Page 1 of 3 1 2 3
700 HP small block #491470
10/08/09 09:30 AM
10/08/09 09:30 AM
nc
E
emarine01 Offline OP
E
nc
Any 59* 700 hp combos around, whats it take to do? Is there a point of no return on the 59* block?
Re: 700 HP small block [Re: emarine01] #491471
10/08/09 09:52 AM
10/08/09 09:52 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I'm sure there has to be a W2 or W5 headed 59* that has turbos that is doing it...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 700 HP small block [Re: emarine01] #491472
10/08/09 09:58 AM
10/08/09 09:58 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
If your not afraid of turning some rpm, you could do it with an all motor deal.
Re: 700 HP small block [Re: emarine01] #491473
10/08/09 11:33 AM
10/08/09 11:33 AM
SoCal
Brian Hafliger Offline
SoCal
Both W2Stroker and DiegoTed have near 700HP engines we built a couple of years ago.
Ted's made 678 and Martin's made 685.
4" cranks, 59° R blocks, 13:1, roller cams, one had Indy cnc -2 heads the other my ported Batten W2 heads, Indy intakes and 1050 dominators.
No special ring stack, no vacume pumps or other trick parts. Both used an 1 7/8 header.
The cams were NOS cams, so there was a little HP left on the table but probably only 20Hp maybe?
Both engines were built with RELIABILITY in mind and not pushed hard to make HP.
Brian Hafliger
Re: 700 HP small block [Re: emarine01] #491474
10/08/09 11:36 AM
10/08/09 11:36 AM
an8sec70cuda Offline
I'm not 100% sure, but I think Johnny Pennington's small block fits what you described. He's from Lexington, SC. Blue with purple stripes Dodge Dart running 9.60s. CHIP
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: 700 HP small block [Re: StrokerAspen] #491475
10/08/09 11:44 AM
10/08/09 11:44 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Find a old R5 bucsh motor you will be way ahead and a lot cheaper
Re: 700 HP small block [Re: emarine01] #491476
10/08/09 12:25 PM
10/08/09 12:25 PM
ggddemon Offline
ggddemon  Offline
I have a 2880lb./ 59*/ r-3 /w-9 glide setup this year, worked o.k...did a best of 6.04@113 in the 660'and 1 run in the 1320 was 9.64@138- old setup was a eddy top end that did 6.26@109 in the 660'
Re: 700 HP small block [Re: ggddemon] #491477
10/08/09 12:45 PM
10/08/09 12:45 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
My old combo ran pretty good. Drysump W5's with sheetmetal intake and Enderle alky injection. Ran 9.0s at 149 2600lb. Dyno sheet showed 741hp but the "mob" here accuses Bill Richardson's dyno as being happy one?
All I know it was a great motor that ran hard for 3+ years.
Re: 700 HP small block [Re: ggddemon] #491478
10/08/09 12:47 PM
10/08/09 12:47 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Personally, i dont see a 59 degree head(except the latest and best indy head)making an honest 700 ponies, based on the old "riders dyno" benchmark.
I know w5's wont do it, w2 wont, the b1ba and eddies wont, so that leaves some sort of 245 indy head as the only way of getting there
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.54 @ 105.20
Re: 700 HP small block [Re: MegaDart] #491479
10/08/09 12:50 PM
10/08/09 12:50 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
A friend went 9.0's at 2450 in a 70 cuda just on gas with little b1ba heads. We figured at that weight he was about 620 real horsepower. So you were about 150 pounds heavier than he was.
1.41 best 60 foot
6.54 @ 105.20
Re: 700 HP small block [Re: B3422W5] #491480
10/08/09 01:42 PM
10/08/09 01:42 PM
SoCal
SoCal
I believe our dyno to be "accurate". My engine made 560HP and runs 10.50's in 2500d.a. air in my 3320lb. duster with me in it.
MPH is usually 125-126.
To me, that's pretty accurate "comparing" other engines I dyno vs. customers cars.
Most combo's that don't "perform" as they dyno suggests are most likely lacking in the chassis and 60ft. over the dyno.
My car has gone 1.37-1.3960ft. Usual is 1.41.
I'm sure that when our dyno reads close to 700HP, it's accurate. I can't speak for anyone else's dyno but knowing what your dyno #'s read vs. in car performance vs. the chassis combo is KEY to getting the car to do whatever the customer wants it to do.
Indy heads flow well, and I find it hard to believe that you think 700HP is unattainable by them in all but the biggest port they offer!
But your allowed to "think" whatever you want...
Brian Hafliger
Re: 700 HP small block [Re: Brian Hafliger] #491481
10/08/09 02:07 PM
10/08/09 02:07 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
don,t really like indy stuff, but the heads are ready avalible,not really sure about the INDY RP. you will have to talk to ryan, the 449 ryan built me was well over the 700hp.just make sure you don't deal direct with them,service is not a favor, they just think that way, IMHO.
If my memory serves correctly ,my engine was suppose to be built at the beginning with a set of w9 ab's, with lots of CSA, and we were going to be using a tall deck 48* r3 with a max bore,but heyy!!! those blocks are pigs... that stoped me from going that route, then i scored a nice brand new in the box x block,and we went from there, Ryan built me this complete top set up from ICH....not bad for a true 59* block at 770hp and 615 torque. gilberto
Re: 700 HP small block [Re: SB449VALIANT] #491482
10/08/09 02:26 PM
10/08/09 02:26 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
My only comment is, run the car, weigh the car and stop speculating. The number won't lie. You might not like it, but that's another story.
Re: 700 HP small block [Re: Leigh] #491483
10/08/09 02:36 PM
10/08/09 02:36 PM
Mcallen, TX
Mcallen, TX
speculate this...
Will be 449 cubic inches, Should make around 730-740 HP @ 7200 RPM, 610-620 TQ @ 5100 RPM
@ 2700 lbs 8.90 @ 152
@ 2600 lbs 8.80 @ 154
@ 2500 lbs 8.70 @ 156
Re: 700 HP small block [Re: SB449VALIANT] #491484
10/08/09 02:46 PM
10/08/09 02:46 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I guess someone's touchy. Post a time slip and a scale receipt, since you're so ornery. My reply was actually hinted at another poster, but since you're up to bat, so be it.
Re: 700 HP small block [Re: Leigh] #491485
10/08/09 02:53 PM
10/08/09 02:53 PM
Mcallen, TX
Mcallen, TX
back to the orininal post, just trying to help/learn...get it
Re: 700 HP small block [Re: SB449VALIANT] #491486
10/08/09 02:58 PM
10/08/09 02:58 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Please, let's only talk about first hand experience here, not a friend of a friend blah, blah, blah. You know all racers are liars he probaby weighs 2200lb!!lol And we are supposed to believe someone who list there car as having "bicycle tires" does that is some weird way make you feel good??
fyi, my car actually weighed 2650+ lbs, had a huge frontal area and burned up high gear clutches when it ran those #'s. Ask Laverne, he saw the trans first hand. things the Moroso calculator can not figure in...
Amen to that!
I think ou812 has a clue
Re: 700 HP small block [Re: MegaDart] #491487
10/08/09 03:27 PM
10/08/09 03:27 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Your HP computed from your vehicle ET is 629.68 rear wheel HP and 699.64 flywheel HP.
Your HP computed from your vehicle MPH is 586.31 rear wheel HP and 651.45 flywheel HP.
that is straight off of Wallace calculator with 9.08 149 and 2650lb data entered.
How can you NOT believe a good W5 can make 700ponies? BillR could do it in his sleep.
Re: 700 HP small block [Re: MegaDart] #491488
10/08/09 03:59 PM
10/08/09 03:59 PM
Finland
mafo Offline
mafo  Offline
Finland
My old motor had really radical batten w2`s(340cfm)on a x-block 4,10x3,42,dual dominators and dry sump(no vacum pump)
Best et was 9,39@143 in a 2900 pound Valiant on dot tires
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: 700 HP small block [Re: mafo] #491489
10/08/09 04:45 PM
10/08/09 04:45 PM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
I beleive 700 can come from a set of W-5's,
Page 1 of 3 1 2 3
