Whats wrong with this pic #488743
10/05/09 10:44 AM
10/05/09 10:44 AM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
Taken at Norwalk, have not touched the ladder bars, and the car has been going left all year.
Re: Whats wrong with this pic [Re: CRT] #488744
10/05/09 10:46 AM
10/05/09 10:46 AM
an8sec70cuda Offline
How old are the tires? CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Whats wrong with this pic [Re: an8sec70cuda] #488745
10/05/09 10:47 AM
10/05/09 10:47 AM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
New this year , May I put them on, They have about 80 passes
Re: Whats wrong with this pic [Re: CRT] #488746
10/05/09 10:54 AM
10/05/09 10:54 AM
So did it start going left when you put the new tires on in May? Or was it doing it prior to the tire change? CHIP
CHIP
Re: Whats wrong with this pic [Re: an8sec70cuda] #488747
10/05/09 10:55 AM
10/05/09 10:55 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Did you check the rollout on the tires??? Maybe a wheel got bent on install?
Re: Whats wrong with this pic [Re: Al_Alguire] #488748
10/05/09 10:57 AM
10/05/09 10:57 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Twisted/turned axle tube? Weak shock?
Re: Whats wrong with this pic [Re: CRT] #488749
10/05/09 10:58 AM
10/05/09 10:58 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
If you get the chance this year yet I would try to swap the tires side to side and see what effect you end up with.
You may have one tire that is slightly different in circumfrence than the other.
Did you have this issue when the tires were first installed?
If you see a difference then I think you have a tire issue. Just my
Re: Whats wrong with this pic [Re: RemCharger] #488750
10/05/09 11:01 AM
10/05/09 11:01 AM
Hemiroid Offline
Hemiroid  Offline
I'd be looking here as well.
Re: Whats wrong with this pic [Re: Al_Alguire] #488751
10/05/09 11:02 AM
10/05/09 11:02 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
first thing came to my mind
Re: Whats wrong with this pic [Re: roadhazard] #488752
10/05/09 11:05 AM
10/05/09 11:05 AM
Cedar Lake IN
CRT Offline OP
CRT  Offline OP
Cedar Lake IN
ya know, I did not check the rollout on the tires (MTs 29.5 X 10.5w) and the shocks are 10+ years old, At Norwalk this year, one pass its in the air and to the left, next pass, the tires slip. This is get worse as the year when on, But after looking at the pic, I did not realize just how bad it was going left.
Re: Whats wrong with this pic [Re: CRT] #488753
10/05/09 11:11 AM
10/05/09 11:11 AM
ky
68roadrunner Offline
ky
mickeys are the worst on rollout. you have to measure, you can't go by the #'s on them.
Re: Whats wrong with this pic [Re: CRT] #488754
10/05/09 11:12 AM
10/05/09 11:12 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
John - the first thing wrong with the pic is that is is blurry.....lol
Re: Whats wrong with this pic [Re: CRT] #488755
10/05/09 11:13 AM
10/05/09 11:13 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You're still in your lane!
If all else fails just aim it to the RIGHT!
Just kidding!! Has to be something simple IMO
Re: Whats wrong with this pic [Re: roadhazard] #488756
10/05/09 11:17 AM
10/05/09 11:17 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I assume it has a spool, not a SureGrip?
Re: Whats wrong with this pic [Re: CRT] #488757
10/05/09 11:22 AM
10/05/09 11:22 AM
John,
Checking the rollout should be the next thing you do. Or you can just swap em side to side at the track and see if it goes the other way. Then you know the tires are the issue.
If that checks out fine, then start looking for twisted or bent parts, lol. CHIP
CHIP
Re: Whats wrong with this pic [Re: an8sec70cuda] #488758
10/05/09 11:36 AM
10/05/09 11:36 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Checkin the rollout is easy and certainly won't hurt. However, I have had a mismatched rollout in the past and this does not appear to be the case here. When I experienced the rollout issue I had to [Edited by Moparts - Family Friendly Site - Keep it clean] the wheel to get the car to go straight when I was driving it through the pits or down the track. And it definitely did not leave like what you are showing here. If you are not cockin the wheel then I would say your issue is elsewhere. A bad shock could definitely cause this. I have piloted a car with a bad shock before and it left hard to one side. Also check your rod ends if you are running ladder bars or a 4 link. I think you had bars if I remember correctly. After all that you need to get it on the scales. Hope you get it straightened out.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Whats wrong with this pic [Re: CRT] #488759
10/05/09 11:54 AM
10/05/09 11:54 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I saw a camaro with a loose shock bolt that would go right. Tightened that up and problem solved... Just an idea.
Re: Whats wrong with this pic [Re: DJVCuda] #488760
10/05/09 12:09 PM
10/05/09 12:09 PM
Nort Cackalacky
rrbrucea Offline
Member known as the "Artist"
rrbrucea  Offline
Nort Cackalacky
Nah, that dude in the Summit shirt is in focus!
Re: Whats wrong with this pic [Re: rrbrucea] #488761
10/05/09 01:01 PM
10/05/09 01:01 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Derricks Henry J started doing that all of a sudden last year roll out and shocks have been checked but maybe it's a bent rear end?? he's pulling his hair trying to solve it.
Re: Whats wrong with this pic [Re: Dodgem] #488762
10/05/09 01:45 PM
10/05/09 01:45 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If not a tire issue, the only way a car goes that hard left on the backtires, is pre-load, it has too much weight on the RR tire, causing the car to drive left. Now too much pre-load can be from shocks, bent parts, worn heim ends, weight moved around, any number of things.....However, I would look at tires and wheelie bars first. Misadjusted wheelie bars will also steer the car.
Monte
