Re: Is 3" exhaust too much? [Re: Evil Spirit] #487072
10/04/09 12:43 AM
10/04/09 12:43 AM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
just a touch more than 400. I will post my build info and see if anybody can figure out how much HP it should be making
Re: Is 3" exhaust too much? [Re: D_C] #487073
10/04/09 10:24 AM
10/04/09 10:24 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I also own a '71 Charger. When I upgraded from 2 1/2-inch to 3 1/2-inch exhaust on the 440 in it, 1/4-mile ET performance improved by 7/10-second.
Wow. DC I like that pic of your Charger. THAT is the way to do a '71 Charger!
Re: Is 3" exhaust too much? [Re: cougar_cat_25] #487074
10/04/09 11:18 AM
10/04/09 11:18 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
I'd just hate to mess up this engine by over heating valves and so on. You guys are right about the horse power tho, I haven't upgraded the intake, carb or the heads so I do have room to grow. However, it's a street car and I'd like to build it to be durable.
How do you figure you'll overheat valves by the size of your exhaust system? The only way you'll cause problems for the exhaust side of the engine is if you don't run enough timing. The fuel will still be burning as it goes out the exhaust.
I think 2.5" exhaust will be plenty for you. It's easier to package under the car and you'll pay less for the tubing and everything. Well typically you will.
Re: Is 3" exhaust too much? [Re: dodgeboy11] #487075
10/04/09 11:36 AM
10/04/09 11:36 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
if you are buying a new system anyway, i'd go 3" as they cost the same from places like tti. 440's like to breathe
Re: Is 3" exhaust too much? [Re: Boise Chall] #487076
10/04/09 12:41 PM
10/04/09 12:41 PM
MNobody Offline
MNobody  Offline
I run 3" on mine with 2 1/2" flowmasters dumped in front of the axle behind a mild built 318 with a .528 cam and i like it, makes the garage floor vibrate
Re: Is 3" exhaust too much? [Re: cougar_cat_25] #487077
10/04/09 01:03 PM
10/04/09 01:03 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
the only issue i have with the 3" systems is it limits your muffler choices to mostly performance mufflers, with the 2.5" system you can get quieter (but more restrictive) mufflers.
If you want performance go 3", if you want to hear the radio, the 2-1/2" may be better.
Re: Is 3" exhaust too much? [Re: MNobody] #487078
10/04/09 01:05 PM
10/04/09 01:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
There is a huge difference in the 3" TTI with Ultraflows (best flow and quiet) than the Flow Bastards. Load rattly and not as good of flow and neighbors hate them!!
Re: Is 3" exhaust too much? [Re: cougar_cat_25] #487079
10/04/09 01:14 PM
10/04/09 01:14 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
2.5 inch exhaust is fine...even to 500 hp...I have 2.5 TTI on My bee...440/030 over...6 pack with stock high performance manifolds and it works well...I have 3 inch on My 67 GTX with a 498 stroker and fitting th tailpipes and over the axel pipes is a Pain.....I have headers on the GTX and get the drone....The bee has no drone...I attribute it to headers....both have crossover pipes..one thought...the first hemi's rated at 425 hp and were grossly underrated..had less than 2.5 inch exhaust systems.
Re: Is 3" exhaust too much? [Re: terzmo] #487080
10/05/09 08:28 AM
10/05/09 08:28 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
2.5" MANDREL BENT won't be much of any restriction to a car up to 500-550 HP. it'll be much quieter, too. another option is to go 3" to the mufflers and then 2.5" muffs and tails, as by then the exhaust gasses has contracted and cooled enough to not need all the volume.
a good article:
http://www.pontiacstreetperformance.com/psp/exhaust.html
pg. 2, they only lost like .05 ET going from 3" tails to 2.25" tails....
2017 Grand Cherokee Overland
Re: Is 3" exhaust too much? [Re: patrick] #487081
10/05/09 09:08 AM
10/05/09 09:08 AM
I would highly recommend an X pipe over an H pipe setup. Major difference in noise & I think a bit more power also. As said MANDREL bends no matter what system and no neckdown in the muffs.
Re: Is 3" exhaust too much? [Re: RapidRobert] #487082
10/05/09 09:53 AM
10/05/09 09:53 AM
I run 3" pipes with dumps from the headers to 3" custom mufflers into 2 1/2 tail pipes with factory like stainless tips on my '70 duster..no restrictions what so ever,car has run the same numbers through the exhaust or opening the dumps..
