Re: Welding Help?
[Re: joedust451]
#487156
10/04/09 01:18 PM
10/04/09 01:18 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
When you say "gas shield", what are you referring to, & you suggest a thinner wire?
The "gas shield" is the inert shielding gas, (commonly Argon or Argon/CO2 mix) used during MIG welding of steel.
MIG = Metal Inert Gas,
or more correctly, Gas Metal Arc Welding (GMAW).
Since no "Flux Core" is required in MIG Welding (just solid bare wire) the wire-diameter can be smaller.
Smaller diameter wire can be run/melted with lower current, thus reduced chance of burn-through.
