Re: 700 HP small block
[Re: instigator]
#491491
10/08/09 05:56 PM
10/08/09 05:56 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
Wallaces calculator says I make 1108 flywheel hp to run 128mph in the 1/8th at 3400lbs!
59deg 408ci edelbrock heads.
which calculator and what was the ET??
[Re: MegaDart]
#491492
10/08/09 06:07 PM
10/08/09 06:07 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
A friend went 9.0's at 2450 in a 70 cuda just on gas with little b1ba heads. We figured at that weight he was about 620 real horsepower. So you were about 150 pounds heavier than he was.
Please, let's only talk about first hand experience here, not a friend of a friend blah, blah, blah. You know all racers are liars he probaby weighs 2200lb!!lol And we are supposed to believe someone who list there car as having "bicycle tires" does that is some weird way make you feel good??
fyi, my car actually weighed 2650+ lbs, had a huge frontal area and burned up high gear clutches when it ran those #'s. Ask Laverne, he saw the trans first hand. things the Moroso calculator can not figure in...
But your allowed to "think" whatever you want...
Amen to that! I think ou812 has a clue
No, its not idle talk, and many members on here are intimately familiar with the car, its weight, and its combo.He racedit at many Classi events in super pro, and at 131 forever.
It is soon to come back out with a w9 motor Best machine built and Dyno'ed that makes the kinda power your "w5 motor" made..We will see how far in the 8's it runs on gas.
So if your car at 150 pounda heavier ran the same numberS on injected alky as his diD, you are way off at 741 ponies.
This very subject was beat to death on one of Ryans thread several years ago, .
Your car ran good, but 741 horse is a dream you need to let go of one of these years, Wayne.
[Re: instigator]
#491494
10/08/09 06:27 PM
10/08/09 06:27 PM
MegaDart
The Swamp
Your HP computed from your vehicle ET is 954.08 flywheel HP and 858.672 rear wheel HP. Your HP computed from your vehicle MPH is 1,108.08 flywheel HP and 0.9 rear wheel HP
your car is awesome instigator but I am not sure why the 0.9 rear wheel HP on the calculator??
whatever Don. I certainly don't want to relive that pissin' match anytime soon.
emarine, it is absolutely possible. Call Bill Richardson at RAM racing if you need some ideas. He had forgotton more about sbm's then most here ever knew...
[Re: an8sec70cuda]
#491495
10/08/09 09:28 PM
10/08/09 09:28 PM
Posts: 125 Lexington South Carolina
johnnyp
I'm not 100% sure, but I think Johnny Pennington's small block fits what you described. He's from Lexington, SC. Blue with purple stripes Dodge Dart running 9.60s. CHIP
Thanks for thowing mine in to the mix, Chip But I have nothing for any of these cars in this post my car weighs to much for them.
[Re: B3422W5]
#491496
10/08/09 09:36 PM
10/08/09 09:36 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Personally, i dont see a 59 degree head(except the latest and best indy head)making an honest 700 ponies, based on the old "riders dyno" benchmark.
I know w5's wont do it, w2 wont, the b1ba and eddies wont, so that leaves some sort of 245 indy head as the only way of getting there
The only way to go
[Re: emarine01]
#491497
10/08/09 10:42 PM
10/08/09 10:42 PM
Posts: 293 Michigan
ccarson
420 CU IN, W9, 13:1 Comp, .728 lift Roller, 280 Dur.@50 yes it can be done but I wish we would have went with a 48 Deg Block.
[Re: ccarson]
#491498
10/08/09 11:33 PM
10/08/09 11:33 PM
Posts: 1,745 Maryland
340_Dart
Maryland
420 CU IN, W9, 13:1 Comp, .728 lift Roller, 280 [Email]Dur.@50[/Email]
I know this will probably be a stupid question, but what would the advantage have been if you used a 48* block? The only difference is the valvetrain is more stable at high rpm, correct?
[Re: emarine01]
#491499
10/08/09 11:52 PM
10/08/09 11:52 PM
Posts: 243 NJ
arc
NJ
[Re: B3422W5]
#491500
10/09/09 12:02 AM
10/09/09 12:02 AM
Posts: 374 kalamazoo, MI.
VIPERDUST
kalamazoo, MI.
Yes the car went 9.03@146, and weighs 2450, all with 400 cubes and b1 heads. So B3 was right.
[Re: ccarson]
#491502
10/09/09 01:07 AM
10/09/09 01:07 AM
Posts: 2,864 IN
Irun5snd8th
IN
According to the calculators my car has to be making near 620 HP to push 3000 lbs to 9.80's at 133. I have eddies on mine so I seriously cannot believe that it would be that difficult to get 700 out of a good set of heads.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: emarine01]
#491505
10/09/09 08:17 AM
10/09/09 08:17 AM
Posts: 506 Texas Afghanistan Iraq etc.
DakFink
Any 59* 700 hp combos around, whats it take to do? Is there a point of no return on the 59* block?
There are a few around. I don't know any personally but run across them occasionally.
What it takes??
Well that all depends on what your after and how much $$$$ you want to spend.
You want N/A, Nitrous or Boost????
Why are you sticking with a 59* block? If you already have a Block understandable. If your starting from scratch might as well get a 48* if you can. Easier head options available to work with.
Point of No Return. I guess your really asking HP limit. Well that all depends? What block you use, how you make that power and what you use it for.
There are at least 3-4 Flavors of 59* block that I know of (maybe more) Factory LA, Magnum R-3, Resto-Blocks and the X-Block can all be had in 59* flavor as far as I know.
As far as the easiest way to get a 700+hp Mopar Small Block. As was stated!! R5-P7 Nascar Motor.
Not sure how much they are going for now, but they were about $6500 complete and running about 2 yrs ago. Granted that was NASCAR Running. Not something you would put straight into a driver.
If your looking to build? There are some top-notch builder on here.
If your just curious?! Might want to check out some other Mopar pages as well.
[Re: jim sciortino]
#491507
10/09/09 10:24 AM
10/09/09 10:24 AM
B3422W5
Portage,michigan
I find it hard to believe that a 400+ ci W-5 couldn't hit an honest 700.
Not meaning to brag, but i think my W5 motor runs as good as pretty much anybodies around.
I have pretty much stock suspension, cheap shocks, and have been almost 135 at 3350 pounds with a 727.
I MIGHT be at 640 honest horse. I think with a hair bigger cam and a better set of headers there might be another 20-30 horse there, but i dont see 60. I might be wrong.
throw alky at it, it might get closer, i am sure.
