Page 2 of 3 1 2 3
Re: 700 HP small block [Re: Dustedu] #491490
10/08/09 04:49 PM
10/08/09 04:49 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Wallaces calculator says I make 1108 flywheel hp to run 128mph in the 1/8th at 3400lbs!
59deg 408ci edelbrock heads.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: 700 HP small block [Re: instigator] #491491
10/08/09 04:56 PM
10/08/09 04:56 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
which calculator and what was the ET??
Re: 700 HP small block [Re: MegaDart] #491492
10/08/09 05:07 PM
10/08/09 05:07 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
A friend went 9.0's at 2450 in a 70 cuda just on gas with little b1ba heads. We figured at that weight he was about 620 real horsepower. So you were about 150 pounds heavier than he was.
Please, let's only talk about first hand experience here, not a friend of a friend blah, blah, blah. You know all racers are liars he probaby weighs 2200lb!!lol And we are supposed to believe someone who list there car as having "bicycle tires" does that is some weird way make you feel good??
fyi, my car actually weighed 2650+ lbs, had a huge frontal area and burned up high gear clutches when it ran those #'s. Ask Laverne, he saw the trans first hand. things the Moroso calculator can not figure in...
But your allowed to "think" whatever you want...
Amen to that!
I think ou812 has a clue
No, its not idle talk, and many members on here are intimately familiar with the car, its weight, and its combo.He racedit at many Classi events in super pro, and at 131 forever.
It is soon to come back out with a w9 motor Best machine built and Dyno'ed that makes the kinda power your "w5 motor" made..We will see how far in the 8's it runs on gas.
So if your car at 150 pounda heavier ran the same numberS on injected alky as his diD, you are way off at 741 ponies.
This very subject was beat to death on one of Ryans thread several years ago, .
Your car ran good, but 741 horse is a dream you need to let go of one of these years, Wayne.
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.54 @ 105.20
Re: 700 HP small block [Re: MegaDart] #491493
10/08/09 05:15 PM
10/08/09 05:15 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
http://www.wallaceracing.com/hpcalculatoreigth.php
5.65 at 128mph at 3400 lbs
65 Barracuda
Re: 700 HP small block [Re: instigator] #491494
10/08/09 05:27 PM
10/08/09 05:27 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
Your HP computed from your vehicle ET is 954.08 flywheel HP and 858.672 rear wheel HP.
Your HP computed from your vehicle MPH is 1,108.08 flywheel HP and 0.9 rear wheel HP
your car is awesome instigator but I am not sure why the 0.9 rear wheel HP on the calculator??
whatever Don. I certainly don't want to relive that pissin' match anytime soon.
emarine, it is absolutely possible. Call Bill Richardson at RAM racing if you need some ideas. He had forgotton more about sbm's then most here ever knew...
Re: 700 HP small block [Re: an8sec70cuda] #491495
10/08/09 08:28 PM
10/08/09 08:28 PM
Lexington South Carolina
johnnyp Offline
johnnyp  Offline
I'm not 100% sure, but I think Johnny Pennington's small block fits what you described. He's from Lexington, SC. Blue with purple stripes Dodge Dart running 9.60s. CHIP
Thanks for thowing mine in to the mix, Chip But I have nothing for any of these cars in this post my car weighs to much for them.
Re: 700 HP small block [Re: B3422W5] #491496
10/08/09 08:36 PM
10/08/09 08:36 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Personally, i dont see a 59 degree head(except the latest and best indy head)making an honest 700 ponies, based on the old "riders dyno" benchmark.
I know w5's wont do it, w2 wont, the b1ba and eddies wont, so that leaves some sort of 245 indy head as the only way of getting there
The only way to go
Re: 700 HP small block [Re: emarine01] #491497
10/08/09 09:42 PM
10/08/09 09:42 PM
ccarson Offline
ccarson  Offline
420 CU IN, W9, 13:1 Comp, .728 lift Roller, 280 Dur.@50
yes it can be done but I wish we would have went with a 48 Deg Block.
Re: 700 HP small block [Re: ccarson] #491498
10/08/09 10:33 PM
10/08/09 10:33 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
420 CU IN, W9, 13:1 Comp, .728 lift Roller, 280 [Email]Dur.@50[/Email]
I know this will probably be a stupid question, but what would the advantage have been if you used a 48* block? The only difference is the valvetrain is more stable at high rpm, correct?
Re: 700 HP small block [Re: emarine01] #491499
10/08/09 10:52 PM
10/08/09 10:52 PM
NJ
arc Offline
arc  Offline
NJ
here is a w5 i did 2 years ago ryan did the heads it is a 408 https://board.moparts.org/ubbthreads/upload2/3356582-Project1.png
Re: 700 HP small block [Re: B3422W5] #491500
10/08/09 11:02 PM
10/08/09 11:02 PM
kalamazoo, MI.
VIPERDUST Offline
VIPERDUST  Offline
kalamazoo, MI.
Amen to that!
Yes the car went 9.03@146, and weighs 2450, all with 400 cubes and b1 heads. So B3 was right.
Re: 700 HP small block [Re: 340_Dart] #491501
10/08/09 11:44 PM
10/08/09 11:44 PM
ccarson Offline
ccarson  Offline
Their are No Stupid questions: the 48 Deg Block does straighten out the pushrods, it also gets the pushrods away from the outer wall of the intake port which allows more agressive porting.
Our W9 Heads have large notches on the outer wall of the intake port for pushrod clearance on a 59 Deg. block.
Re: 700 HP small block [Re: ccarson] #491502
10/09/09 12:07 AM
10/09/09 12:07 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
According to the calculators my car has to be making near 620 HP to push 3000 lbs to 9.80's at 133. I have eddies on mine so I seriously cannot believe that it would be that difficult to get 700 out of a good set of heads.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: 700 HP small block [Re: Irun5snd8th] #491503
10/09/09 04:34 AM
10/09/09 04:34 AM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
Just curious what do you think my engine would dyno??? stroked to 408,stock 360 block with INDY, hand ported 360-2 heads,car run a best of 9.16 at 145 mph with 1.26 60fts, race weight 2,800 lbs... Jim
Re: 700 HP small block [Re: emarine01] #491504
10/09/09 07:12 AM
10/09/09 07:12 AM
utica ny
meus31 Offline
meus31  Offline
utica ny
Well i think it depends on how set on kill the motor is . a customer of mine had ray barton build him a 9 inch deck height 440 r3 small block . now i know yes it is a 48 degree block . but it has 4 year old indy -1s not the new raised port stuff but i know ray did a considerable amount more port work after receiving them from indy. its 14 to 1 on c 16 single dominator but it has a very low drag ring pack motor made peak power at 6900 and was 754 i forget what the torque was . car has 1 7/8 to 2 to 2 1/8 step headers 30 inches long with merge collectors and a vacumn pump and such . car weighs 2925 with driver and has run a best of 9.09 at 146 with a 1.23 sixty foot. this has been a killer motor no problems for three years racing two classes every weekend. its a 67 valiant back half car with a full stock interior still except the back seat and a 904 to . by the way know problems with the tranny either .
Re: 700 HP small block [Re: emarine01] #491505
10/09/09 07:17 AM
10/09/09 07:17 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Any 59* 700 hp combos around, whats it take to do? Is there a point of no return on the 59* block?
There are a few around. I don't know any personally but run across them occasionally.
What it takes??
Well that all depends on what your after and how much $$$$ you want to spend.
You want N/A, Nitrous or Boost????
Why are you sticking with a 59* block? If you already have a Block understandable. If your starting from scratch might as well get a 48* if you can. Easier head options available to work with.
Point of No Return. I guess your really asking HP limit. Well that all depends? What block you use, how you make that power and what you use it for.
There are at least 3-4 Flavors of 59* block that I know of (maybe more) Factory LA, Magnum R-3, Resto-Blocks and the X-Block can all be had in 59* flavor as far as I know.
As far as the easiest way to get a 700+hp Mopar Small Block. As was stated!! R5-P7 Nascar Motor.
Not sure how much they are going for now, but they were about $6500 complete and running about 2 yrs ago. Granted that was NASCAR Running. Not something you would put straight into a driver.
If your looking to build? There are some top-notch builder on here.
If your just curious?! Might want to check out some other Mopar pages as well.
Re: 700 HP small block [Re: DakFink] #491506
10/09/09 09:00 AM
10/09/09 09:00 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I find it hard to believe that a 400+ ci W-5 couldn't hit an honest 700.
Re: 700 HP small block [Re: jim sciortino] #491507
10/09/09 09:24 AM
10/09/09 09:24 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Not meaning to brag, but i think my W5 motor runs as good as pretty much anybodies around.
I have pretty much stock suspension, cheap shocks, and have been almost 135 at 3350 pounds with a 727.
I MIGHT be at 640 honest horse. I think with a hair bigger cam and a better set of headers there might be another 20-30 horse there, but i dont see 60. I might be wrong.
throw alky at it, it might get closer, i am sure.
1.41 best 60 foot
6.54 @ 105.20
Re: 700 HP small block [Re: emarine01] #491508
10/09/09 09:48 AM
10/09/09 09:48 AM
New Haven County CT
Mr 5 Speed Offline
Mr 5 Speed  Offline
New Haven County CT
My Duster is a stock block stroked to 393 inches. Ran 9.63 last weekend at 139. It weighs 3230 with me. This combo has been together (freshened every other year) for over 14 years. I don't race a dyno but on the calculators that some of you have posted up, I'm over the requested HP.
http://www.cardomain.com/ride/2468359
Re: 700 HP small block [Re: Mr 5 Speed] #491509
10/09/09 09:57 AM
10/09/09 09:57 AM
K
KOS Offline
KOS  Offline
K
no dyno time but 137mph @3400lbs stock suspension dart 727 dana 60 with 11%converter slip.cnc 230s under 440".i think it would make 700hp on most dynos.
Page 2 of 3 1 2 3
