Re: Power Shift my 4-speed? [Re: Thackdaddy] #493734
10/12/09 12:16 AM
10/12/09 12:16 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
And it seems like opinions vary on what the lack of power shifting vs lifting a bit is doing to my actual et?
Well, in either case above you are not power shifting, once you push the clutch you loose the power part.
Back in the late 60's when sticks were a lot more common that today, the racers that I knew called POWERSHIFTING just pulling the handle without using the clutch or lifting the gas; SPEEDSHIFTING was slightly using the clutch and leaving the gas floored, and GRANNYSHIFTING was clutching and lifting the gas. Different guys call it differently, like the posi/sure-grip/traction-lock nicknames. I never saw too many guys actually powershift without using a modified trans - as in modified blocker rings and sliders. I also learned a trick we called button-shifting - you would put a switch in the shifter ball that would short the coil when pushed. As you shifted. you tapped the button, which made the motor nose over, and you could shift the trans easier. Many bikes still do it today; it's tied into the airshifter button; the tell-tale is the pop through the pipes from the ignition cycling and burning the gas out of the pipes.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Power Shift my 4-speed? [Re: Evil Spirit] #493735
10/12/09 12:35 AM
10/12/09 12:35 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Even a slick shifted trans, [every other tooth ground off gear ring and syncronizer ring], has to be clutched to shift at WOT. A planetary trans, [Like Lenco], can be shifted without the clutch.
Speed shifting is when you shift without the clutch, you pull out of gear as you let off the gas and when the engine RPM drops to the right speed it will pop into next gear. That was called speed shifting and was common before the invention of syncronizers. It is very slow but must of been faster to do that way before syncronizers.
Herb Mclandless needs to chime in on this one as I am sure he ran stick S/S cars.
I have seen several old in car drag strip films from the sixtys and you could see the driver bounce the clutch as he was rowing through the gears.
Re: Power Shift my 4-speed? [Re: toddd] #493736
10/12/09 12:57 AM
10/12/09 12:57 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Your clutchs' in-ability to slip.
For sure the posters problem with 60 ft. If you had a 5.88 rear gear and a 3.09 low gear in trans. you could probably side step the clutch.
You cant just dump the clutch. You need to let it out in stages. I have made a couple passes in my SRT-8 Challenger and let it out in 3 stages. Dumping it all at once was a horible 2.11 60 ft. Then in stages I got a 2.00 60 ft. Motor still bogged so next trip I will try a higher RPM and hopefully not find tire spin. Car went 13.20 at 108.50 MPH with the 2.11 60ft. On the 2nd pass with the 2.00 60 ft. I missed 2nd gear, and the staging lane were closed so I wont get another chance until tommorow.
Re: Power Shift my 4-speed? [Re: qwkmopardan] #493737
10/12/09 01:10 AM
10/12/09 01:10 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Like I said, I'm sure that there is many different nicknames for shifting styles, just like for posi units and rear carriers. Posi, Traction Loc, Suregrip, Limited Slip, Pumpkin, Chunk, 3Rd Member, etc. I'm simply explaining what we called it, after someone else brought it up. I do remember my uncle shifting his 68 GTX with a well prepped Hemi box many times; no clutch or lift on 1-2, tap clutch and no lift on 2-3, and no clutch or lift on 3-4. After the vertical gates became popular, it was "Full Monty" on all of them. Brutal on trans, and it helped that he never had todays tires, and he still broke a lot of parts. As for me, I cleaned out 2nd on about my third try at powershifting my 66 T-10 Mustang, and since I didn't have the deep parts bin that he did, I went the more economcal way and did what WE called speedshifting - toe clutch with gas floored, pull handle, repeat as necessary.
Re: Power Shift my 4-speed? [Re: qwkmopardan] #493738
10/12/09 01:19 AM
10/12/09 01:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You can just dump the clutch with enough gear and good tires that hook. I did it all the time when I raced my 4-speed Dart with 4.56's and 28" slicks. But most street cars you have to do as you stated. My sons SRT-4 would spin the BF drag radials on it as it had an open diff and I got better times then anyone else out of it by working the clutch. The trick was to launch as fast as you can without any tire spin. It took a few practice runs to nail it down. Ron
Re: Power Shift my 4-speed? [Re: Evil Spirit] #493739
10/12/09 01:48 AM
10/12/09 01:48 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Am I wrong in thinking your shifting has nothing to do with the 60' due to the fact that you should cover that first 60' in first gear or darn close to it. The only experience I have with shifting quickly is watching my instructor at school (I've since graduated, long long time ago it seems, where does the time go?) shift his 99 camaro with a jerico transmission. I know they had a clutch with adjustable spring pressure points and they would crawl under it at the track to get the right amount of slippage without it being excessive or too tight and bogging the motor.
Here's a video, I know it's not a mopar, but this thing is impressive being N/A and a 4 gear stick.
http://www.youtube.com/watch?v=3y6ZgKte3PY&feature=related
Re: Power Shift my 4-speed? [Re: dodgeboy11] #493740
10/12/09 09:57 AM
10/12/09 09:57 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Post deleted by moparts [Re: SCATPK] #493741
10/12/09 11:51 AM
10/12/09 11:51 AM
Re: Power Shift my 4-speed? [Re: qwkmopardan] #493742
10/12/09 01:11 PM
10/12/09 01:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You don't forget. It's just like riding a bike or Sex once you do it once you never forget how.
Just get out of practice, On both counts - don't ask!
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Power Shift my 4-speed? #493743
10/12/09 02:05 PM
10/12/09 02:05 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Here is an in car video of my Brother in Law Emilio (Mr5Speed) rowing Five.
http://video.cardomain.com/VideoPlayer.aspx?id=651959
Looks just like me in my car, Not!
Very cool video and a good look on what is going on inside the car to get it down the track.
Re: Power Shift my 4-speed? [Re: SCATPK] #493744
10/12/09 02:10 PM
10/12/09 02:10 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
As far as my 60ft time is concerned I dont think my shifting has anything to do with it as I should cover it in 1st gear. Again it seems like there are many opinions on how to shift a manual trans car and many different ways to break parts. I have avoided breaking anything and would like to keep it that way so I will proceed with caution on my next outing at the track.
Re: Power Shift my 4-speed? [Re: SCATPK] #493745
10/12/09 06:51 PM
10/12/09 06:51 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Herb, I think you should dump those MT radials and get yourself some MT ET Streets. The ET Streets are a very sticky tire. I drove a buddies set on the street and noticed a big difference compared to my MT Radials The radials are a good street tire but in my opinion are not good for the track for traction. I also think that if you want to hit your mark at the track, you should go with 4:10s in the rear. I know you want to keep it stock looking but for a better 60' time, you should consider some Caltracs.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Power Shift my 4-speed? [Re: SCATPK] #493746
10/12/09 10:28 PM
10/12/09 10:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think powershifting would pick you up 2 or 3 tenths -
It'll be hard on parts.
Re: Power Shift my 4-speed? [Re: Evil Spirit] #493747
10/13/09 12:08 PM
10/13/09 12:08 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
I remember using the same shifting terminology, but have been trying for a few days to remember the modifications made for power shifting. I think you did some welding here and grinding there but am really drawing a black. I am pretty sure Rick Allison built a few (or many).
Re: Power Shift my 4-speed? [Re: BSB67] #493748
10/13/09 01:28 PM
10/13/09 01:28 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Wow, that charger of yours sure runs the number!
