Page 3 of 3 1 2 3
Re: Building Pro Street Hemi Cuda [Re: cogen80] #489949
10/15/09 10:34 PM
10/15/09 10:34 PM
South Mississippi
70bbeep Offline OP
70bbeep  Offline OP
South Mississippi
I'm assumeing the block has hemi mounts because it is sitting on the k-frame with schoemacher (bad spelling) rubber mounts. I didn't want the motor plate because of the vibration, but I do like the idea of centering the engine. If I used an Alter-K-tion frame wouldn't that solve the clearance problems?
I wasn't thinking about header clearance. Sounds like I need to go ahead and buy some for mock-up.
Also need info on the front of the engine, such as water pump, alternator brackets, and fan pulleys or elec fan???
Re: Building Pro Street Hemi Cuda [Re: 70bbeep] #489950
10/16/09 06:10 AM
10/16/09 06:10 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
my engine ended up centered based on the header fitment. I have Hooker Super Comps and they are pretty big and take up some room. I did not have to ding them, but torsion bars would have killed me trying to get these to fit. I run a MF system. My goal was to get it closer to center so I could get the passenger valve cover off. Like you said, pick up a set now, and figure out where it will land becuase it will help sort it out.
As for the engine accessories...That's easy, see pic.
Re: Building Pro Street Hemi Cuda [Re: Dragula] #489951
10/16/09 06:59 AM
10/16/09 06:59 AM
Netherlands
72Challenger Offline
Netherlands
In my Challenger I had the hemi in the stock location on shumacher mounts without a problem. I slightly notched the passenger side valve cover but eveything else, including hooker s/c 2.1/8 headers fitted without a problem.
I guess if you really want to get it centered you'll run into problems with the firewall and trans tunnel. With my 4-speed the bellhousing already was very close to the firewall / tunnel, would not be able to move it an inch.
Re: Building Pro Street Hemi Cuda [Re: 72Challenger] #489952
10/16/09 01:01 PM
10/16/09 01:01 PM
Dragula Offline
Dragula  Offline
Mine had no issues with the firewall or the trans tunnel and I run a JW ultra bell which is thicker than stock. My only reason was valve cover clearance on the passenger side, and I could not move it further due to one of the header tubes that kicks out under the frame rail to go around the torsion bar. It also helped the launch because the left front stays more even than it did in the past.
Re: Building Pro Street Hemi Cuda [Re: Dragula] #489953
10/16/09 04:15 PM
10/16/09 04:15 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Heres my Pro Street Cuda...
Re: Building Pro Street Hemi Cuda [Re: mopar_mark] #489954
10/16/09 04:53 PM
10/16/09 04:53 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mark,how 'bout an update on your car!Have you made a pass yet??Have you at least been out terrorizing the fine citizens of London England??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Building Pro Street Hemi Cuda [Re: hemi-itis] #489955
10/18/09 01:28 PM
10/18/09 01:28 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Yeah, still terrororising the neighbourhoods
Went to the track the this weekend, still need to get a handle on getting it to leave the hole, 60ft times are attrocius (1.40's-1.60's )
Best run was 9.12 @150mph, 1.42's 60 ft.
At least heading in the right direction, that was in full street trim, excluding the slicks
Re: Building Pro Street Hemi Cuda [Re: mopar_mark] #489956
10/18/09 02:54 PM
10/18/09 02:54 PM
hemi-itis Offline
hemi-itis  Offline
That's at half throttle Waiting on your new thread with VIDIO!
Re: Building Pro Street Hemi Cuda [Re: mopar_mark] #489957
10/19/09 06:34 PM
10/19/09 06:34 PM
South Mississippi
70bbeep Offline OP
70bbeep  Offline OP
South Mississippi
Mopar Mark, All I can say is --- DAAAAM thay's one wicked looking cuda. Any videos of it running and driving?
Re: Building Pro Street Hemi Cuda [Re: 70bbeep] #489958
10/19/09 06:40 PM
10/19/09 06:40 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Mark , as you drive it on the street, who insures that ride? That sure is a beauty.
Re: Building Pro Street Hemi Cuda [Re: rowin4] #489959
10/19/09 09:32 PM
10/19/09 09:32 PM
hemi-itis Offline
hemi-itis  Offline
Prince Charles
Post deleted by Defbob [Re: hemi-itis] #489960
10/19/09 09:54 PM
10/19/09 09:54 PM
Re: Building Pro Street Hemi Cuda #489961
10/21/09 10:26 PM
10/21/09 10:26 PM
South Mississippi
70bbeep Offline OP
70bbeep  Offline OP
South Mississippi
That Cuda looks like a Pro Mod car. I bet its fun to drive.
Where is the best place to buy hemi engine parts? I could buy from the engine machine shop that I choose to build it or I could look for used or never used parts on the net, like here on this board or ebay or racing junk. Any thoughts?
Re: Building Pro Street Hemi Cuda [Re: 70bbeep] #489962
10/22/09 04:34 AM
10/22/09 04:34 AM
Dragula Offline
Dragula  Offline
Most likely, your going to end up buying the parts you need new. Used hemi parts, good used hemi parts, seem to be difficult to get lately. Been looking for a few myself.
I also like the Pro-Mod Cuda shown. Mine is only a 780hp Pro-street Cuda and that thing is just wicked. Can't believe how mild the idle is. I would trade my engine for somthing like that in a heart beat, just awesome.
Re: Building Pro Street Hemi Cuda [Re: mopar_mark] #489963
10/22/09 04:53 AM
10/22/09 04:53 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
Hi Mark,
The fun thing in this story, we have the same chassis builder, and the Mark's car was built just after mine (in '96 !)
Here is a Youtube link where we are together, hope your chassis gremlins are gone !
http://www.youtube.com/watch?v=BqrDo_pe53Q
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me Run 8.04" / 168 mph 1.11" 60 ft Fastest Mopar at the Euro Mopar Nats website : http://vantastic-racing.com/
Page 3 of 3 1 2 3
