Re: RV2 compressor
[Re: NachoRT74]
#488259
10/04/09 07:49 PM
10/04/09 07:49 PM
Posts: 25,827 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Most compressors come without lube oil, the type of lube oil determines if the compressor can be used with R-134.
Re: RV2 compressor
[Re: John_Kunkel]
#488260
10/04/09 08:30 PM
10/04/09 08:30 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Ok, thanks... just a question, I read on classicautoair when making the conversion EPR valve NEEDS to be removed http://www.classicautoair.com/MOPAR_OEM_...0&width=480Does mean that, REMOVED and just letting empty that location? I have ran 134a gas on my car but compressor never has been touched inside, beside cleaned and refilled with the right oil. EPR valve has been there allways and AC compressor has been working without problem ( well has been getting lower and lower performance latelly ). What does make that valve and why should it be removed ? I dunno what to do right now. My compressor got a WEIRD noise like it had some "tappets" problems, making that kind of noise at idle and decreasing the noise as far Revving up, but noise allways present. I'm searching for some compressor locally, but CSK auto have them really cheap. That would mean wait for about couple of months to get it in hands. thinking thinking thinking
Re: RV2 compressor
[Re: Ronnman]
#488262
10/04/09 09:20 PM
10/04/09 09:20 PM
NachoRT74
Valencia, España
I thought that it was the expansion valve function!!!
why not the valve and a softer spring ?
what does make the expansion valve then ?
yes I have seen the compressor at ebay, but CSK Auto beats the price from ebay in about $45 between price and shipping since CSK auto is free shipping
Re: RV2 compressor
[Re: NachoRT74]
#488263
10/04/09 09:25 PM
10/04/09 09:25 PM
NachoRT74
Valencia, España
beside that, I'm trying FIRST to fix this locally but everybody tells diff stories about when making the 134 conversion, what I already "made" around 3 or 4 years ago
