Re: Any luck matching original undercoating?
[Re: cougar_cat_25]
#483944
09/30/09 12:17 AM
09/30/09 12:17 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
If you have small areas that broke off, here is what I did and it blended real well. You can do this on both inside the car and out side as well. This is in my trunk....
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#483945
09/30/09 12:20 AM
09/30/09 12:20 AM
Troy
West Coast, CA
....placed a little 3M Autobody sealant to fill the void and let it tack up for about 10 minute...
[Re: Troy]
#483946
09/30/09 12:21 AM
09/30/09 12:21 AM
Troy
West Coast, CA
then I took a worn steel brush and tapped the sealant to give it a textured look...
[Re: Troy]
#483947
09/30/09 12:22 AM
09/30/09 12:22 AM
Troy
West Coast, CA
Here is a better example to show you the end results...
[Re: Troy]
#483948
09/30/09 12:24 AM
09/30/09 12:24 AM
Troy
West Coast, CA
....just like before and when I was done I sprayed some 3M Undercoating...
[Re: Troy]
#483950
09/30/09 12:28 AM
09/30/09 12:28 AM
Troy
West Coast, CA
Good luck!! By the way, I still own this car and the fix was done four years ago and still looks good.
[Re: cougar_cat_25]
#483952
09/30/09 10:57 AM
09/30/09 10:57 AM
Troy
West Coast, CA
For big stuff 3M has a product called Body Shultz (sp?) It's a rubberized undercoating and you also have to buy the gun that goes along with it. It's the closet thing that I have ever found.
