Re: WHOA!!!! Need some advise and opinions....Urgent Update
[Re: 1_WILD_RT]
#494145
10/17/09 07:21 PM
10/17/09 07:21 PM
Posts: 10,759 North Dakota
6PakBee
North Dakota
Hang on just a minute. Your initial post said the motor would turn over fine with the C-body pan/pickup. You suspected the B-body pan/pickup was the culprit and it wasn't. Now that you still have the problem, you're prepared to tear the motor down looking for something in the combustion chamber? The only thing I've ever seen crawl into a combustion chamber without assistance is mice. If it were me, before I started pulling the entire engine apart I'd be pulling the valve covers to make sure I didn't just lose a valve for some reason .
[Re: it's Bob]
#494147
10/18/09 01:17 AM
10/18/09 01:17 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Can't wait to get the final wait to get the final answer to this one ![](/ubbthreads/images/graemlins/coffeetime.gif) Still betting on some simple answer
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#494148
10/18/09 08:53 AM
10/18/09 08:53 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
after you unbolt the torque convertor, but before you do any more... try turning the engine.
[Re: moper]
#494150
10/18/09 12:50 PM
10/18/09 12:50 PM
Posts: 2,530 Nunya CA
CR8CRSHR
Nunya CA
Torque Converter is not bolted to the Motor/Flex Plate at present but turns freely so that eliminates that theory. As for the Motor turning freely before, that is true. However after careful thought over past work I have done on this Motor, i.e. Manifold, HP Exhaust Manifolds, etc, I just might have dropped something inadvertently into it. That is a possibility as I did drop something earlier after the re-build...That was done in 2005...and had to pop a head off to get that pesky washer I dropped into it, After the suggestion of checking to see if a Valve has dropped, might also be the culprit causing the sudden stoppage. Either way I have to tear the top end down to do a thorough inspection and correct what ever is causing this. I re-built the 383 in my 66 Chrysler 300 completely myself and only had a builder complete this motor's re-build for me as I was unable to put the time in due to AF commitments and flying. Just goes to show ya sometimes if you want things done right the first time one might want to consider doing the whole thing yourself. The builder also has a stellar reputation but that doesn't mean that even one with great credentials cannot miss something. As long as the lower end rotating section is functioning as it should, the top end I can handle. Why it might even be time to put some E-heads or 440 source heads on it instead. But I think not....I don't have the spare $$$$'s and I am also re-locating to NW Florida the 1st of the year. So I need to get this issue solved and buttoned up so the car can be transported/shipped to there. Thanks for the inputs and all. Keep them coming and I will continue asking questions as needed..... ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
[Re: CHRYCOFAN]
#494152
10/18/09 05:54 PM
10/18/09 05:54 PM
Posts: 1,181 Lost in the ozone again
stubbs300
Vacation
Vacation
Did you ever check to see if a flexplate bolt is too long & hitting the back of the block? Can't remember if you checked that. Had that happen once, just a bit too long & they'll hit.
Butch
Some people just can't read or comprehend the facts that cr8crshr has writen so many times that the motor isn't bolted to the flexplate!
[Re: stubbs300 ]
#494153
10/18/09 06:42 PM
10/18/09 06:42 PM
CR8CRSHR
Nunya CA
[Re: CR8CRSHR]
#494154
10/18/09 08:31 PM
10/18/09 08:31 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
You might save yourself a lot of work by getting a borescope and looking in the spark plug holes on that side. You can see what ( if there is one) problem you are having without going thru all this work.
RIP Monte Smith
[Re: CHRYCOFAN]
#494159
10/19/09 03:53 PM
10/19/09 03:53 PM
CR8CRSHR
Nunya CA
I read a lot about the converter bolts but couldn't remember ( as I said ) if the flexplate to crank bolts had been checked. Too easy to look...
Sorry I bothered you...
Butch
No way did you bother me Butch. We have chatted numerous times over on the C Body Board and the Dry Dock and I know your work with your C Body. You got a leg on me when to comes to a lot of this stuff. I appreciate any input because it makes me become more thorough in this. And my Bad...I have not checked the Flex Plate to Crank bolts at all. Just assuming that it is correct as they are all the exact ones Ma Mopar uses. But I will do that and also check the Harmonic Balancer Bolts on the front of the Crank as well. I have to get this thing solved before I have to start packing up for my California to Florida move and the more I get put back together with this project the easier it will be for transport. My C Body is drivable but the B Body will not be at that time. But the more I have bolted back on will make it easier to ship. Again Thanks a Bunch guys and keep the theories going....cr8crshr/Bill ![](/ubbthreads/images/graemlins/wrench.gif)
