10/14/09 05:20 PM
like I said if you guarantee it, he needs to take you up on the offer it would eb the best money he ever spent. If I had had 4k I would probably take you up on the bet. but since I don't I would like to see him spend the $550 and run the mid 12.50s. I would be first in line to give you a big congrats.
Heck, I know you're a BIG BALLER, just borrow the money from the bank for 30 days.......You'll DOUBLE your money.........and there can be as many Moparts members around as you want to verify that I don't touch anything else....... ![](/ubbthreads/images/graemlins/beer.gif)
It'll be the easiest 4 or 5K you've ever made....... ![](/ubbthreads/images/graemlins/wave.gif)
#495911
10/14/09 05:22 PM
10/14/09 05:22 PM
Quicktree
just help the man out, I would love to see him run 12.50
[Re: MikeyT]
#495913
10/14/09 05:37 PM
10/14/09 05:37 PM
Mike
Like mentioned, I'd go with a 9.5 or 10" that stalls at least 3,800.........I've had great luck with PTC 256-383-6868......... Tell them you want it to stall at LEAST 3,800RPM (personaly, I'd get something that stalls around 4,500)....... ![](/ubbthreads/images/graemlins/thumbs.gif)
I'm trying to help you out too by making you 5K richer...... ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MikeyT]
#495916
10/14/09 07:37 PM
10/14/09 07:37 PM
RemCharger
Sk. Canada
Mike
Wouldn't hurt to talk to Wize too.... And yes, ditch the exhaust as long as the shortys don't burn anything.
[Re: B G Racing]
#495917
10/14/09 07:52 PM
10/14/09 07:52 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
I wouldn't do anything till I had alot more race time and honed my driving techniques and established a base line et.
I think you've nailed it. I would not touch a thing.
Unless he stopped for take-out mid track, his numbers don't make sense. I believe that is why there is the debate over the converter and 60' time and what the result would be.
With a 1.9 60', and 105 trap speed, that should be a 13.0 to 13.1, not a 13.68. Either one of his three numbers is wrong, or something happened mid track
He needs more track time, and after that, he needs to start tuning.
[Re: B G Racing]
#495918
10/14/09 08:11 PM
10/14/09 08:11 PM
MR_P_BODY
I wouldn't do anything till I had alot more race time and honed my driving techniques and established a base line et.Then make changes as required to better the et,starting with gear ratio,tires and easy bolt on parts.You will always have the base line to tell you if the changes worked or not.
the gear itself is a torque multiplier but you HAVE to put it to the ground ![](/ubbthreads/images/graemlins/wave.gif)
[Re: BSB67]
#495919
10/14/09 09:01 PM
10/14/09 09:01 PM
MikeyT
Watertown, WI
I'm very certain of this factas well. I've had very minimal seat time at the track. I know once the newness wears off I'll be good to go Sadly I threw out the time slip. I know 1320 time and trap speed were such, and I might be remember the 0 to 60 foot wrong, but I'm almost certain it was around 1.9, if not it was close, not off by more then a couple tenths .1 + or -
Mike
[Re: MikeyT]
#495920
10/14/09 09:50 PM
10/14/09 09:50 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
Mike
A couple tenths in the 60ft. would change everything. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: MR_P_BODY]
#495921
10/14/09 09:55 PM
10/14/09 09:55 PM
You guys are over-rocketeering this.......and I'm still holding my breath on anyone to take me up on my bet........I'm trying to stimulate the economy......... Somebody WILL have a few K to spend on their hot rod......... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
I'll even put a 2.91 Sure Grip in the car and I'll still bet it'll go mid 12's with JUST a converter swap and slicks......... ![](/ubbthreads/images/graemlins/popcrn.gif)
Any takers??? According to all the experts, the odds are way better than going to the Casino.......... ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: moparguy7074]
#495922
10/14/09 09:56 PM
10/14/09 09:56 PM
MikeyT
Watertown, WI
I know i know .1 on the bottom often means .2 on the end, but honestly I wasn't that far off!
Man this is a great discussion and I feel like things are coming to gether on it and I'm getting excited. I just for once would like to run what you big dogs run!
Mike
#495923
10/14/09 10:25 PM
10/14/09 10:25 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
You put 2.91,s in and I will take that bet that it wont do mid 12,s
But as is, it Does have the MPH for mid 12,s it just needs a better hook and more vert ![](/ubbthreads/images/graemlins/thumbs.gif)
As many have stated ![](/ubbthreads/images/graemlins/shruggy.gif)
I agree with Mike and Bob above that I would run the combo as is to get some better baseline runs out of it. Theres nothing wrong with that With more runs ,he may break into the high 12,s anyways.
But no doubt IMO, that MPH shows that his ride is good for a mid 12. mike ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Sport440]
#495924
10/14/09 10:51 PM
10/14/09 10:51 PM
OK.......It's a BET....... ![](/ubbthreads/images/graemlins/wave.gif)
Is the starter of the thread, Mike, willing?
Do we have anyone that'll hold the money while this takes place? How about Mr. P Body or Bob George?
Can we get a Moparts member to loan us a 2.91 Sure-grip chunk???
If his local track is open, for 4K, I'll drive up there on a Thursday with the converter and my tranny jack and do the swaps in his driveway on Friday, then we'll go to TNT either Friday night or Saturday.........
If his local track is closed, for a 5K bet, I'll go up there, get the car, bring it back, swap converters, gears, and install slicks......and he can race it.........then I'll swap gears back and haul it back up to Wisconsin.......
If he doesn't mind, I'd prefer to drive, but I'm sure I can walk him through how to get the most out of it.......
Step up with the cash........ This is gonna be FUN....... ![](/ubbthreads/images/graemlins/apimp.gif)
#495925
10/14/09 10:59 PM
10/14/09 10:59 PM
MikeyT
Watertown, WI
LOL! I would love to, but this weekend I have to work and have a paper for class to complete. Now give me a little time to get the slicks and the converter and I promise that I will leave the car the same and run it as such! hopefully I can get into the 12's with it. This would also shut up a few of the braggarts at the local club who think my mopar is two big and to possibly be fast. Sorry they are import dudes and they do not know what they say!
Mike
[Re: MikeyT]
#495926
10/14/09 11:00 PM
10/14/09 11:00 PM
How about next weekend? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Is your track still open, and do you know for how long? BTW.......I'll buy the converter and you'll get to keep it, no charge........Free converter and installed for free....... ![](/ubbthreads/images/graemlins/apimp.gif)
#495927
10/14/09 11:06 PM
10/14/09 11:06 PM
MikeyT
Watertown, WI
Big Squeeze I'll be honest you got me all fired up! Thanks! Its going to make sleep very difficult this evening Yet its really kind of a bad time for me. When I was asking I was trying to figure out a few things over the winter months to work on. ![](/ubbthreads/images/graemlins/laugh2.gif) Not by next weekend! My car is actually slated to go into the shop on monday to fix this ugliness ![](http://i13.photobucket.com/albums/a270/Mike440SB/P1020091.jpg) and this one ![](http://i13.photobucket.com/albums/a270/Mike440SB/P1020088.jpg) Mike
[Re: MikeyT]
#495928
10/14/09 11:11 PM
10/14/09 11:11 PM
It'll look fine running mid 12's........and I have a set of slicks you can use...... If you're up for it, I can come get it ANYTIME and I can do a private track rental at a track about two hours from house for $75/hour (Mokan Dragway)...... I'll take the car there, run it as is, with plenty of Moparts members there, I'll swap converters and gears at the track, then we'll do the money shot.........Then I'll swap gears back and bring the car back to you....... ![](/ubbthreads/images/graemlins/apimp.gif)
#495929
10/14/09 11:14 PM
10/14/09 11:14 PM
MikeyT
Watertown, WI
Man thats tempting! Sorry as much as I would love too I can't do this until spring. Sorry!
Mike
[Re: Quicktree]
#495931
10/15/09 04:43 PM
10/15/09 04:43 PM
dang I was hoping to see that majic trick really I would have loved tosee the results. Wayne how much nos were you plan on running?
Nothing magic about it.......As long as the motor isn't running out of fuel or missing, it'll be fine, as-is........ ![](/ubbthreads/images/graemlins/wiink.gif)
#495932
10/15/09 11:55 PM
10/15/09 11:55 PM
MikeyT
Watertown, WI
I do have a couple questions. What will running a loose converter do for driveability on the street. Lets say I do go with a 3800 loose converter. Won't I have huge overheating issues on the street with it?
Mike
[Re: Sport440]
#495934
10/16/09 09:09 AM
10/16/09 09:09 AM
Mike
Mike. with todays Tight converters you could have a 4500+ stall vert and not know it driving around town. My 4200 stall Dynamic drives and feels like a Stock Vert, That 4200 stall doesnt come into play untill, you put the hammer down.
EXACTLY.........Don't sweat it.......If you're worried about it, just put the biggest tranny cooler you can find in front of the radiator........ ![](/ubbthreads/images/graemlins/beer.gif)
