Page 3 of 3 1 2 3
Re: WHOA!!!! ....Problem has Been Solved...Finally!!!!! [Re: CR8CRSHR] #494164
10/22/09 02:50 PM
10/22/09 02:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If this motor rotated fine before and all you did was change manifolds and such how does a piston all of a sudden be hitting the crank ?
Re: WHOA!!!! ....Problem has Been Solved...Finally!!!!! [Re: CR8CRSHR] #494165
10/22/09 03:03 PM
10/22/09 03:03 PM
IMGTX Online content
IMGTX  Online Content
I'm in the class of people thinking something isn't Kosher in Denmark here.
A Stock build should not need trimming. Combined with the fact the problem suddenly appeared there is something loose or wrong.
Pull that rod cap.
Re: WHOA!!!! ....Problem has Been Solved...Finally!!!!! [Re: IMGTX] #494166
10/22/09 03:19 PM
10/22/09 03:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There has got to be something wrong to have only one piston hit because they all are the same and so are the rods and crank throws. For some reason that rod is shorter or the piston longer. Grinding is just a way to get the crank to rotate but it sure isn't going to cure the problem. It would be very bad finding the problem after reinstalling the engine and starting it.
Re: WHOA!!!! ....Problem has Been Solved...Finally!!!!! [Re: stumpy] #494167
10/22/09 04:11 PM
10/22/09 04:11 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Did you pull the right head? It would be interesting to compare piston heights. I agree with the others, with stock parts you should not have any interferences.
Re: WHOA!!!! ....Problem has Been Solved...Finally!!!!! [Re: CR8CRSHR] #494168
10/22/09 04:12 PM
10/22/09 04:12 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Found the problem...
Nope. You found the result of the problem....
Page 3 of 3 1 2 3
